Conversion folks please list your conversion in here
Old Dec 20, 2005 | 11:31 AM
  #401
woody69's Avatar
Default conversion
1968 Impala SS convertible stock 6.0 with 4l80 04 corvette disc front rear and Nordskog gauge panel. I am looking at puting a ls6 intake and cam in> Does anyone know if this should make more power. Thanks. Woody
Old Dec 21, 2005 | 12:01 PM
  #402
El Camero's Avatar
Default '83 El Camino
This is a great site and forum. I currently have a '83 El Camino with a 3.8L 350 Turbo and I've just bought a 2000 Camero LS1 w/4L60E to install. I think this should make for a pretty sweet ride after everything is complete.
Old Dec 29, 2005 | 03:10 AM
  #403
TexasZ06's Avatar
1997 Chevy Silverado
2004 LS6, ATI Procharger, 4L80E
Old Dec 31, 2005 | 01:27 PM
  #404
sonnysteel's Avatar
Default 99 LS1/T56 in 57 Chevy
1999 LS1 - GMPP CNC ported LS6 heads, Patriot Cam, LS6 intake
1957 2 door hardtop
Suspension: C4 Corvette
Old Jan 1, 2006 | 05:19 PM
  #405
red jet's Avatar
1993 Ford Mustang notchback
LS-1/A4 twin t48mm garrett turbos
Old Jan 3, 2006 | 06:06 PM
  #406
LS1MCSS's Avatar
1984 Monte Carlo SS
2000 LS1/T56
A work in progress that should be running in a couple of weeks
Old Jan 3, 2006 | 07:32 PM
  #407
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
'86 Chevy Silverado w/ a 5.3L/4L60E powertrain bolted in:
Now if I can just get a pinout or schematic of the underhood electrical center & harness pinouts, I'd be all set.
Old Jan 7, 2006 | 02:30 PM
  #408
Mke Vee's Avatar
Default 4.8 LR4 in s10 Chassis under '46 Chev Panel Truck
Vette C5 motor mounts are great generic mounts! It's cold in Cleveland, so progress in slow at the moment. I'm trying to complete this project on the "super-cheap". I'm at $3,000 including the purchase of the subject vehicle, donor (frame) vehicle, and crate engine. That was supposed to be the entire budget at one time. Not goin to happen! Thank God for sawzalls, welders and ebay!
I'm running the engine with an old EM-Tec3 and a jury-rigged crank trigger wheel. My current problem is finding exactly what is needed to connect a 1991 vintage 700R4 torque-converter (from a 2wd s10 4.3) to the 4.8 LR4 flexplate. All but one of the trans-to-engine bolts look right, but the flexplate/converter issue has me concerned. I was told that the crank on the LSx family has a larger diameter pilot hole for the center hub of the converter to go into. That makes me think that a later 4L60E convertor might work, if it is the same at the front-pump side. I really don't know at this point. One place told me it was $300 for a "kit", another guy told me to elongate the converter bolt-holes in the flywheel a teeny bit and simply bolt it all together. Has anyone put an older auto trans on a Lsx family engine? Any insight would be greatly aprreciated compmikey-AT-aol.com - Cheers, MV
Old Jan 7, 2006 | 07:50 PM
  #409
Tydriver's Avatar
I dont need any of these parts I have shown below, if you are interested let me know, I hope this information helps !!!
Here you go LS1/Gen3 to 700r4 Flywheel..
Wanna buy it ?? I am not going to need it. I am going LS1 and 4L80e.
