Conversion folks please list your conversion in here
Old Dec 11, 2013 | 09:27 AM
  #1421
Da-bigguy's Avatar
1971 Camaro
LS7 crate engine with 4L80e
No pics of the engine in the car as it hasn't happened yet but I do have the car and I do have the engine!
Old Dec 14, 2013 | 02:39 PM
  #1422
mattcrp1's Avatar
Default 1976 SWB chevy truck
Here is my conversion, 4.8l 4l60e all stock into my truck. Just dropped the engine/trans in it and scored on a set of trail blazer manifolds.
Attached Thumbnails Conversion folks please list your conversion in here-truck1.jpg
Old Dec 15, 2013 | 07:59 PM
  #1423
Indianadroprop's Avatar
63 impala, 2004 5.3 and 4l65e. Caprice spindle swap, 4 wheel disc, ford 9" rearend. I just finished a frame off 2300 miles ago and just got the lsx itch so I sold the 327 and 700r4
Old Dec 17, 2013 | 11:43 AM
  #1424
charchri4's Avatar
96 Miata with an LS1 from an 02 Camaro SS. I documented the entire process in a short video any builder will enjoy. Sound matters so crank it and click it!
Old Dec 21, 2013 | 04:04 PM
  #1425
Bizzy B's Avatar
Default 80 Firebird jus starting out
These are some pics of my Firebird I just recently acquired.
It has original yellow 301 but I want to swap in a LS1/4l60e. All feedback would be greatly appreciated. The hood, rusted trunk pan and front support is the only bodywork that is damaged but otherwise very good car with start from.
-Tranny suggestions
-Rear End
-Suspension
-Any other useful info.
Thx in advanced
Attached Thumbnails Conversion folks please list your conversion in here-my-cece-pics-059.jpg   Conversion folks please list your conversion in here-my-cece-pics-057.jpg
Old Dec 23, 2013 | 12:34 PM
  #1426
charchri4's Avatar
-Tranny suggestions
-Rear End
-Suspension
Thx in advanced
My best advice to you is spend about a month reading build threads on similar projects and put together a plan. At this point you really don't know what questions to ask but seeing what worked and did not work for other people will reveal much to you.
What is your budget and goal for the car?
Old Dec 24, 2013 | 07:35 PM
  #1427
daveS's Avatar
Default '37 Oze
I just fired up my '37 Ford 3-window - a fiberglass bodied tribute car, built from a roller that I bought from the OZE Rod Shop.
Got the roller on 8-6-13 and worked nearly full time on the car since then. It's got a stock 430hp LS3 "connect and cruise" package from Chevy. The car will be a driver, not a show car and as such, has an inexpensive all GM accessory drive (Cadillac CTS), except for the home-made alternator mount and an Alan Grove AC compressor mount. The alternator relocation required the throttle body to be flipped.
The GM wiring harness had quite a bit of excess length, with the ECM mounted below the dash, on the tunnel, but there wasn't room for the TCM under the dash, so it went in the trunk. I only had to extend 5 wires, about 2' to do that.
Old Dec 25, 2013 | 11:58 PM
  #1428
amfs1950f-1's Avatar
1950 Ford F-1
'01 f-body LS1/T56
http://www.s10forum.com/forum/f213/l...-f-1-a-552842/
Old Dec 27, 2013 | 01:01 PM
  #1429
54 Burb-boy's Avatar
Default 54 GMC Suburban
I am currently heavy into the building of a 1954 GMC Suburban. This will be a rest-o-rod with new running gear. We will be putting a LC9 5.3 L crate engine and 4L80E HD transmission in. Not quite to the point of installing the engine and transmission yet. We are just finishing body work and have completed installation of Heidts IFS & rear suspension. Will keep the group posted as we progress.
Old Dec 27, 2013 | 07:51 PM
  #1430
Root2812's Avatar
Welcome. Its nice to see another AD Chevy on here. I am doing a 5.3 swap into my 1950 half ton.
