GM Holden LX Torana - LS1 Conversion
1976 GM Holden LX Torana Sedan
LS1 Conversion (from 2004 GM Holden Commodore)
Performance Wholesale Heads - CNC Ported
Comp Cam 238/240
Patriot Springs/Pushrods
Yella Terra Roller Rockers
Race Balancer
Meiziere WP119U Electric Water Pump
Low mount Alternator conversion
T400 Gearbox, fully manualised
B&M Mega Shifter
B&M thermo cooled transmission cooler
3800rpm Hi-Stall
TCI Flexplate suit LS1 & T400
Moroso 20140 oil pan
MSD Starter Motor
Borg Warner Diff Conversion with 3.9 gears and mini spool
Custom Tailshaft
Custom Headers, twin stainless 3" exhaust, magnaflow cats & mufflers
300mm Front brake conversion with twin piston calipers
Super low springs, Koni shocks all around and full rubber/bush kit
1" 4 wheel disc master cylinder, A9X booster, custom brake lines
Started off as a 1 owner 6 cylinder car. Lots of money spent and still not painted or running.
Requiring Wiring & Fuel system to complete and some small exhaust modifications.
Before being touched
![](http://imagehost.perthstreetcars.net/images/11firstday_frontright.jpg)
![](http://imagehost.perthstreetcars.net/images/73firstday_rearright.jpg)
6 cylinder out
![](http://imagehost.perthstreetcars.net/images/45IMG_20110131_00018.jpg)
Different between Banjo drum brake diff and new borg warner disc brake diff
![](http://imagehost.perthstreetcars.net/images/27IMG_20110209_00029.jpg)
First test fit of LS1 engine
![](http://imagehost.perthstreetcars.net/images/1315022011010.jpg)
First Magazine Feature
![](http://imagehost.perthstreetcars.net/images/30danmagazine.jpg)
Custom Headers being made on "jig"
![](http://imagehost.perthstreetcars.net/images/95done2.jpg)
Brakes on, diff in, engine re-fitted
![](http://imagehost.perthstreetcars.net/images/66Clipboard01.jpg)
Gearbox in, Exhaust made
![](https://sphotos-e.ak.fbcdn.net/hphotos-ak-ash4/314867_10150299264058896_6840000_n.jpg)
![](https://sphotos-a.ak.fbcdn.net/hphotos-ak-ash4/302130_10150290209893150_2164342_n.jpg)
![](https://sphotos-h.ak.fbcdn.net/hphotos-ak-ash4/309754_10150290210423150_2099104_n.jpg)
Another Magazine Feature
![](http://i701.photobucket.com/albums/ww15/P100_Ute/cars/DanWA-LS1-Torana.jpg)
Off for suspension/brakes to be finished (note buick v6 for gate stopper
![](http://imagehost.perthstreetcars.net/images/43suspensionbrakes.jpg)
Back from suspension/brakes
![](http://imagehost.perthstreetcars.net/images/73homeday_21_6_12.jpg)
![](http://imagehost.perthstreetcars.net/images/77homeday1_21_6_12.jpg)
And that is pretty much how she sits today, owning a house with a few projects on the go means kind of slow progress from here
Comp Cam 238/240
Race Balancer
B&M Mega Shifter
3800rpm Hi-Stall
MSD Starter Motor
Custom Tailshaft
6 cylinder out
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Good chance of that, they are available in GM cars from 86 through to 97, aswell as Australian fords from 81 through to 98. Also Australian delivered Nissan Skylines 86-88. The particular one i used is from a 87 Skyline as it is the same width as the Torana diff from the factory.
The good thing about so many cars sharing this diff is there is a multitude of gears and centres available including aftermarket like LOKKA/TrueTrac/Kaaz
