Conversion folks please list your conversion in here
Old Apr 14, 2013 | 06:43 PM
  #1341
86Mulletmobile's Avatar
86z28 camaro lq4 swap stock truck intake and efi setup
Old Apr 15, 2013 | 08:52 AM
  #1342
JJMclure's Avatar
89 vauxhall Carlton LQ4 full tube chassis loooong term project 9" braced rear intended box th400
Old Apr 17, 2013 | 09:44 AM
  #1343
65drag's Avatar
Default 1966 C10 4.8/4L60E swap
Currently have a build thread going....
https://ls1tech.com/forums/conversio...ld-thread.html
Old Apr 30, 2013 | 07:05 PM
  #1344
81regal's Avatar
Default future project
1981 Buick regal limited
5.3 swap. maybe future turbo
Old May 1, 2013 | 05:49 PM
  #1345
OEMTim's Avatar
I'm almost done swapping an LS1 into my '86 Porsche 951.
Just figuring out the brakes now.
Old May 5, 2013 | 07:22 PM
  #1346
donnie_19's Avatar
Default LQ9 in C3 1978 Corvette
Installed a 6.0 LQ9 in my 78 vette. Bored .30 over, with 590 lift cam. LS6 Intake, cable Throttle Body, 42 lb injectors, 255 lph fuel pump in tank, C5 filter regulator 58 psi. 2004R transmission with Bowtie TV cable and LS Kit, B&M quicksilver shifter, Holley Accessory brackets for A/C, PS and Alt brackets. Holley EFI and Cables, Vintage Air, Fiero Seats by Mr. Mikes, Jeep Steering Box conversion. Aluminum Radiator with Z28 dual electric fans, Replaced all 8 body mounts. New Shocks, new front end bushings, upper and lower ball joints. Stock 308 rear gears, Dakota Digital Gauges.
Attached Thumbnails Conversion folks please list your conversion in here-corvette-lsx-installed-harness.jpg   Conversion folks please list your conversion in here-corvette-ls-engine-installing-78.jpg   Conversion folks please list your conversion in here-dakota-digital-ecu.jpg   Conversion folks please list your conversion in here-corvette-feiro-seats-2.jpg   Conversion folks please list your conversion in here-corvette-lsx-engine-bay-3.jpg
Old May 5, 2013 | 08:59 PM
  #1347
southerntidefan's Avatar
87 wrangler
Was told it was a 5.3 out of 04 suburban. All indications lead to 02
Old May 6, 2013 | 06:38 AM
  #1348
mjollnir's Avatar
Originally Posted by donnie_19
Installed a 6.0 LQ9 in my 78 vette. Bored .30 over, with 590 lift cam. LS6 Intake, cable Throttle Body, 42 lb injectors, 255 lph fuel pump in tank, C5 filter regulator 58 psi. 2004R transmission with Bowtie TV cable and LS Kit, B&M quicksilver shifter, Holley Accessory brackets for A/C, PS and Alt brackets. Holley EFI and Cables, Vintage Air, Fiero Seats by Mr. Mikes, Jeep Steering Box conversion. Aluminum Radiator with Z28 dual electric fans, Replaced all 8 body mounts. New Shocks, new front end bushings, upper and lower ball joints. Currently using stock 308 rear gears.
do you have a forum thread of the swap?
Old May 9, 2013 | 03:41 PM
  #1349
73LScamaro's Avatar
Default 73 Camaro LQ4
Converting to a 6.0 LQ4 with comp cams 281LR HR13 cam, 4L60E, new tank and global west suspension. Just seems that ever time I turn a corner, I run into something not working together. I am wanting a simple swap, but found out certain engine plates do not work with certain headers. Has anyone completed this conversion WITHOUT Edelbrock stuff?
Old May 11, 2013 | 08:55 PM
  #1350
donnie_19's Avatar
swap ls in 78 corvette
Old May 12, 2013 | 08:36 PM
  #1351
ls1silverado4754's Avatar
Default 01 silverado 5.7l ls1 built 4l60e need help
new swap no spark do i have to flash my ecm
Old May 13, 2013 | 08:54 AM
  #1352
1096s's Avatar
2009 LY6 / 6L90E.
1980 Holden WB one tonner.
Yes, I'm in Australia.
http://s721.photobucket.com/user/109...87104592017283
Cheers,
Sean.
Old May 13, 2013 | 05:46 PM
  #1353
rwb's Avatar
rwb
"new swap no spark do i have to flash my ecm"
Did you have the vats shut off??
Old May 15, 2013 | 05:45 PM
  #1354
ToySnakePMC's Avatar
Default 1994 Miata - LS2 T56 Ford 8.8 Diff
Not that this car is anywhere near finished, I thought I would throw this link out there for anyone who is studying or evaluating a possible Mazda Miata swap. This is V8Roadsters' kit with lots of Flyin Miata options for a hopefully clean appearance and well-engineered performance. Cheers!
http://www.v8miata.net/build-threads...-carolina-794/
Old May 20, 2013 | 09:18 PM
  #1355
78QuickSilverTruck's Avatar
i have my 78 chevrolet C10 silverado, LM7 5.3 swap. its 01 engine i got for 250 without trans, i have gotten a free 4L80E since my buddy couldnt use it in his nova, plus i helped him pull his 5.7 liter vortec from an 01 GMC 2500 HD conversion van.
Old May 21, 2013 | 01:45 AM
  #1356
Ian Johnston's Avatar
That link doesnt go to your truck. Wouldnt mind having a look at the build thanks.
Old May 23, 2013 | 10:18 PM
  #1357
awinquist's Avatar
1967 Camaro
Carburated LS2 with a Super T10 4 speed
Old May 25, 2013 | 02:17 PM
  #1358
oduck's Avatar
Default 2003 chevrolet express 2500 6l80e/6l90e conversion
I have a 2003 Chevrolet Express 2500 Passenger Van that I would like to convert from 4L80E transmission to a six speed trans. Which would be best ,6L80E or 6L90E? What is the difference between them? I had also thought about changing out the old 6 liter for a fresh LS3. Now don't anybody laugh, but I have thought about one of the 480-525hp LS3's. Would the 6L80E/6L90E transmission be up to it? I pull a 25ft travel trailer as well as a 20ft Wells Cargo Auto carrier from time to time.
Old May 29, 2013 | 08:57 AM
  #1359
rageahol's Avatar
Howdy,
Vehicle: 68 Camaro RS Convertible, 327, 4-speed
Donor: 04 GTO LS1 6 speed
Build Link:
https://ls1tech.com/forums/conversio...-progress.html
Old May 30, 2013 | 11:48 PM
  #1360
mjones2004a's Avatar
https://ls1tech.com/forums/conversio...-chevelle.html
1967 Chevelle
2001 LQ4 and Th400 swap
