Tesla Model LS4
Old Apr 15, 2021 | 06:06 AM
  #61
bobcratch's Avatar
Originally Posted by Matthew Towne
Can anyone get me physical dimensions of the LS4 drivetrain? It appears the block is the same size as a vortec, but It would be nice to get a tape measure on one.
All assistance is appreciated.
its an LS block, so its the same size as the other LS blocks. The biggest difference with the LS4 is that it has the most compact accessory drive of the bunch. Well, to be clear, the accessory drive is tighter to the block, on account of being mounted transversely in the vehicle. Check out this thread here - https://ls1tech.com/forums/conversio...nderway-2.html
Old Apr 15, 2021 | 09:21 AM
  #62
rkreigh's Avatar
Originally Posted by Michael Yount
2 LS4’s - one in front and one in back. The irony here is that the best part of the car is the power train. Near as I can tell, the rest of the car is dodgy at best...
it will be a sled but keep the electric motors and make the ls4 pull it. the batteries are low and you might have to sacrific the front motor to slap and LS4 up front
uber hybrid!!!
Old Apr 15, 2021 | 09:55 AM
  #63
Haggar's Avatar
LS4 differences are all over the web, any basic google search will show them. Example:
https://forums.hybridz.org/topic/848...changeability/
They are mostly common size, with weird accessory drives, short cranks, and a 60 degree bellhousing.
I think the larger issues you have will be when you remove the front motor, how is the overall SW of the other modules in the car going to react? (I work for one of the largest suppliers, and design/supply ECUs to Tesla). IS the system even going to run with a motor just missing? How is the braking system going to react to the front motor missing, and not able to regen? etc, etc, etc. Are you trying to retain full function and look of an OEM vehicle, or just a gutted/hacked together thing. Tesla has higher integration than most with their computing power onboard.
Old Apr 15, 2021 | 06:30 PM
  #64
Matthew Towne's Avatar
Well, I've considered that, and the RWD versions were produced at the same time as the AWD versions and shares the same rear motor.
I believe I can trick the car into thinking it's a RWD version. I still have to figure this part out, but think its very doable.
That being said, the car should brake, and regen accordingly for a RWD.
Yes, I am trying to retain the original function of the Tesla with the addition of a gas motor.
I can always modify a RWD Tesla, and then it won't even know its missing a motor.
Old Apr 15, 2021 | 06:33 PM
  #65
uber hybrid!!!
I do plan on sacrificing the front motor.
Old Apr 16, 2021 | 08:05 PM
  #66
Back to thermodynamics. So per everyone's advice I plan on venting the hood well before the windshield to help underhood temperatures. Any suggestions?
In addition I've seen where ceramic coating the exhaust can reduce underhood temps. Any opinions on this? All assistance is appreciated.
Old Apr 16, 2021 | 08:53 PM
  #67
You don't listen. Anywhere atop the hood, especially towards the rear, is a high pressure area. DO NOT TRY TO EXHAUST AIR ANYWHERE ON THE HOOD. It is all high pressure. Underneath, OK. Sides (fenderwells), OK. Look at all cars in the world. NONE exhaust via the hood, or anywhere on top of the car. It's not about thermodynamics, it's about airflow. HUGE difference
Old Apr 17, 2021 | 06:13 AM
  #68
Michael Yount's Avatar
Actually, you can vent the hood, but it needs to be well forward of the windshield; probably the front third. If you look at pictures of mid-engined race cars with the radiators in the front, there's frequently a big outlet right behind the radiator. Where you have FLOWING air over the hood, you'll have lower pressure. Of course, that flow gets disrupted/re-directed as it approaches the base of the windshield --- it "piles up" and creates a higher pressure area. Note the big opening in the "hood" below.....also done this way to help maintain an area of low pressure under the car as they had problems because of achieving lift-off on the Mulsanne straight at LeMans. The shape/style of that opening can assist as well - frequently people will use NACA ducts to vent in this area. Check out Chenran's (I think I spelled it right) LS swapped 944 Porsche on this site, IIRC.
BTW, I'm not sure anyone "advised" you to vent the hood, but you seem hell-bent on it. I'd allow air that's passed over the radiator to pass out of the compartment under the car the way God intended. If that poses battery heat issues, and I don't think they'll be significant, then I'd beef up the battery cooling system that I believe the car has.
