GM throttle body connector PT2706
So I'm putting a 6.0L in my 53 chevy and ended up with a throttle body off a 2016 6.2L. I was having a hard time finding the connector for my harness to this new style plug so I called the dealership and found they want $152 for an electrical connector! Cheapest I have found it is $72 on Amazon and most likely it is not an OEM piece. Does anyone know of a different place to buy this or any other places GM used this plug so I can track one down at a wrecking yard? Part # is 13581267 or PT2706
I am sure that Mouser has the connector and terminals, provided you know exactly the manufacturer and series, etc...
I am guessing it is a Molex connector.
Edit...more likely Delphi GT150...pg 12...?
http://ecat.delphi.com/docs/default-...aster&sfvrsn=0
Andrew
Andrew
Looks like it is TE Connectivity...
http://www.mouser.com/ProductDetail/...1cZzEMMw%3D%3D
1-1438153-3 gets you the proper A key way...
Just need to find the terminals for it...
Andrew
Andrew
Andrew
Andrew
Tipsy
![](https://ls1tech.com/forums/attachments/conversions-swaps/580999d1499380293-gm-throttle-body-connector-pt2706-te.jpg)
Looks like about 4 bucks in parts, plus shipping. I bet if you're careful, some Delphi metripack crimpers will work just fine.
Andrew
I took a screenshot of the terminal part number info on the data sheet and Keying Option "C" just happened to be closest to the terminal databox.
Tipsy
![](https://ls1tech.com/forums/attachments/conversions-swaps/581000d1499381032-gm-throttle-body-connector-pt2706-te.jpg)
Maybe I'm misinterpreting the info on the datasheet but I think the terminal part numbers are the same regardless of the keying option.
Tipsy
Tipsy
The OP owes us beers for saving him $65...
Andrew
Thanks everyone for the info, I found one terminated for like $15. I am now looking for the pinout for this connector so I can wire it in. I am unable to locate a wiring diagram for it.
