Conversion folks please list your conversion in here
Old Jun 4, 2013 | 09:00 AM
  #1361
BigEd_72455's Avatar
1993 Chevy S-10 standard cab 2wd
originally 4.3L and 4L60E
going to receive a 5.3L and turbo 400.
trans is bought, trade deal made for 5.3.
bought the LS flywheel extender for the turbo 400.
Watch for it in the projects section in the future.
Old Jun 4, 2013 | 11:25 AM
  #1362
haulass350's Avatar
1997 scsb truck LQ4 + P1sc + 4l80e swap
https://ls1tech.com/forums/conversio...rger-swap.html
Old Jun 7, 2013 | 01:20 PM
  #1363
Anythinggm's Avatar
1972 Buick Skylark
LS1/4L60 conversion, just getting started.
Old Jun 7, 2013 | 02:11 PM
  #1364
Rich L.'s Avatar
'87 Porsche 944
f-body LS1, rebuilt with new rods, cam and valve springs
http://944v8.blogspot.com/
The car's a hoot on track, passing expensive machinery and getting lots of attention.
Rich
Old Jun 13, 2013 | 11:34 AM
  #1365
billymgb1000's Avatar
Default mgb
1974 mgb roadster + 4.8 ls1 with edelbrock 600 no efi and turbo 350
I left the stock rear end with 3.90 gears this thing flys weighs 2200 lbs also flow master 2 and one quarter inch true duals running off headers I get the looks you wouldn't believe .I love this thing
Old Jun 18, 2013 | 09:40 PM
  #1366
4eyes5.3's Avatar
99 BMW 540 with a 5.3 please will be looking for alot of help from everyone thanks .
Old Jun 23, 2013 | 11:12 AM
  #1367
olsparkey25's Avatar
1970 el camino.ls1 engine and brake upgrade from 2001 camaro doner.
Old Jul 3, 2013 | 12:56 PM
  #1368
Bruizer13's Avatar
1987 C4 vette with an LS1/4L60e swap. 11.6 in 1/4 beating a 2014 Mustang 5.0 GT
Old Jul 3, 2013 | 01:04 PM
  #1369
2000SS1979's Avatar
11.6 in the 1/4 mile - YouTube
I've seen that slow *** Mustang around..
Old Jul 8, 2013 | 09:08 PM
  #1370
WileyK's Avatar
93 RX7 with LS1 with 4L60E
Using Hinson Garage subframe
Old Jul 9, 2013 | 04:09 PM
  #1371
Animal 6.0's Avatar
sn95(MUSTANG) conversion 6.0 lq4 block,806 ported,62cc.mill,750carb,224/224114cam,
Old Jul 12, 2013 | 04:48 PM
  #1372
sixty8poncho's Avatar
1968 Pontiac Firebird
Wayne Due Subframe w/C4 Suspension, Mustang II Rack
LS3/4L65E (Connect & Cruise package)
Old Jul 13, 2013 | 03:49 PM
  #1373
rcampin's Avatar
Talking
want to put a 2010 6.0 with a 6L90 trans into my 2001 gmc 2500 hd. it has a 6.0 4L80e currently..what do i need to make this happen? i used to build machines.. so im not intimidated by this.. any clues?
Old Jul 13, 2013 | 10:45 PM
  #1374
Bad Scuba's Avatar
Hey everybody I recently made a trade and ended up with a 99 Tahoe with a 5.7 ltr 350. The truck is really clean but the motor was making noise. I have a 5.3 out of a 03 Tahoe that was wrecked with very low miles on it. I've installed the 5.3 with the whole wiring harness and I fabricated a bracket for the old a/c unit I have everything installed except for the fuse block. The one on the Tahoe is a 32-way F Metri-pack 280 Series and the one on the 5.3 motor is a 68 Way 280 Series BLK. Which I've gottin all that info off this site. But it shows installing just the wires you need for a swap when you don't have everything. My question is does anybody have the schematics for both harnesses so I can hook up everything like factory through the firewall?
Old Jul 13, 2013 | 10:54 PM
  #1375
Bad Scuba's Avatar
Default 5.3 swap
Oh and I have both ECM's for the 99 and the 03. the 99 is still hooked up to the truck but the harness and ECM for the 03 is installed also. I just hooked up everything but the speed sensor on the trans and the fuel pump and everything else is still on the old harness.
Old Jul 14, 2013 | 12:43 AM
  #1376
Exclamation
Bad Scuba, both of your posts are in the wrong forum. This one is to LIST the conversion, not seek tech support. Also, search is your friend on here. You can find out more by searching and reading the posts it lists, than sitting around waiting on someone to respond.
Old Jul 23, 2013 | 09:02 PM
  #1377
Szwed's Avatar
That Z looks awesome Jeromio!
Old Jul 24, 2013 | 06:30 PM
  #1378
m3nd3zls1's Avatar
1975 nova, ls1 with 4l60e
Old Jul 25, 2013 | 01:33 PM
  #1379
PapaD's Avatar
Default 89 Rx7 Covertible
Just starting my build. It will be a long process, but I wanted all the bases covered. Vehicle receiving the LS1 is a 1989 Mazda Rx7 Convertible. Donor car is a 2001 Z28 with T-56 Trans. I plan on using Granny's Speed Shop Conversion kit. Watched it on Power Block TV episode 271. Just pulled out the Rotary engine and trans and pulled the wiring harness out of the bay. Time to clean and prep the bay for a color change.
Attached Thumbnails Conversion folks please list your conversion in here-rx7-pic1.jpg   Conversion folks please list your conversion in here-rx7-pic2.jpg   Conversion folks please list your conversion in here-z28-hood.jpg
Old Jul 25, 2013 | 02:48 PM
  #1380
A-man930's Avatar
1969 IH Travelall
'02 F body LS1 Twin Turbo
4L80e
Build in Progress with pics coming soon!
