Conversion folks please list your conversion in here
Old Nov 22, 2006 | 07:05 PM
  #521
justin b's Avatar
1984 buick regal
2004 6.0
victor jr. 750 hp holley, asa cam,150 shot of n20,1 3/4 long tubes
powerglide,superstreet fighter converter
8.5 grand national rear,4.10
pics coming
Old Nov 23, 2006 | 09:05 AM
  #522
Classic Restorations's Avatar
Default Update on LS7 swap in 03 Z06 2 bad LS7 GM motors!
Well, I brought my 03 Z06 to a well recommended Corvette specific shop located in Westchester County, NY and was told that the SLP tuning that had been in my PCM for 3 years was sloppy even though I had never had any issues. After this tune that took much too much time and many different excuses since the shop was not equipped with a dyno, I take my Vette back and the engine blows up at Lime Rock on the 2nd lap. Teardown of the motor reveals #7 piston leaned out and detonated sending its shrapnel throughout the motor and taking #2 with it. The #7 cylinder wall has a 2" crack in it. Diagnosis on the PCM reveals bad timing and fuel curves causing the issues. After much thought, I decided to purchase the much vaunted LS7 Corvette Z06 motor.
I purchased the LS7, the oil reservoir and the lines. Upon receipt of the motor, the crankshaft was removed to change the reluctor wheel so my 03 PCM could function. When we disassembled the motor, we found the main bearings to be full of dirt and badly scored along with 2 rods. After many phone calls to GM Performance, an offer was made to rebuild this "new" crate engine. I declined the offer and requested a replacement motor. After 2 weeks, I received the replacement LS7 and upon removal of the crankshaft, we found the same problems, except worse. I have pictures placed on my website under Current Projects and 2003 Z06 LS7 conversion.
I am at the point where I do not want to put any LS7 in my car as this seems to be a major problem. There has been a lot of hype with these motors about the expensive facilities, hand assembly and hand signed along with individual 20 minute dyno runs to ensure the utmost in quality.
Anyone else had these issues with LS7's or GM Performance crates? It has been suggested to me that GM may be pulling these engines off the Wixom plant line that do not meet production car oil pressure specs and selling them as crate "performance" motors.
__________________
Old Nov 24, 2006 | 12:04 PM
  #523
Rottluver's Avatar
__________________
First off I am really sorry you are having so many problems with your car and motors. Secondly, IF that last part is true........holy hell, look out. Can anyone say consumer fraud & "Class Action Law Suit"?????
Please keep us posted.
Old Nov 29, 2006 | 04:51 PM
  #524
76camaroguy's Avatar
Default 76 camaro / 02 Ls1 swap
HELP ME! I have a great deal on a LS1 from an 02 Camaro SS with work already done and I need to know what all I need to convert my car / engine bay / engine. Headers, motor mounts, adapter to fit turbo 350 tranny, etc. Please let me know!
Brandon
Old Dec 2, 2006 | 09:19 AM
  #525
9sec240's Avatar
Hi everyone.
Ivan from AMS checking in.
Currently in purchasing stages of swap.
89 240sx hatch
98 LS1 A4 out of a Camaro
Old Dec 3, 2006 | 05:33 PM
  #526
rat454's Avatar
1974 Monte Carlo SS, 95 LT1 4l60E full computer stock manifolds, dual exhaust, x over, a/c delete pulley...
Old Dec 4, 2006 | 01:57 PM
  #527
LS1Sportside's Avatar
'95 Sportside Chevrolet
LS1 M6, Mild Cam, Turbo
'00 Astro Van
5.3 A4, Mild Cam
'69 MGB
LS6 M5, Twin Turbo
'99 Camaro
X-3.8, 402 A4
Old Dec 7, 2006 | 09:02 PM
  #528
52ChevyLS1's Avatar
1952 Chevy Truck with an ls1 and 4l60e from a 98 Z28.
Old Dec 9, 2006 | 09:19 AM
  #529
Insulator's Avatar
Default 1978 Porsche 924
1978 Porsche 924 with a GTR body Kit, 2001 LS1 w/LS1edit software and mild engine warm over, 1986 Porsche 944 turbo Suspension, Big Red Brakes all around 12.7"frt 11.2"rear, 1993 Porsche 968 6 speed transaxle.255 40 17 fronts 345 30 18 rears. Should pull 1g and run 11 sec ¼’s
Original plan was a restoration. (HA) Found out no engine parts were available, most Porsche owners are **** orifices, and anyone who has parts thinks there gold plated.
Started researching swaps, 944 and 968 drive train are slam dunk straight forward almost bolt in but very expensive, temperamental turbos. Someone used to do a 4.3 V6 that was poorly conceived and designed. I learned a little from their swaps. Then I discovered an LS1 would be within 100 lbs. front axle weight of a 944 Turbo. Thus began the odyssey.
WHY I‘m doing it? Because everyone said I can’t and that it couldn’t be done.
Completion early 2007
Pics and thread to follow
Old Dec 9, 2006 | 10:36 PM
  #530
GMLSI's Avatar
1978 HZ Holden Premier.
5.7L LS1 with TH350 with 3800rpm converter.
228/230 @112LSA
9" Diff with 3:9 diff gears.
Old pictures of the car can be found here. http://www.cardomain.com/ride/564964
Should have some updated pics on my Cardomain page soon.
Cheers,
Ryan
Old Dec 19, 2006 | 01:35 AM
  #531
Mercer Motorsports's Avatar
Ken Mercer here with Mercer Motorsports . I'm a competitor in the World Extreme Rock Crawling Championship Series (W.E.ROCK ).
