ls 4.8/5.3 turbo budget fox
So im new to this forum and new to a build like this. I'm interested in doing a turbo ls 4.8 or 5.3 in a fox body on e85 and on a budget... of course
I've been doing quite a bit of research and I hear people making this swap happen for about 5 grandish. the info I've gotten has already been very helpful, but I was hoping someone could sum up a very basic parts list for me.
basically my end goal is similar to others... I want a gutted street legal 10sec beater! (don't really care bout reliability either)
I and a friend should be capable of all the work except the tune.
parts is was planning on
aje k member
custom driveshaft
stall converter
some of my questions are..
is it best to by a "drop out" (engine/accseriees/tranny/harness and ecu?)
do I need that vehicles gauges also? even if I have the cluster ziptied somewhere I can see them
what auto transmission?
fuel system pump/rails/injectors etc?
I realize I could search forever but theres a 93 lx roller fs in the area, should I pull the trigger or no?
any help would be awesome
thanks
aje k member
custom driveshaft
stall converter
thanks
aje k member
custom driveshaft
stall converter
thanks
aje k member
custom driveshaft
stall converter
thanks
To answer some of your other questions as far as a motor and trans go, you'll have to decide on that. Things such as what trans do you want 4l80 or 4l60? Do you want f body acc or truck, which intake? Stand alone harness or are you planning on modifying a stock one and making it work? Fuel system as stated above when on a budget you may end up leaving power on the table by trying to stay under that 5k mark by not setting up a good fuel system thats up to the task, so you have decide whether you plan on trying to make a lot of power with this down the road. Thats why these projects get out of hand, you put the car together for 5k, get it running, lose a few races and want to add power and end up buying a ton of parts twice in the upgrade process. Gotta plan the build carefully.
What type of modification would need to be done?
I am currently finishing up on my LS swap, I got the car for $700 (90 notch 5.0 w/t-5) 123k miles, had been parked for 8 years great interior, I stole it. 5.3 with PCM and harness for $500, 4L80e with converter $600 slip yoke $100. aje crossmember with a-arms $700. Custom length drive shaft $100, new fuel system in-tank Bosch 044, $300. LS6 intake $300, Fbody oil pan kit $250, Leash electronics relay board $100. Fbody radiator free, got love free. Lincoln markVIII fan $20, trans cooler $15, and at least another $1000 in misc things not mentioned. That's the cheapest-best LS mustang swap I have ever seen. Took me 6 months to buy all the parts and get it on the road. Brother in law is tuning it, so good cost savings there too. My goal was 4K, I was a little over $4700 when done. Helps I sold the 5.0 and T-5 for $1250!!!!! Suckers
I am leaving out a bunch of stuff that was very time consuming but not expensive necessarily. I built the exhaust using corvette manifolds and 2-1/2" pipe all the way out to the rear bumper. Re-wired the factory truck harness, used ford sending units for all the factory gauges. (No speedometer yet, but that's it.) fabed my own trans crossmember, built my own cold air intake. I have an considerable amount of tools and raw supplies already at my disposal, another benefit many may not have. I spent a ton of time researching what to buy, and learned a lot from my brother in law who has already completed his LS swap, a 6.0 turbo with powerglide running 5.60's in the 1/8th. It's not possible without help from those of us who have already been in your shoes. Feel free to ask, I may not know the answer, but there is a good chance I do.
O-I figured I was going to blow my budget, I would have made it if I didn't have to to the AJE, and could stick with the factory k-member. I figured it would really cost $7-10. But I got luck with a bunch of stuff, the brother in law intell helped considerably.
No turbo......yet. I am planning on a turbo, that's why I went with the 4L80e. It's a lot less work to go with a 4L60, but they are weak. I have not done a thread, but I took a ton of pics, on when I have time I will put one together.
Your trying to stay under 5k and going turbo? Good luck, for me the turbo stuff is what really put the hurting on the wallet because I spent a bunch of money on making sure everything else was up to the task (ie proper converter, good trans, built rear, steller fuel system, good intercooler, good wastegate and bov) I also made sure to spend the money to make sure I could make the power hook (ie full suspension, tubular everything) The AC also added to my bill a bit as well and all new full interior and nice seats.
When I go turbo, I plan on dropping another 3-4K. For now it's going to be my daily driver, and tuned for MPG. OD trans and 3.08 rear axle. I am shooting for high 20's on the highway. We will see shortly.
[QUOTE=5.3Notch;17727786]When I go turbo, I plan on dropping another 3-4K. For now it's going to be my daily driver, and tuned for MPG. OD trans and 3.08 rear axle. I am shooting for high 20's on the highway. We will see shortly.[/QUOTE
maybe this is what I should figure on.
Sorry if this is harsh, but even if you keep the interior gutted and use a lot of stock suspension parts and stock gauge cluster and save money here and save money there sort of thing I would expect to spend around 10k for an turbo lsx swap fox if you want it to be done right and run 10's. Also be really careful when buying stuff off craigslist too, my build was done until I realized that my "built" rear end I bought off craigslist was built completely wrong and now I am having to rebuild it.
Have not been to the track yet, we just tuned it for the first time on Thursday night. And diagnosed a bad head gasket, so I have more parts on order, then I can finish the tuning and take it to the track.