Old Dec 27, 2013 | 08:23 PM
  #1431
12secondnova's Avatar
1970 nova ss my first car
LS3/L99
6l80e
9 inch rear with split mono leafs, cal-tracs, and double adj. varishocks
I was planning on going N/A with maybe a little shot of nitrous but am now going with twin s366's.
Pics http://s1298.photobucket.com/user/12...?sort=3&page=1
Old Dec 29, 2013 | 09:24 PM
  #1432
miatainthe10s's Avatar
Default Pro touring miata
92 miata
6.0 lq4 l92 heads twin s366 turbo
Gforce 1200 hp dog ring t56 magnum
9 inch rear comp enginering housing
2x3 chassis
Old Jan 11, 2014 | 08:29 AM
  #1433
502ms's Avatar
Default Dirty Dianah | 67/72 Chevy C10
Hello!
I have a 72 Chevy C10 Stepside.
LQ4 Motor, T-56 transmission, 3.73 gears, custom exhaust, headers and intake. Bagged, lays frame and really scoots. Possible turbo candidate this year.
http://dirtydianah.com
Attached Thumbnails Conversion folks please list your conversion in here-image.jpg
Old Jan 13, 2014 | 07:52 AM
  #1434
Scott68B's Avatar
1968 MGB
LS4, Ford V8 T5
Attached Thumbnails Conversion folks please list your conversion in here-ls4inmgb.jpg   Conversion folks please list your conversion in here-ls4boltedin.jpg
Old Jan 26, 2014 | 12:42 PM
  #1435
cartoon14's Avatar
Default In the shop
65 C10 slammed on air 02 Vortec 4L60
71 C10 slammed on air 02 5.3 Vortec 4L60
49 3100 slammed on air 02 5.7 LS1 4L60
66 Cadillac DeVille 02 5.7 LS1 4L60
70 Camaro RS/SS LS3 6spd
48 Cadillac Sedanette 10 LSA (in Process)
84 C10 01 5.3 Vortec 4L60
wiring & tune done in house HPT, in house fabricated engine Mts and crossmembers.
Old Jan 29, 2014 | 04:03 PM
  #1436
PEPS's Avatar
1968 Chevelle will be receiving an LS1 - T56 from a 2004 GTO. I've had this car since I was 16. Had it 40 years now.
Old Jan 30, 2014 | 11:53 AM
  #1437
MrPZProductions's Avatar
1990 Fox body LX Notch- 4.8 Turbo swap with worked 862 heads- BTR turbo cam-going to go with a built Turbo 350 most likely- car is completely gutted currently- work in progress and I just started- plans are for a street car that can run consistent high 9's at the track- going to be using a lot of everyones knowledge through the process for sure!! I'll try to get some pictures up soon- anyone have any experience with EZ Wire in a fox? I took the entire harness/ecu- every wire I could out of it and am going with the EZ wire for fans, headlights, taillights and signals- thanks
Old Feb 6, 2014 | 11:19 AM
  #1438
SuperHatch's Avatar
1994 Infiniti J30
Turbo 5.3L 2004 LM4
300ZX Manual Trans
http://s1287.photobucket.com/user/LO...%20Turbo%20LM4
1993 Nissan 300ZX Convertible
2002 LQ9, Stock w/ LS2 Intake
300ZX Manual Trans
http://s1287.photobucket.com/user/LO...9%20Conversion
Old Feb 9, 2014 | 06:12 PM
  #1439
sowbelle's Avatar
Smile
1971 Chevelle Malibu had a built 355 and TH 350 It is getting a
1998 LS1 with a 6 speed and really a total car makeover
New paint interior brakes rear end the whole nine yards
Old Feb 12, 2014 | 09:33 AM
  #1440
40ChevyCoupe's Avatar
1940 Chevy Coupe with LS1, 4L60E, and rear from a '98 TA and Fatman/Mustang II front end
Lots of work left to be done, plumbing, wiring (TA harness needs to be installed in car), interior, maybe even paint.
