Cheap manual transmissions for an LS.
Old Sep 4, 2016 | 06:56 PM
Ghostang's Avatar
Default Cheap manual transmissions for an LS.
Looking to do a cheap, cheap swap in my 04 Mustang 3.8 5 speed. I know 'cheap' and 'motor swap' should never be mixed but it's just a quick project to make me and my father-in-law closer. (He's a Ford guy, I'm a Chevy guy.) Anyway, I have my eye on a local LM7 for next to nothing. I found out I could use my factory K member if I use 4.6 mounts and adapter plates. I was hoping to use my factory T5 5 speed (I spoke to someone who used one by a mix of GM and Ford parts between the clutch assembly, plus a specific bellhousing) because it would save me from having to buy an expensive T56 and switch to a hydraulic clutch, but apparently the T5 I have is just too weak. I'm looking for another transmission that will work, Ford or GM. I've checked the NV3500 and NV4500, although I'd still have to switch to hydraulic. It seems the 3500 won't handle the torque and although the 4500 will, it has a very steep 1st gear and is also extremely heavy. Any other ideas? All opinions, criticizes and "dude you're out of your ******* mind, dumbass" quotes are welcome lol. We're planning on doing two of these, but the first one we want to do dirt dirt dirt cheap. The second one will be more expensive, using AJE parts, aluminum block+t56, etc.
Old Sep 4, 2016 | 08:34 PM
DavidBoren's Avatar
Welcome to the forums.
Just rebuild/upgrade your T5, and get the bellhousing to mount it to an LS. You can get all the fancy cool-guy parts like billet keys and bronze guides and a master rebuild kit from thegearbox.org to make the T5 you have now equivalent to a "Stage II" transmission. Plus, you get a fully refreshed transmission, instead of a junkyard mystery transmission in unknown condition.
You also might want to take a look at the Hooker SN95 adapter plates for the engine. All the UPR and other crappy swap kits make the engine sit really high. The team making the Hooker mounts have went out of their way to make the engine sit lower, and I think that is worth mentioning.
Don't forget to either swap in a GT 8.8 axle or a '04 Cobra IRS. Those V6 axles are a joke. So are the V6 brakes, swap those for the '04 Cobra brakes, as well.
Old Sep 4, 2016 | 09:02 PM
Ghostang's Avatar
Thanks a lot, David!
That was my original plan but I've never taken a transmission apart so I'd probably feel safer if I were to have someone to do the rebuild lol. But factoring in the $400 for the master rebuild kit, price to have someone do the rebuild, and nearly $700 for the QuickTime bellhousing, I'll be paying a lil more on the transmission part than expected and would really rather avoid it if possible. If it comes down to it, I guess it's still a cheaper alternative to the T56 and McLeod hydraulic clutch conversion.
Old Sep 4, 2016 | 09:22 PM
DavidBoren's Avatar
Don't be afraid of rebuilding your own transmission. You can find a million step-by-step walkthroughs and plenty of people with experience to help you through the process of rebuilding it yourself. That saves you the cost of paying someone else to do it. Not sure what it even costs to get a transmission rebuilt with a master rebuild kit you are providing, but I have seen shops charge $500 just to install customer provided gears in an axle, so anything you can possibly do yourself usually saves you an assload of money.
The bellhousing is going to be expensive no matter what, but that is the price of admission. You might be able to find a used one if you shop around.
Old Sep 5, 2016 | 07:43 AM
Pop N Wood's Avatar
An old muncie or super T10 will bolt up. You need to source a 621 big block bell housing or buy an aftermarket equivalent, same one you would use with your T5. You can even run mechanical clutch linkage.
Here is a not too bad thread
https://ls1tech.com/forums/manual-tr...-can-here.html
Old Sep 5, 2016 | 10:08 AM
garys 68's Avatar
Consider a Muncie or T10, no issues with either. I've run both behind an LS motor.
Your Ford T5 has a different bell to trans bolt pattern, input shaft, clutch spline and pilot bearing diameters. It's probably doable to mate it to a GM with bellhousing and pilot bearing adapters, hybrid GM/Ford clutch, but may cost more than buying a Muncie/T10, 621 bell, and clutch.
There is a stock GM bell with ford bolt pattern (4.3 Astro Van), but those are pretty rare.
Old Sep 5, 2016 | 03:06 PM
JoeNova's Avatar
Restricted User
NV3500 bolts up too.
Old Sep 5, 2016 | 03:59 PM
JayinMI's Avatar
Rare because you don't see many manual transmission Astro vans, IIRC.
Jay
Old Sep 5, 2016 | 04:32 PM
DavidBoren's Avatar
The 4.3 was only available with a T5 manual transmission in the Astro for one year, 1992. From '93 onward the automatic was the only transmission offered.
Old Sep 5, 2016 | 07:05 PM
Ghostang's Avatar
Would the Astro bellhousing work with a Ford T5? I'd figure the Ford and GM T5s would have two different front plates.