This flywheel allows conversion from the Gen 3 crankshaft to a 700r4. It also has correct hole spacing for a 700r4 application with 298mm torque converter bolt spacing (LS1's require 300mm spacing). GM Part# 12551367
Also, consider the following parts that you will need for going with a GEN3/700r4 combo:
BowTie Overdrives TV Cable for the downshifts when you stomp the gas :
Lokar Throtte Cable for the LS1 TB to Pedal: (Lokar Part# TC-1000LS1)
.......and the GM part for the throttle pedal to TB connection:
(GM Part #12565559)
Even if you dont buy the new flywheel or Lokar TV cable from me, I'd STRONGLY recommend this book for your conversion :
The Book is a mandatory MUST HAVE for LS1/6 swap. It has ECM Pin outs, dimensions, part numbers etc. All sortsa goodies inside. (GM PART #88959384)
I hope this infromation helps ease your issues. I try to share this information where/when I can.. Good luck with your swap. I have more pictures and alot more information on my website in the gallery.
Old Jan 13, 2006 | 01:02 AM
  #410
homegrown TA's Avatar
96' firebird was V6 auto
swapped 98' Ls-1 M6
Old Jan 14, 2006 | 08:10 AM
  #411
zamika0a's Avatar
1981 Corvette
Richmond 5-speed
Old Jan 15, 2006 | 02:56 AM
  #412
red92rsls1's Avatar
1992 camaro, LS1 & turbo 350 trans
Old Jan 15, 2006 | 09:59 PM
  #413
blackrose90's Avatar
1971 Chevelle Malibu
99 LS1 ,4l60e
Picked up the engine and trans yesterday, made the adaptor plates and its in the frame today.
Old Jan 17, 2006 | 01:22 PM
  #414
Flashman's Avatar
1993 Ford Mustang (notchback)
LS1/T56
Just getting started!
Old Jan 25, 2006 | 01:24 PM
  #415
Brains's Avatar
I suppose I should list mine!
1987 Mustang notch
LS1/4L60e, almost finished!
http://www.ls1mustang.com
Old Jan 27, 2006 | 07:11 PM
  #416
Stu Cool's Avatar
I just realized I never listed mine here. 1953 Studebaker Starlight Coupe, 2000 TransAm LS1 as listed in my sig. Progress shown in the link
Pat
Old Jan 28, 2006 | 01:35 AM
  #417
liljojoe13's Avatar
Default need help with 1997 silverado 4.3 to 5.3 swap
Please list:
1) Vehicle receiving the swap
2) Your new combo, LS1; A4 or M6, etc.
3) Link to pics if you have any
We can create a list and link it to the top of this forum as a guide.
I wanted to thank everyone who has gotten the word out about this particular forum, I wasn't sure if it would have an audience but it appears that there is one.
Bonus points if you have info or pics of that 59 Cadillac converstion with the turbocharged LS1 from New Jersey!!!!
i have a 1997 silverado and im putting in a 2002 5.3. i have the computer,wire harness,and under the hood fusebox. i hooked up all the connectors to the engine and trans. the only thing i have left to plug in is a plug with 4 wires on it ,it has 2 red,1pink and 1 blk/wht. can someone tell me where that plug goes.also where do i hook up my ignition wires and 12v wires from my ignition go to.i need all the help i can get
thank you
Old Feb 1, 2006 | 09:11 PM
  #418
Leadfoot381's Avatar
1989 Iroc - LS1 from a 97 Vette with built 700R4 trans
- speartech harness, JBA Shorty Headers, Custom y-pipe with no cats, corsa exhaust, Fast 78mm manifold, BBk 80mm throttle body, SLP MAF, O2 sims
- If you would like pics email me at Leadfoot381@cs.com and i will happy to send some to ya
Old Feb 7, 2006 | 08:00 PM
  #419
ZipZ28's Avatar
Pat
I'm sitting here, looking through the journals on there and ran across yours. As I was sitting here reading through yours I was thinking,, 53 Studebaker Starlight Coupe,,,, hmmm I know that sounds familiar
Beautiful car!!
Old Feb 8, 2006 | 12:01 AM
  #420
Luis Duran's Avatar
Default 1968 C 10 short bed
almost finish, 68- c 10 short bed ls1 from a 1999. camaro automatic.
