New Hooker 1st-gen/Nova swap parts info
Old 01-14-2016, 11:02 AM
  #161
Toddoky's Avatar
Originally Posted by robm-951
I did mine similar to post 20 in this thread, but I used 2 flat pieces instead of the one curved plate. I have an alternator mounted, but no a/c compressor. I did notch both sides so hopefully when the time comes, I can run a low mount compressor. I don't think even with notching you'll be able to use the f-body compressor mount.
https://ls1tech.com/forums/conversio...8-74-nova.html
Actually, you can use a 4th-gen f-body alternator with the Hooker 1st-gen F-body engine brackets as long as you notch the subframe. This is possible due to the brackets being of a unique proprietary design that deletes the factory frame stands from the mounting of the engine. Typical swap plates will not allow you to do this.
Old 04-06-2016, 10:23 PM
  #162
Sebtarta's Avatar
Todd to recap from our PM's, so other people that have this question can get the info as well.
If we do the stroker on the LS, in my case a 408, it would be wise to still use the 302-2 pan but just welding a bump on it as the pics below
Will this still clear the frame?
Maybe the new 302-3 pan can come with this hump already incorporated?
Old 04-07-2016, 06:11 AM
  #163
Toddoky's Avatar
Yes, those photos depict the needed modification well and the pan will fit in the 1st-gen F-body/ 3rd-gen X-body subframe following the process without further mods to the car.
Old 08-15-2016, 02:36 PM
  #164
ryeguy2006a's Avatar
I am curious Toddoky, is that something that may be incorporated into the 302-2 pan in the future? It seems like a small modification to the 302-2 pan that would allow the use of 4" stroke, while still clearing the frame. Any thoughts? I will be in the market for one within the next 6 months, so I would be interested to know.
Old 08-15-2016, 05:14 PM
  #165
Toddoky's Avatar
It's been discussed within the engineering/product management teams, but I don't have any specific knowledge of it being green-lighted to happen.
Old 08-18-2016, 09:12 AM
  #166
Hi Todd,
Thank you for the update. And for those that may be looking for other engine mount combinations, these mounts are awesome! They just fit, and I mean everything. I tried to save money on my other swaps by using different mounts and this was far and away the easiest mounts I have used.
It took me 5 mins per side to drill the one hole that is required for these mounts, and when I bolted the motor/trans/sub-frame to the car I had clearance everywhere! Firewall, trans tunnel, and ground clearance. I did a quick test fit of the F-body low mount alternator, and I am 99% sure I won't even need to notch the frame. Nice work guys!!
Old 08-18-2016, 09:14 AM
  #167
Quick question for those that have done the swap with a 6 speed. What is the length driveshaft that you have used? Is there by chance a stock GM driveshaft from something like an S10 or something that may be the same length that can be picked up at a JY?
Old 05-11-2017, 02:59 PM
  #168
It seems that a lot of the photos in this thread are lost. Can someone please post up the clearance between the drag link and the 302-2 oil pan? From multiple angles would be great, and also what pitman arm is on the car. The 5.25" or the 5.8" arm.
Old 05-11-2017, 03:18 PM
  #169
Toddoky's Avatar
Here's what I have from the development file...the photos show the clearance at full turn on both sides. I can't confirm the length of the pitman/idler arms that were on the car unfortunately.
Old 05-12-2017, 08:40 AM
  #170
Thank you for the pictures Toddoky.
Old 05-12-2017, 06:41 PM
  #171
GonHuntin's Avatar
Heads up to anyone using the Holley parts in a factory air car. I just did the swap with an LS1 out of a 2002 Trans Am. There is no way the right side coil packs will fit mounted in the 02 f-body location.
There is also no way to get the driver's side header (1 7/8" full length header) installed following the directions included with the headers.......the directions say to lift the front of the motor with an engine hoist or jack the left side of the engine up with a floor jack......neither method works......we tried!! The passenger side head hits the evap box long before you get enough clearance to install the header. We had to take the steering box out of the car, put the headers in place with just the center bolt so they could swivel, remove the brake line going to the passenger side and put the steering box back in the car.
Old 05-18-2017, 02:57 PM
  #172
RW68CAMARO's Avatar
any pics, i'm doing the same swap. thanks RW
Old 05-18-2017, 06:09 PM
  #173
GonHuntin's Avatar
What do you want pictures of??
Old 06-28-2017, 01:23 PM
  #174
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,142 Likes on 742 Posts
Holley motor mounts, they allow moving motor back inch or so? Part number for the motor mount kit?
Old 06-28-2017, 01:44 PM
  #175
GonHuntin's Avatar
No, the Holley mounts do not allow any adjustment.
Old 08-20-2017, 11:49 AM
  #176
LS1 pwrd NOVA's Avatar
Anyone using stock corvette accessories in their swap using this setup?
I have I think c5 accessories and the power steering pump pully is close to the A arms. I did a quick fitment of the pump and It looks like there is maybe 1/8" or less of room from the pulley hitting or rubbing.
If I don't like the fitment, what accessories are most of you guys running besides the truck setup using the hooker ls swap plates?
Old 08-20-2017, 12:11 PM
  #177
Toddoky's Avatar
Your easiest/cheapest fix is going to be to swap out the PS pump pulley (i.e. Holley part no. 97-154) for one of smaller diameter. Many users just swap it and go, but if you are going to drive your car aggressively, you should considers using a kit that lowers the pump pressure also.
Old 08-20-2017, 04:31 PM
  #178
Not bad for $35 but it says you must use an underdrive pully to keep pump rpms down.
So does truck and fbody accessories fit with no issues ?
Old 08-20-2017, 10:14 PM
  #179
Toddoky's Avatar
The pump manufacturer recommends use of the underdrive pulley, which is why Holley makes the recommendation also. I can tell you that hundreds of guys have swapped the PS pulley out by itself and ran their car without issue. I've never attempted to install the truck accessory drive on a 1st-gen, so I don't know what the result would be. A stock 4th-gen accessory drive set-up won't install without notching the subframe to clear the alternator.
Old 08-21-2017, 07:40 AM
  #180
My plan for my accessories is a type of hybrid set-up that I believe will solve both problems of notching the frame and clearing the a-arms. I am running a truck pulley, and spacing out the low mount LS1 fbody alternator 3/4" so they are at the same pulley spacing. I haven't tested it yet as I am waiting for the longer bolts, but my mock up with the shorter bolts shows that it will have clearance everywhere without having to notch the frame.
Quick Reply: New Hooker 1st-gen/Nova swap parts info