I completed an LS2 crate motor swap in my competition rock racing buggy earlier this year. It's a mid engine design where the drive train sits backwards in the rig behind the driver seat. I used an ECU/Harness package from UMI Racing (Delphi 4B ECU and custom harness). Motor was mated to a Hughes Powerglide transmission and Lovell (pneumatic) transfer case and Currie custom 9" / Dana 60 axles with rear steering.
The swap went fine, my only real issue was mixing and matching accessories. Street and Performance provided most of the serpentine components and I had to make my own bracket to mount the steering hydro pump.
Given the nature of our competition series, the rig saw lots of steep (70-80 degree) hill climbs , decents and off camber situations... and a few hard roll overs. I had a few overheating issues and also started to see low oil pressure on occasion.... well you can probably guess what happened.... with about 10 hours on the motor (BOOM) or more like TAP TAP TAP TAP TAP TAP......
The tear down revealed several spun rod bearings due to oil starvation... all the bearings had some amount of galling and damage. I had just put an oil accumulator on the motor when it went, but obviously too late as the damage had been done early on.
So, lots of lessons learned about the importance of good fuel, tuning, cooling and oil pressure as all of these areas contributed to the demise of my brand new LS2 Corvette motor.
After looking around some at options, I decided to call up Brian at SDPC and order a new forged 402 short block. I now have that motor installed and it's a monster (thanks Brian).... more pics and updates to come.
Also, noticing more and more LSX swaps in Jeeps and other 4X4 and offroad
rigs here.... that's a good thing. If there is any information I can provide or any questions I can help answer based on my swap experiences, I'm happy to
do so. Oh, BTW... I'm rebuilding that old LS2 block (another forged 402 stroker) and it's going in my 1984 Jeep CJ8 project..... pics coming of that project soon as well.
SDPC 402 in a 2200 lb buggy GET SOME!!!!!
Old Dec 25, 2006 | 02:00 PM
  #532
69MyWay's Avatar
Please list:
1) Vehicle receiving the swap
2) Your new combo, LS1; A4 or M6, etc.
3) Link to pics if you have any
We can create a list and link it to the top of this forum as a guide.
I wanted to thank everyone who has gotten the word out about this particular forum, I wasn't sure if it would have an audience but it appears that there is one.
Bonus points if you have info or pics of that 59 Cadillac converstion with the turbocharged LS1 from New Jersey!!!!
1. 1985 Corvette
2. LS1 from a 98 Vette, 00 heads, 4L60E
3. http://mcspeed.homestead.com/LSXC4.html
Old Dec 26, 2006 | 12:24 PM
  #533
93zMan's Avatar
2000 V6 camaro.............swaped 99 transam LS1.
Old Dec 26, 2006 | 04:09 PM
  #534
YJ LS1's Avatar
Default 5.3LM7 in Jeep Wrangler
'87 Jeep Wrangler with 5.3L LM7, 700R4, Atlas II Transfer Case.
LS1performanceparts and Steve Hilton supplied the LM7 and the wiring harness and computer. Harness and computer are real Hack Jobs. Harness was missing connectors, TPS, and one other that I've forgotten about as it was Feb 06. Computer was supposed to have been setup for 2-O2 sensors, but harness shipped with 4 connectors. Computer is throwing security codes...VATS was supposed to be removed. NO communication with Steve since June this year....he will not return phone calls or email. I saw some of the stuff that was said about him here. It all rings true in my opinion.
Don't buy from him, he charges top dollar and offers poor quality and satisfaction. I need to find a tuner to take care of the computer problems...it won't run more than 5 seconds then injectors get shut off by security.
Here's a link to my project....
http://parksrinehart.com/Gallery/5-3L-LS1-Chevy-Buildup
Old Jan 1, 2007 | 08:38 AM
  #535
hotrod51's Avatar
Default Conversion
'04 6.0/4L80E into '49 Chevy PU. Modified stock harness, cam/ heads. Top chopped,C4 suspension.........Darwin
Old Jan 1, 2007 | 08:43 AM
  #536
hotrod51's Avatar
Default 6.0 into 49 Chevy PU
'04 6.0/4L80E with modified stock harness.Cam swap/ ported heads/Z06 exhaust manifolds. Chopped top, louvered hood C4 Corvette suspension.........
Old Jan 3, 2007 | 10:57 PM
  #537
northcoastrides's Avatar
'00 Astro Van
5.3 A4, Mild Cam
'69 MGB
LS6 M5, Twin Turbo
'99 Camaro
X-3.8, 402 A4
Hey LS1sportside how did the Astro van swap go I'm working on a 5.3 S10 but I'm allready planning my next swap an awd LS1 astro and looking for any info
Old Jan 4, 2007 | 03:37 AM
  #538
petroltherapy's Avatar
northcoastrides - check out this website - lots of members with V8 Astro's/Safari's - I know at least one of them is an LS1 swap:
http://www.astrosafari.com
Old Jan 8, 2007 | 10:02 PM
  #539
Sweet Thanks Bro
Old Jan 13, 2007 | 10:20 PM
  #540
a10beav's Avatar
My '88 Firebird has been getting worked on for 3 months now and I hope to have it done very soon.
LS2 with MTI stealth II cam, Stage 2E ported heads, FAST 90mm intake w/ Nick Williams throttle body, PCM tuned, viper T-56, Moser Ford-9 with 3.50s and tubular k-member/suspension upgrades.
We're just trying to get the engine to run now...
