Conversion folks please list your conversion in here
Old Oct 4, 2013 | 05:30 PM
  #1401
cobalt964's Avatar
Porsche 911 modded ls3 g5052 trans, supercar killer!!!
and if the ls3 isn't fast enough, I have a ls7!!!
Old Oct 7, 2013 | 05:10 PM
  #1402
Project Daily 57's Avatar
Default 1957 Chevy Pick up with Transam subframe-LS1 Baby!
1957 Chevy 3100 Short bed Pickup
2005 5.3 LM7 / 4L60E 79K miles
81 Trans-Am Subframe
'02 Blazer 4WD rear axle 3:42 gears
Old Oct 10, 2013 | 08:44 AM
  #1403
5.3Notch's Avatar
1990 mustang notchback, LM7 with LS6 intake, 4L80e and a 3.08 rear axle. Daily driver.
Old Oct 19, 2013 | 12:33 AM
  #1404
Old Drive-ability's Avatar
Default LS1, G-50, Porsche 914, 996 suspension build
I have a lot of work to do !
Old Oct 19, 2013 | 11:42 AM
  #1405
pbiston's Avatar
68 GTO
99 LS1
4l60e
I am about half way done, which usually means about 90% more work
Old Oct 21, 2013 | 05:47 PM
  #1406
gmagno's Avatar
Default 1970 Camaro
1970 Camaro - L99 & 6L80E Swap
__________________
My Project Thread http://www.nastyz28.com/forum/showthread.php?t=237233
Old Oct 21, 2013 | 06:52 PM
  #1407
Project66impala's Avatar
1966 mustang coupe
Ls3
prc 255 Cnc heads
Texas speed 235/239 cam
Holley hi ram
200 -250 shot of nitrous debating puck or direct
4l80e
Old Oct 23, 2013 | 03:32 PM
  #1408
aggie91's Avatar
'82 C-10
2000 LM7 5.3, 4L60e w/Trailblazer Converter
Check out the full build thread here:
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
Old Oct 23, 2013 | 04:31 PM
  #1409
bczee's Avatar
I had my 71' Chevelle LS1 swap in her a while back (post #517), but forgot to list my 71 Nova ! Follow the links in the Sig !
71' Nova
02' LS1 with ***** Thumper Cam, Comp Spring/retainer
4L60E with updgrades (Sun Shell, Z-Pac, etc), ACC 3200 Stall.
8.5" with 3.73:1, 30spline Axle, Eaton Posi.
Hotchkis TVS
LS1 Brakes
Edelbrock Headers
RetroLSx pan, Now marketed by Holley
90% done, Engine fires up.. but need to complete the Brakes, get wheels and Tires finally the Exhaust system.. then she will be back on the Road !
BC
Old Oct 30, 2013 | 08:32 PM
  #1410
Ham92's Avatar
okay so sorry to everyone for this. i am completely new to this site and dont know how to post this is the closest topic to my question that actually has the community in to the conversation.
so i just recently bought a 92 caprice and want to do a swap and all with an lm4 to it and a 6l80e any tips? im not a complete nube to cars but to swaps i am. any help would be great.. thank you
Old Nov 1, 2013 | 11:43 AM
  #1411
Jason454's Avatar
Default 1940 ford coupe 5.3 4l60e
01 Silverado 5.3 in a 1940 ford coupe, air ride, original aged paint when done.
Attached Thumbnails Conversion folks please list your conversion in here-20130310_173308_resized.jpg   Conversion folks please list your conversion in here-20131026_131002_resized.jpg
Old Nov 16, 2013 | 02:28 PM
  #1412
FirstGenThree's Avatar
'87 S10 2wd long bed- '03 L59 back by 200-4r and yes it's still dbw. No ET as it's still a 7.5" open. Good fun daily driver though.
http://s1209.photobucket.com/user/Fi...?sort=6&page=1
Old Nov 17, 2013 | 08:27 AM
  #1413
Tom DeWitt's Avatar
DeWitts offers every model aluminum radiator configured for an LS engine swap. We customize the standard radiator with the correct inlet and outlet size and add high performance Spal electric fans. We even have a connection for the stem line.
