Rowdy burnouts and loud noises: The LSX/Subaru swap project
#101
Front side of the control arm mount
drawn up and mocked up in cardboard. I'm boxing in the other side tomorrow. More goodies ship out Tuesday, and I'm ordering my chromoly at the end of this week.
#109
Always wanted to LSx swap a GD or Forester, the rear end stuff just gets really expensive if you want to run STi stuff. Really love GC coupes, looking forward to seeing it when its done!
#113
The sti components are wider by 15mm, lighter/stiffer aluminum construction, allow me to use 5x114 hubs, which are bolt in vs. Press fit. It also let's me bolt on the factory sti brembo calipers and bigger rotors, along with millions more wheel options.
The JDM and usdm stuff of that year is nearly identical, I just happened to find a deal through an importer. The rear set up will use factory sti knuckles as well but will have DSS hubs and I'm making all the suspension links so I can convert over to all hiem joints.
#115
#116
Even though the car is going to be used a lot in straight lines like mile runs/highway pulls I don't want to lose the original nimble feel of the car. I know it won't feel the same as when it was stock n/a 2.5 but I still want the raw, tight feeling of more track oriented suspension set up.
#118
Should be enough to cover front and rear subframes, trans mount, and tunnel. Unfortunately I'm on Christmas break tomorrow until next year so progress will be stalled for the time being.
