Affordable fuse/relay panel suggestion
i have the one you linked.
seems fairly solid. i havent moved my nest of relays/fuses into it yet but i might start on that since i pulled a muscle trying to get my motor out the other day to fix an oil leak and need to get stuff done on it but cant do anything strenuous.
They work fine. I don’t recall them having a waterproof seal
99% of GM factory fuse panels I have seen are not watertight. Relays on the older 80-90's cars like S10 and Buick FWD cars use sealed relay sockets. The LSx based cars and trucks are not watertight on the bottom; they use a dust cover over the top panel. I guess these are just as good for most applications that i build.
