Lq4 swap won't idle
So I got my swap running. Runs good off idle but will not idle. I took the computer to F-body central in Baltimore to have vats deleted and a baseline tune done. I have a little handheld scanner that can show me some live data. Here's what I got
Fresh rebuilt Lq4 pretty much stock except 215 cam
Home built harness following lt1swap.com
55lbs of fuel pressure
New injectors
On my second MAF and is reading about right in the scanner
Both O2s are new and reading
IAC seems to work, moves when the key is first turned on and hunts for a high idle sometimes
ECT sensor is good
TPS is good
Stock pcv setup
Fixed the only vacuum leak I could find now I'm closer to getting it to idle
The lowest the rpm will go is right around 1000-1200 with the throttle proped open at 8% if I go to 7% it dies.
I'm thinking possibly
IAC
MAP
PCV > catch can
Tune
I'd like to get it to idle so is can drive it to get it tuned. Any ideas?
New injectors
ECT sensor is good
TPS is good
Stock pcv setup
IAC
MAP
PCV > catch can
Tune
Ran the engine again last night. tried capping all vacuum ports. ran the same. tried unplugging the MAF = ran worse. plugged MAF back in and unplugged the MAP = ran worse and smelled very rich.
throttle at 9%
1000-1100rpm
MAP - 37-39 kPa running / 101 kPa koeo
seems like 18.5-19 in.Hg vacuum
MAF - ~14g/s
ignition timing - 27.5
fuel trims
bank 1
st - 0%
lt - 0%
bank 2
st - 0%
lt - 0%
bank 3
st - -24%
lt - -64%
bank 4
st - +10%
lt - +51%
throttle at 9%
1000-1100rpm
MAF - ~14g/s
fuel trims
bank 1
st - 0%
lt - 0%
bank 2
st - 0%
lt - 0%
bank 3
st - -24%
lt - -64%
bank 4
st - +10%
lt - +51%
Shouldn't it be idling between 55-75 kpa. A 5.3 ive been working on idles between 55 and 65 depending on idle speed. It has a Tsp 224/228 cam. I haven't started tuning it to far yet but it idles really good. It even started up with factory tune. Had to adjust the throttle butterfly. I have to close it down now because iac is down to 0 at idle. Are the injectors factory sized or larger. If they're larger and its not tuned for it, the engine will run rich. Maybe the base idle airflow table is off.
I thought that was funny too. Swapped the pins at the PCM to read bank 1/2 but then I was getting fault codes for no b1s1 and no b2s1 readings. So I swapped the pins back and the fault went away. It's a launch scanner from matco. I think it's just displaying the banks backwards.
I have about 3ft of tube after the header with the o2s 1ft down them. Yea 30lbs from the from the big blocks. I told the tuner that I have 30lb and he said he adjusted it to them.
The butterfly is completely closed. The shop I went to for the baseline is good and reputable.
Yep. One thing I'm wondering is if I accidentally got the pins backwards for the IAC. Would that cause the IAC to move in the wrong direction?
Cleaned the IAC. Didn't help. I pushed the IAC all the way in and left it unplugged and idled really high and fine. I'm going to replace the IAC tomorrow. But if that doesn't work could my wiring be backwards for it?
Latest update. Yesterday, I got a new IAC and put it in. truck started and idled fine without me messing with it. I could rev it up a little bit and it would come right back to idle. no issues. Had about 5min of idle time. Turned the truck off to run brake lines. Tried to start it again for a buddy and right back to the same issue. I tried unplugging both O2s, same issue.
Is your setup a cable throttle setup? If so your tps should be 0% at idle. Can your tool tell you the iac count?
Did the tuner turn off the rear 02's and cot (cat over temp protection)?
Yesterday I checked the wires for the IAC. all 4 have continuity and are going to the right pins in the harness. They arent shorted to ground or positive.
76 -> B
77 -> A
78 -> C
79 -> D
What I have that is known good:
New Delphi IAC
Good wiring
Good ECT signal
Good TPS signal
Good MAP signal
seems like a good MAF
Now more on the O2s
I have what I believe is a case grounded O2s. Theyre the flat 4pin connectors.
I have them wired
B1S1
A - Tan/white -> 29 blue
B - Purple/wht -> 69 blue
C - Black -> ground
D - Pink -> switched 12+
B2S1
A - Tan -> 26 blue
B - Purple -> 66 blue
C - Black -> ground
Does this look right?
