New Hooker 1968-72 A-Body LS Swap System Preview
Old 04-11-2016, 06:07 PM
  #421
user 4737373's Avatar
Originally Posted by 69 Custom S Vert
Oil Pan Mod Complete
I like the execution of the modification, looks good.
Old 04-12-2016, 11:32 AM
  #422
cypher's Avatar
someone needs to tell holley to make 302-3 and just fix that minor problem
Old 04-12-2016, 01:05 PM
  #423
69 Custom S Vert's Avatar
holley forward position frame mounts installed
Old 04-14-2016, 05:00 PM
  #424
Test fit. Tranny not mounted. Engine mounts slid right in to frame mounts. Oil pan sits about 3/4 inch above K member. This picture is at full steering lock. plenty of tie rod clearance.
Old 04-20-2016, 12:33 PM
  #425
Default Moment of Truth
Here are the pics of the engine mounted with tranny and headers. I couldn't be more thrilled with the header fit and clearance. I had to use the g-force crossmember because Holley doesn't make one for my convertible (yet). As you can see, it works seamlessly. Thank you Todd!!!!
Old 04-20-2016, 12:49 PM
  #426
That's some good stuff right there. It's very satisfying to finally have Hooker A-body swap parts out in the market to help users simplify the swap process and remedy some of the long standing issues that have existed to this point.
Old 04-20-2016, 01:45 PM
  #427
oldstv's Avatar
Default question
Will the trans cross member making contact with the floor cause some nvh in the cab?
Old 04-20-2016, 01:47 PM
  #428
Good question. Let me ponder that one.
Old 04-20-2016, 02:01 PM
  #429
korndawg's Avatar
Did you steal my pics? Lol jk. Looking great!!! This Holley kit is amazing!
Old 04-20-2016, 02:12 PM
  #430
OLDSTV. Thanks for the observation. I'm gonna have to find 3/8 to 1/4 inch clearance somehow between the cross member and floor pan. It is not tightened down so I'll try massaging the floor pan with some wood and a jack tighten it down and see if that helps. I have brand new body bushings so that can't be the issue.
Old 04-20-2016, 02:22 PM
  #431
oldstv's Avatar
It might be an issue as far as nvh. You could drive it and see, you can always come back to it. I do wonder about possible corrosion at the contact points just from movement. This too might not be an issue but worth looking at.
Old 04-20-2016, 05:24 PM
  #432
ycgoat's Avatar
Looks Good, Thanks for the pics they will help me out quite a bit. Would you be able to verify the center to center spacing of the header tips for me.
Old 04-20-2016, 07:45 PM
  #433
Project GatTagO's Avatar
Received 1,482 Likes on 929 Posts
Tooling for castings is expensive. Adding a little modification to the pan is cheap.
Andrew
Old 04-20-2016, 08:44 PM
  #434
Andrew
Stop being so reasonable Andrew! It would be a lot easier to justify the tooling costs associated with a design revision if a greater percentage of swappers overall were putting together stroker engines, or if the required modification was difficult to carry out. As it is, neither of those is the case. It may happen in the future, but there are bigger fish to fry at the moment that will have a greater ROI.
Old 04-21-2016, 09:03 AM
  #435
oldstv's Avatar
I agree!! Like doing the 66 and 67 cars.
Old 04-22-2016, 08:45 AM
  #436
The first production run of the 1-7/8" mid-length headers has been completed and will get boxed up and placed on the shelf next week. The transmission crossmembers are running a week behind schedule but should get delivered next week. Here's a photo of a set of the mid-length headers out of the completed batch...
Old 04-22-2016, 08:55 AM
  #437
oldstv's Avatar
Looks good Todd!! What would the benefit to using a mid length over a standard long tube?
Old 04-22-2016, 09:39 AM
  #438
The benefit would be to achieve the maximum possible ground clearance. The long-tubes tuck well, but for those wanting to "lay frame" you can never have enough ground clearance.
Old 04-22-2016, 10:48 AM
  #439
Todd,
I am as suing that there will be some intermediate pipes available to join the mid length headers with the exhaust system...
Andrew
Old 04-22-2016, 11:10 AM
  #440
Todd,
Andrew
That's correct Andrew. There will be adapter tube kits released that connect the Hooker cast iron manifolds to the 2.5" Hooker exhaust system, the mid-length headers to the 2.5" or 3" exhaust systems and the long-tube headers to the 2.5" exhaust system. The long-tube headers connect directly to the 3" exhaust system. The adapter tubes will get released over the next few weeks.
Quick Reply: New Hooker 1968-72 A-Body LS Swap System Preview
