How The Hell Do You Pre Lube An LS1?
Old Nov 13, 2004 | 08:18 PM
LS1GMCTruck's Avatar
Default How The Hell Do You Pre Lube An LS1?
Before starting an LS1 that has'nt run in a couple years...What's the best procedure? Thanks in advance. Gar
Old Nov 13, 2004 | 08:45 PM
Keith's Avatar
Pull the plugs, unplug the coil harnesses, crank it over until it develops oil pressure. I would stick some WD-40 or equivalent in the cylinders first, though. Maybe even some Marvel mystery oil.
Old Nov 14, 2004 | 11:41 AM
John B's Avatar
Moderator
ABSOLUTELY DO NOT DO THIS!!! Disconnect either your oil pressure sending unit or the fitting directly above the oil filter and plug in an oil pressure pre-lube pressure tank. This will pre-prime the motor and ensure oil is all the way through the motor including through the pushrods up to the rockers. You can rent one for $20 or less at any quality motor rebuild place.
Old Nov 14, 2004 | 11:54 AM
Default So...This also introduces a fresh oil supply?...
Or does the pressure tank simply circulate the fresh oil that is already in your oil pan & filter? Thanks, Gar
Old Nov 14, 2004 | 10:26 PM
Keith's Avatar
I sure wish I would have known about this earlier. I hope that engine is ok.
Old Nov 14, 2004 | 10:29 PM
onehardmaro's Avatar
Just start it up; it will be fine. Let it do a complete warm up before driving or revving.
Old Nov 14, 2004 | 11:15 PM
John B's Avatar
Moderator
If it fired right up then you have absolutely nothing to worry about if the bearings and stuff were pre-lubed at installation.
You add your choice of oil to the pressure tank because this is the source.
Old Nov 14, 2004 | 11:27 PM
C4VetteLS1's Avatar
Most people just unplug the coil harnesses and crank it over. It doesnt work as well as priming it with a pressure tank but its hugely common and wont be a problem
Old Nov 15, 2004 | 10:43 AM
Oscar Will's Avatar
I made a simple fitting to connect at the oil pressure switch and use a manual pump (normally used to service boat lower units) to pump several quarts of oil while rotating the crankshaft every half-quart. When I first fired my newly blueprinted engine I had immediate oil pressure, no lifter rattle (no air) and I'm certain the bearings will last much longer. I guess this sort of thing depends on how much time you want to spend.
Old Mar 9, 2013 | 05:08 PM
Forcefed86's Avatar
I know this thread is ancient, but it was the first one that popped up on google. When I looked up how to prime an LS1.
I just thought I'd add I built a pressure tank and tried using the fitting above the oil filter. Pumped a good quart of fluid into the motor at 40psi and It didn't register any oil pressure on the gauge (mechanical gauge). Also had the valve cover off and no oil was coming up through the rockers. I don't think the lower fitting will work.
Old Mar 10, 2013 | 07:42 AM
Pop N Wood's Avatar
Opinions vary, but I followed the tech procedure GM publishes in the installation guides for their crate motors. This one is for an LS3, but they all say basically the same thing, i.e. pull the plugs, disable the fuel and crank it over 10 seconds at a time until you register oil pressure. The only thing I would add is to pull the filter and make sure it is full before starting this.
http://paceperformance.com/files/pdf/LS376-515.pdf
You can build some type of preluber, but from what I have seen you will drain the oil passages again anyway when you go to disconnect it prior to starting.
Old Mar 10, 2013 | 11:35 AM
Forcefed86's Avatar
Thanks for the reply.
What you say may be true of the LS1 type pumps. The older SBC gear pumps wouldn't prime properly unless prelubed. I was just worried the pump wouldn't have enough suction unlubricated to prime the initial start. I did try to fill the pump itself with alot of oil and I have some heavy assembly lube on most of the rotating assy, valves etc. I'm sure it will be fine. I just wanted to post this because I couldn't get the pre-luber to register oil pressure when using the fitting above the oil filter. There is a main galley access point behind the alternator on the block that I'm sure would work.
Old Mar 10, 2013 | 07:43 PM
KY Nova's Avatar
You could add a ballvalve to the pre-luber. Just a thought.
Old Mar 10, 2013 | 09:02 PM
gMAG's Avatar
Good name there, "KY".
I pulled fuses for fuel & spark, packed the oil pump with vaseline, then cranked. Pressure came up, in 3 cranks of 8 seconds each.
This worked faster than not packing the oilpump.
Old Mar 10, 2013 | 09:13 PM
Gray86hatch's Avatar
Cranking the engine without the crank throwing oil on the cyl walls is just asking for problems.
Cranking it for 30 seconds is enough to wipe the walls clean.
Pressure lube it. Start it to get the oil moving thru it like it would if it was running.
I have $45 into my pre oiler
Tim
Old Mar 10, 2013 | 10:59 PM
Forcefed86's Avatar
$45! Check this shade tree rig out!
2 liter coke bottle,
1 air fitting
1 barb and some hose & clamps.
All junk I had laying around the shop.
Regulate the shop air to 30-40psi and open the ball valve. I put about a liter of oil in this way. But as said above no oil coming out the valvetrain. I think I'd have to plumb it to the sending unit which is a bastard to get to, or the oil galley plug behind the alternator.
Old Mar 10, 2013 | 11:59 PM
rathersmart's Avatar
good advice!
Old Mar 11, 2013 | 12:11 AM
topbrent's Avatar
Build your own pre-oiling rig out of an old sbc oil pump and a bucket.
http://www.carcraft.com/techarticles...e_luber_build/
Old Mar 11, 2013 | 12:21 AM
gMAG's Avatar
Tim
I see what you're saying Tim, but I'd rather turn it at cranking speed, than find out there was no pressure after running at 1100 rpm.
Old Mar 11, 2013 | 01:17 AM
TURBO BUICK's Avatar
Default Pre Luber
I did exactly what that Car Craft article did and it works great. The only thing that I did was go to Home Depot and get a 2 1/2 gal bucket. With the AN fittings, 2 1/2 gal bucket etc. I doubt if I have $50 into the cost. The plus side is that you can use it on other engines and even other makes IF you have the proper fittings. Of course I already had an old small block oil pump. All it takes is a little bit of time. Rich