Old Sep 5, 2016 | 07:30 PM
DavidBoren's Avatar
For whatever reason, Chevy used a Ford pattern T5 in the Astro, just with a special GM bellhousing. So that bellhousing should bolt directly to a Ford T5.
Old Sep 5, 2016 | 08:14 PM
S10xGN's Avatar
Not sure if it will work with a Ford T5, but it's made for the small 10.5" clutch and thus will not work for an LS swap with normal LS flywheels...
Old Sep 6, 2016 | 11:16 AM
garys 68's Avatar
Couldn't say for sure, but the pic I found makes it look similar to a 621 (pic below). Yu can see bosses for both GM and Ford patterns.But then you still have to deal with the different input shaft length, hybrid GM flywheel/pressure plate, ford disk, bearing retainer, and pilot bearing.
A Muncie/T10 would be much simpler.
Old Sep 6, 2016 | 10:43 PM
jmd's Avatar
jmd
The bolt pattern matches, so the answer is effectively, this:
The biggest potential gripe about a non-GM/V8 T5 is the ratios. GM stuck with the 2.95 first gear for all V8 third gen T5 F-bodies; Ford dropped it before '85. It's a good gearset as far as ratios go; I wouldn't want a 3.35 or higher.
The T5 Astro used a 168 tooth flywheel (see the starter pocket protruding out,) like all S/T 4.3 trucks. Their 10.5" clutch wasn't matched to a 153 tooth flywheel.
In a T5 car that already has the T5 which is set up for speedo, shifter position and maybe even can re-use the driveshaft? Just stop, Captain. Tenille is tired of you and your mismatched clutch disc.
Old Sep 6, 2016 | 11:57 PM
gnx7's Avatar
Here is another option. I wouldn't even put $1 into ANY T5 transmission unless the internals were not even remotely stock.
350z Gen2 CD0009 transmission
https://ls1tech.com/forums/conversio...009-trans.html
Old Sep 7, 2016 | 08:38 AM
S10xGN's Avatar
Originally Posted by jmd
...The T5 Astro used a 168 tooth flywheel (see the starter pocket protruding out,) like all S/T 4.3 trucks. Their 10.5" clutch wasn't matched to a 153 tooth flywheel...
My bad... I looked thru my records and found that I had bought the "iron duke" bellhousing with the Ford trans pattern. This bell definitely will not work with a 168t flywheel. Somehow was thinking it was the same as the Astro bell.
Attached Thumbnails Cheap manual transmissions for an LS.-100_2375.jpg   Cheap manual transmissions for an LS.-100_2376.jpg
Old Sep 7, 2016 | 12:03 PM
elliss12's Avatar
I currently have a ls1/6 mated to a 94 cobra t5 utilizing a quicktime bellhousing, 9 1/4" 23 tooth input shaft, ls1 pressure plate, 10.5" exedy clutch disk 10 spline (for Ford input shaft). Lots of little variances between the t5's and in the end youll have almost the same amount into the t5 as you would going the t56 plus a ton more headache and a trans youre hoping will last powershifting. Again, you wont save much money if any in the end.
Old Sep 7, 2016 | 01:05 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
I Used an NV3500 behind a 5.3 in my 68 c10. Was super cheap and easy to do, trans is small and light weight and is very tough.
However it has 2 serious downfalls:
1st gear is a very low ratio and there is a big step in ratio from 2nd to 3rd
It does not like to be shifted at higher rpm
It is a great trans for just a cruiser swap, but if you are trying to race the car or go fast it probably is not your best option
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Sep 7, 2016 | 08:45 PM
Cheese Weasel's Avatar
Hell, not just "the internals"! From posts that I've seen, even the case is known for being not especially strong, & cracking...
There's a reason why GM put virtually no T5s behind the 350 engine (but you can find them behind 305s & V6s all day long). And GM dumped the T5 completely when the opti-crap-equipped LT1 was introduced, never mind the LS engines...
I wouldn't say that the T5 is garbage - but the only way that I would use one would be in a fairly-lightweight vehicle that didn't need to make much torque.
Originally Posted by elliss12
...Lots of little variances between the t5's and in the end youll have almost the same amount into the t5 as you would going the t56 plus a ton more headache and a trans you're hoping will last powershifting. Again, you wont save much money if any in the end.
Completely agree. I know that the Muncie & the T10 are each a solid choice, I don't have any knowledge about the others mentioned in this thread - but the T5 just isn't a good option behind an LS...
...but it's just a quick project to make me and my father-in-law closer. (He's a Ford guy, I'm a Chevy guy.)
Very cool man, I seriously hope that you get to make that happen!!
Old Sep 7, 2016 | 09:19 PM
truckdoug's Avatar
nv3500 is a truck tranny and it shifts like a truck tranny. there are some ones in later 4.3 s10's that dont have as deep of a first gear and less of a jump from 2-3.
if you gotta row your own, for as cheap as possible that's where i'd look.
the cd009 swap is gaining popularity, they were $300-400 a year ago, now they're twice that