Here is a partial list of our stock items but any model can be configured for LS by changing the first digit of the model code to a 6
http://www.dewitts.com/collections/ls-series-upgrades
www.dewitts.com
Old Nov 21, 2013 | 08:17 PM
  #1414
Sburch5887's Avatar
Originally Posted by Sburch5887
67 Firebird, 1st we did an LQ4 6.0 with a T56, using bone-stock junkyard motors the first one lasted about a month, the second did good until we put a magnacharger on it, then when we picked it up from the tuner, found out it had been 2 quarts low on oil, and before we knew we had spun the front main bearing. We got it home and installed the third motor and ended up doing a cam swap on it and sent it back to the tuner guy and it was dynoed at 540hp at the wheels and it still runs strong. Never being satisfied with it, we removed the perfect-running 6.0 and bought a brand-new LSX 454 crate motor to install. This was the first LS7 style engine we had delt with so there was a lot to learn on it... including finding out that the ls7 has a 58 tooth relict or wheel, and the 03-06 harness that we were using on it reads off of a 24 tooth wheel, after buying a little tiny box that costs $250 from lingenfelter to convert it, the car is now running, naturally aspirated (we had to send the supercharger off to California to get the bottom plate changed to fit on the ls7) just got it back from the tuner Friday and WOW what a beast this thing is! I would never believe the torque this engine has! My normal tuner guy was busy so I had someone else do it and he only got 572hp out of it, when the engine alone without bolt-ons is supposed to start at 620hp.. So we are impatiently waiting for the the mangacharger to return! More to come!
I was looking through the forum here and realized that I hadn't updated y'all on the progress of the 67 Firebird with the LSX 454.. it actually has been done since the end of last year, it is a beast, making 650 hp 685 tq, we ended up having to change the harness and computer to a 2010 Camaro that we got from GM Performance, it was a stand alone harness and ready to run computer for $1000, after it was all together it was on to the tuner shop to be tuned and this is the most powerful car I have ever driven, it will break traction at 40-50 mph and spin until you let off of it. In the near future I am going to tear out the dash and interior harness with some updated stuff I plan on making from scratch, it is going to get some crossfire seats and a fresh console, a custom made steering column with wipers, cruise control and headlight dimmer, leaving the start button on the dash (keyless start keyfob system from digital guard dog) I will try to update everybody futher on the build!
Attached Thumbnails Conversion folks please list your conversion in here-67ta-7-.jpg   Conversion folks please list your conversion in here-67ta-8-.jpg   Conversion folks please list your conversion in here-67ta-2-.jpg   Conversion folks please list your conversion in here-67ta-5-.jpg
Old Nov 26, 2013 | 10:28 AM
  #1415
chevymike396's Avatar
93 Formula LQ4/4L80e .. at this point i have the car running well but not tuned and i cant get it to stop over heating... i had Current Performance customize the truck harness to be stand alone and they did a great job...rear is richmond 4.10s.. ls6 intake.. new MAF new starter new plug wires and ac delco iridium plugs.. 1 3/4 long tubes ..no emissions (EGR ,EVAP) ..new radiator and hoses plus new dual fans... FULL brake line overhaul and replaced the baulky ABS module with a Right Stuff Detailing prop valve... 275/60 ET streets on pro stars rear and low pro Nitto 555s on 17" torque thrust Ms in front... custom driveshaft.. UMI adjustable torque arm...im guessing the car wieghs about 2800-3000 pounds with one seat and no carpet or trim...dyno tune will be in the next week
Old Nov 26, 2013 | 02:11 PM
  #1416
Swapper's Avatar
89 Mustang lx coupe
supercharged 5.3l
https://ls1tech.com/forums/conversio...now-blown.html
Old Dec 1, 2013 | 09:08 AM
  #1417
camarossrulz's Avatar
Default 1981 trans am
1981 trans am with ls1/a4 from a 2000 firebird formula
Old Dec 2, 2013 | 04:42 PM
  #1418
s30's Avatar
s30
1972 Datsun 240z
LM7/Th400
Old Dec 3, 2013 | 10:36 AM
  #1419
Helomedic1171's Avatar
98 K1500
LM7 swap with 4L80E
Old Dec 3, 2013 | 12:31 PM
  #1420
bluewave18's Avatar
89 Fox body Coup
6.0 LS
AJE tubular k member with tube a arms and coils
Strange 10 ways front and rear
4L80E
CC plates
adj. upper and lower rear suspension
full -8 fuel system supplied by Stealth 340 in tank pump with -8 return
Holley mid ram (coming soon)
PRC double springs with new seals and Ti retainers
ARP head bolts
Z06 cam
LS2 timing set
Melling oil pump
Camaro oil pan, dip stick, pick up, and tray
Tq box reinforcement plates for upper and lower
Glow Shift fuel pressure gauge, boost, oil pressure, water temp
Vented PCV catch can
I know there is more I cant even think of right now.
Heads are fixing to go on. I have all of the parts except the intake, drive shaft, tq converter, and trans x member (i will have to fab one).
I plan on using an On3 76mm turbo kit that retains the AC since I live in Houston area. This kit is not available at this time so I'm waiting on it. So far I've replaced the interior and I'm just waiting on a few more parts before the major construction begins. Engine will be ready to go in as soon as I get my intake from the GF for Christmas.