Old Apr 17, 2021 | 10:50 AM
  #69
Lots of guys in the Pro-Touring world vent their hood to help aid under hood temps. I’ve considered it myself, but my underhood structure is too complex and there’s no good place to locate the vents. What I see is guys placing the vents outward toward the wheel wells, and about centered between front of hood and base of windshield. High pressure on hood is at base of windshield in center, so going outward with vents helps pull air out. This is very common practice in the sports car racing world where there are stacks and stacks of coolers located at the front of the vehicle.
Old Apr 17, 2021 | 11:43 AM
  #70
LetsTurboSomething's Avatar
I guess I never considered it before, but on a race car like a pro touring car, do those hood vents let heat and air out or are they letting high pressure cold air through the top of the hood and venting out the bottom of the car? Or are hood vents basically just for letting heat out when the car is moving to slow for actual airflow or idling at a stop so nothing catches on fire? Because the latter was always how I though of them.
And if the car isn't wrecked or broken or anything like that yet, would it not be easier and maybe even cheaper to just sell or trade it for one that is already just RWD from the factory? I'm pretty much thinking that an aftermarket control unit is going to be necessary because from how I understand it you can't mess with a Tesla controller pretty much at all. The things are just locked up tight from Tesla.
Old Apr 17, 2021 | 12:00 PM
  #71
When the car’s not moving, convection will allow hot air to vent through hood openings wherever they are. Once at speed there’s a pressure gradient at work. The closer to the windshield and the closer to the center of the car, the higher the pressure. The leading edge of the hood is also higher pressure, higher at center, not as high at sides. Pressure drops as air flows over the hood until you begin to approach windshield/cowl area. Each car has a unique gradient.
Old Apr 17, 2021 | 01:39 PM
  #72
Note location of vents
Old Apr 18, 2021 | 12:53 PM
  #73
Note vent location
Old Apr 18, 2021 | 01:28 PM
  #74
Of the vents shown above, are either strictly cosmetic? Or do they both work?
Old Apr 18, 2021 | 02:44 PM
  #75
Both functional - took the pic of the Camaro this morning; the Aston is the V12; takes up more space than the V8 and has more thermal load to shed; hood vents needed to help manage that.
Old Apr 18, 2021 | 08:02 PM
  #76
Thanx! Very good points, and well thought out. I appreciate it. The battery cooling system is very robust for fast charging, so your probably right. So any thoughts for making sure air flows to the underside of the car properly at different speeds?
Old Apr 18, 2021 | 08:19 PM
  #77
I'd focus on getting air to flow properly across the radiator and any other necessary heat exchangers. Being sure the front is sealed up so all air flows across the exchangers; being sure the opening for these is in a high pressure area and has a sufficiently sized opening; being sure that condenser and other exchangers are sealed up to the radiator so the cooling fans are pulling all air across the exchangers; being sure the fans are shrouded properly; be sure there's some sort of splash guard or air dam below/behind the bottom of the radiator so that a low pressure area is created which helps air to flow across the exchangers. Otherwise, the bottom of the engine compartment is open -- and pressure under the car should be lower than pressure at the front of the car = air flows across the exchangers and out the bottom of the engine compartment. Take a good look at the front/underside of any IC engine in a contemporary car -- it'll tell you all you need to know about how to get air to flow across the exchangers and out the bottom of the compartment. If you decide you need to vent the hood for better low speed/idling performance -- you know where to put the vents. And give some thought to how water is going to behave with those vents if you use them -- generally speaking you don't want water repeatedly/consistently dumping onto the engine and electrical components (alt, wiring/plugs, etc.).
Old Apr 18, 2021 | 08:38 PM
  #78
The more I think about it the more I'm liking venting under the car. In addition to a robust cooling system theres about 3/4 of an inch of aluminum plating under the battery to avoid impacts. I think that should insulate and dissipate heat well. The older teslas have a large nose cone that I will convert to a grill. That should provide plenty of air flow. The Tesla systems will operate independently, though might have to work harder from the extra heat
Old Apr 18, 2021 | 08:42 PM
  #79
Yes, I figure since LSs are so commonly swapped, I can easily find whatever I need to get out running. I'm considering s RWD version. P85 would be fun.
  #80
