adapter for temp sensor plzzz
Old Jun 1, 2014 | 10:48 AM
mohd2116's Avatar
Question adapter for temp sensor plzzz
hey guys .. i need adapter for the analog temp sensor to fix it on Ls1 temp hole which is 8mm as i think,, any suggestions
and what i want to fix is
Old Jun 1, 2014 | 01:19 PM
Stormed_Norm's Avatar
Your sensor is bigger than the factory hole? Would you consider drilling and taping it to the size for your sensor? Looks like there should be enough room, trim your header gasket also. ;-)
Old Jun 1, 2014 | 01:25 PM
LXguy's Avatar
Have you thought about drilling and tapping a spot on the water pump?
I don't think anyone makes an adapter for a mechanical gauge into the stock port.
Old Jun 1, 2014 | 02:03 PM
garys 68's Avatar
There's a brass block plug on the drivers side. The hex center is perfect for 1/2" NPT. But the depth of that will require a pipe spacer, but will easily work.
Old Jun 2, 2014 | 03:13 AM
71ANTICARB's Avatar
https://ls1tech.com/forums/conversio...-car-pics.html
Old Jun 4, 2014 | 05:13 AM
mohd2116's Avatar
thank you all , all your solutions is good i will follow the link that 71ANTICARB mentioned
Old Jun 6, 2014 | 08:13 AM
mohd2116's Avatar
Cool electric temp gauge and sender
i changed my mind to fix electric gauge so any good one with the sender as full kit ???????
Old Jun 6, 2014 | 10:15 PM
67Skylark's Avatar
Street and Performance, S&P. Mena AR sells an adapter that should work
