View Poll Results: Are you interested in swapping the ZF8HP transmission?
Yes, I am interested!
136
83.95%
I am unsure.
16
9.88%
I have no idea what you're talking about.
10
6.17%
Voters: 162. You may not vote on this poll
ZF8HP Transmission swap
I wasn’t sure if there was a good Motorsport vendor that had good prices. Does the Max. ECU offer the same options/features as turbolamic?
Which ecu does street people normally get if they want to run a 8HP? Not sure if they all can or not.
thanks,
thanks,
Andrew
Are there any capabilities that are missing for a street cruiser? For me, the appeal of the MaxxECU is that I both gain 8HP control and multiport injection with one purchase.
The biggest issue that I see with using MaxxECU is the lack of modestly priced wiring harnesses. I consider myself better than average with car and EFI wiring, but making a dedicated harness from a universal harness is a pretty daunting task, even for me. I can't imagine the average LS swapper having the desire to do that.
Andrew
They are also a MaxxEcu dealer.
Originally Posted by MuhThugga;[url=tel:20607066
20607066[/url]]Are there any capabilities that are missing for a street cruiser? For me, the appeal of the MaxxECU is that I both gain 8HP control and multiport injection with one purchase.
But after reading Andrew’s comments above I see it may be pretty involved over some other options. Either way I’ll be watching 8hp projects closely!
Have a 4th gen WS6 with a built TH400 I’m planning to go single front mount, really intrigued by the 8spd development and that would be freaking awesome to do.
So after reading the whole thread and the recommended trans is the 8HP70 from a 5.7L(Higher-Stall) 2015-2023 Charger/Challenger.
2015-2023 is covering 2nd, 3rd, and 4th generations of these transmissions.
Then there is the number of pins in the connector on the later ones....
Is there a consensus on which is the OPTIMUM year trans to look for?
Is there a consensus on which is the opium year trans to look for?
Andrew
Generations refers to the model years manufactured - ?
Although the later generations past 2010 are 8HP75 & 76's
2008: Pilot Series
2010: 1st Generation
2014: 2nd Generation
2018: 3rd Generation
2022: 4th Generation
2008: Pilot Series
Andrew
Is there a concise break down of TurboLamik vs Max ECU capability? As I understand Maxx ecu flashes firmware while TurboLamik solders a board to bypass this entirely. Just curious the limitations of the firmware flash compared to the turbolamik solution.
