'92 S10 Lq4/Holley Terminator X Won't Start
I've gotten to the point in my swap where it's time to fire the truck up...only to find out it won't start. It cranks and cranks, and while the Terminator X handheld shows cranking RPM (~100), it also shows the crank and cam sensors are both sending a signal to the ECU thanks to the diagnostic lights on the Terminator X ECU itself. The only thing I can get it to do is an occasional backfire through the throttle body (I've also noticed several of the intake runners feel warm to the touch after attempting to start). I've verified I've got spark from all eight coils thanks to a timing light. The issue is fuel delivery, and I am honestly not sure where to go from here. The injectors are stock Lq4 units wired up through the Terminator X, and my fuel system is all new, with a Walbro 255 in the tank, Corvette regulator, and Holley Sniper fuel rails with a single crossover. I've attached a picture of my fuel setup under the hood. From reading the Terminator X instructions, they recommend a return style fuel system that has feed and return lines fed all the way up to the fuel rails. Is it possible my setup can't provide enough volume?
Additionally, how can I verify the injectors are firing while cranking? I have searched and people say you can hear them, but I can't tell over the cranking of the engine.
I've re-setup the Terminator X several times ensuring all the parameters are correct (including TPS autoset), and save for just that occasional backfire, I get no life at all out of the engine. I am worried I'm going to trash a bearing or two if I keep cranking on it without it building up oil pressure.
I've attached a datalog from the Terminator X during a start attempt, if anyone is willing to take a look and see if they see anything glaring. Here's the dropbox link to the log file: https://www.dropbox.com/s/vrqgkvlrsl...1-0001.dl?dl=0
Any assistance is greatly appreciated!!
Try a noid light to check for injector pulse at the injector plugs. After that maybe introduce fuel or brakeclean or the like, to see if it fires. Injectors have been known to stick after sitting for a long time.
Yes try a mood light at the injectors
make sure you have the FPR hooked up correctly. My swap had the fuel pump wired backwards inside the tank. Ricks Tanks messed up, so anybody can
I've got the regulator setup right, just checked again. Also, the vacuum fitting is capped now, the photo was taken before I had capped it off. I've got some new Accel 53 lb injectors on the way, as this motor is out of a truck that was on fire and the stock injectors that are in it suffered some heat damage on their exterior which I am sure is a contributor to the issues I'm having. Not to mention with the sloppy stage 2 cam I'm running, I needed more injector anyway.
As soon as they show up Thursday I'll get them in and update!
Got the new injectors in, new tune file with the injector parameters, and.....still nothing. What gives? The engine just cranks and cranks with an occasional back fire and no other attempt to start. Fuel pressure regulator is plumbed correctly, MAP sensor is setup correctly, I have spark verified with a timing light, however I tried spraying some starting fluid into the throttle body and it still would not fire. Is there anything else I can try at this point? It is almost acting like the firing order is incorrect, despite the "Odd" coil pack connector being connected on the drivers side, and "Even" on the passenger side.
Thanks to Andrew’s help, I’ve gotten the truck started. Turned out I had the coil harnesses reversed. I had them the way I did because I assumed when I had them apart for cleaning the way they went back together based off of how the wires were “bent” from the factory. Needless to say absentmindedly I didn’t verify and they were both 180 degrees out. For anyone who may have this issue, check your coil pack harnesses to make sure they’re hooked up right! I used this quick chart to verify
The following 2 users liked this post by draab2006:
Homer_Simpson (12-26-2021), Project GatTagO (05-22-2020)
