Coolant temp and stock ECU fan controls
Got 2 questions. I did the LT1 swap on the wire harness and it uses the stock temp sending unit on the front drivers side head. Where else can I tap into so I can use the temp guage in the car? It's a typical 1 wire hookup is all I need.
the other question is I had the ECU tuned by a local tunner, he turned on the 2 stock fan controls in the harness... forget exactly which pins they are, 33 and 42 I think. I wired up my fan using one of them. But my question is, how do they work? At what temp do they turn on the fan? I just wabt to make sure they truely are working before i cook the motor.
Thanks !
Thanks !
Rear passenger side head. The heads are identical.
i'm using the passenger side head temp port for the gauge in my volvo swap. works fine. There are no numbers on the gauge, so i couldn't tell you how well the two correlate.
Thanks !
Thanks !
That spot on the passenger side will typically read 20 or 30 degrees lower than the one on the front in the driver's side.
You can get an early 3-wire coolant temp sensor for an LS engine. Two wires go to the ECU like normal, the third wire was made to drive the coolant temp gauge directly. This will probably be the easiest and all around best option for you.
The ECU determines what temp the fans kick on. Your tuner can set them to whatever temperature you want. I often use one of them to run an electric water pump.
Thanks everyone! I'll use the rear port on the pass side head. I'm not looking for exact degrees, I just need to make sure I'm not cooking the motor. The car is a cruiser/ warm weather driver.
