Fox with gm 6 speed question
Old Sep 5, 2014 | 04:38 PM
66NBLUE's Avatar
Default Fox with gm 6 speed question
I'm putting a ls1/ 6 speed in a 92 coupe. I'm using AJE k member and tranny cross member. It looks like I'm going to have to cut out a good part of the trans tunnel to clear the tranny. Has anyone else ran into this problem? Thanks guys.
Old Sep 5, 2014 | 11:34 PM
dmracing's Avatar
I read somewhere if you run the engine mounts backwards it will be at the shifter hole.
Old Sep 6, 2014 | 11:40 AM
usdmholden's Avatar
I had to hammer my trans tunnel in a few places with my MM k member and engine setback. If you have a 2.3 auto chassis the trans tunnel is smaller to begin with than a T5 chassis.
Old Sep 9, 2014 | 11:00 PM
64post's Avatar
Default Tunnel clearance
I did not hammer or even touch the tunnel, I cut the unused "ears" off the top/front portion of the trans case and I lowered my K member with 3/8's aluminum spacer plates that I made because I wanted to get the trans tail shaft as high as could to make the power train sit as level as possible and it all worked out perfectly. I don't much care for the look of the motor leaning back and the header collectors pointing to the ground. The extra room has the motor sitting lower and the hood clears an Edelbrock Pro Flo XT.
Attached Thumbnails Fox with gm 6 speed question-20140701_141526_resized.jpg   Fox with gm 6 speed question-20140717_091544_resized.jpg   Fox with gm 6 speed question-20140715_181619_resized.jpg   Fox with gm 6 speed question-20140802_130610_resized.jpg
Old Sep 11, 2014 | 07:43 PM
SSSTANG#1's Avatar
Is that a Stiffler's crossmember?
Old Sep 11, 2014 | 08:57 PM
64post's Avatar
Yes, I don't recommend it either. The side to side mounts are not welded to the same angle and the tab for the mount is needlessly welded in a strange downward angle, I will cut it off and reweld it level, other than that? It's good.
Old Sep 13, 2014 | 05:06 PM
matt99's Avatar
The aje cross member I have looks to have some adjustability forward and backwards. And I have seen dirty dingo motor mounts have some adjustability forward and backwards as well, up to 1 inch.
Old Sep 15, 2014 | 09:14 AM
5FOX3's Avatar
anyone got a measurement on driveshaft length with a t56 to a factory 8.8?
Old Sep 15, 2014 | 01:12 PM
64post's Avatar
I used an aftermarket extra long 1310 GM 27 spline front yoke for the Fbody T56 , a 1330 to 1310 conversion u joint, a `99 mustang driveshaft with approx. 2 inches removed (to 43.5") and it has about 1.5" clearance when installed.
Old Sep 28, 2014 | 06:40 AM
SSSTANG#1's Avatar
Did you get it in?
