Conversion folks please list your conversion in here
Old Oct 18, 2011 | 12:34 PM
  #1141
cmwatcds's Avatar
Default 5.8l and old 4l80e
Attachment 321612
I hope this is the right place to post this and I apologize if it is not. I am certain this question has been asked many times. I apologize for asking again but I couldn't find this specific question.
I have a 1991 1 ton chevy pickup with a 350 TBI engine and a 4l80e trany.
I am swapping the 350 TBI for a 2003 5.3l engine. I threw the rod through the oil pan and this is the engine I have.
I had purchased the Speartech wiring harness, the engine relocation kit and the spacer for the 4l80e conversion.
So here is the problem that I am having, I posted some pictures to assist in this question. The flex plate that came with the original engine is a 6 bolt hole flex plate to connect with the heavy duty torque converter. I want to keep the heavy duty torque converter since it is a truck. The original flex plate is the same diameter and the bolt holes align, well except two as to which you can see in the pictures "hopefully". so can i just drill the two holes in the original flex plate and use the spacer to offset the flex plate from the engine? or what is the suggestion here. I really don't want to buy a new torque converter unless there is no other reasonable choice.
Thank you for all the help.
Chris
Old Oct 18, 2011 | 02:59 PM
  #1142
hobbs53's Avatar
Default Help needed..!!
I hope everyone will be patient with me here and not think me sacrilegious here for bringing up the F word......................ford, but i have a '59 F100 in dire need of a good LS platform. Don't know which of the motors I'll find in my price range (loved the article on conversion <$1,500.......); but will need all the suggestions/guidance/help I can get. Really want to find a engine/tranny unit..........anyone with any history with this type project?
I appreciate your patience with me and the..............................F.............
Old Oct 23, 2011 | 12:28 AM
  #1143
VINDON's Avatar
Default 1984 cadillac 2door fleetwood
Our build is a 1984 cadillac 2door fleetwood RWD.42K miles Euro 1992 clip
1998 camaro LS1/4L60E Trans
We were gonna use the LT1 but decided the LS1 is the best choice
We plan to do the 3inch forward and pan replacement to to save the factory A/C bracket and compressor.I noticed no one has posted anything on the 80s' cadillacs and hope this helps....
Old Oct 23, 2011 | 01:11 AM
  #1144
427Nova's Avatar
Default 66 Nova Blown LSX 427
66 Nova
427 c.i.
LSX block
AFR cathedral ports
BDS 8 -71 blower
E.F.I.
Pump gas, 110 or E85
4 speed Jeffco
12 bolt - 3.73 gear
Attached Thumbnails Conversion folks please list your conversion in here-woodward2011novaroncruisin.jpg   Conversion folks please list your conversion in here-woodward2011novaengine.jpg   Conversion folks please list your conversion in here-woodward2011novajeffco.jpg   Conversion folks please list your conversion in here-nova-martin-tech-041.jpg   Conversion folks please list your conversion in here-woodward2011novadrivesidefront.jpg
Old Oct 25, 2011 | 10:02 PM
  #1145
kbktulsa's Avatar
Talking 1987 jeep wrangler
1987 jeep wrangler, 1999 LS 1, 4l60e, 231J transfercase, ford 8.8 rear end, Just started the swap, have the old out and am starting the motormounts and mounting the 8.8 rearend. Making my own wiring harness, ecm flashed by lt1 swap.com. 32x11.5x15 procomp tires. havent decided on which headers will fit yet.
Old Oct 26, 2011 | 07:51 AM
  #1146
Jboggy's Avatar
In progress: 1987 Mazda rx7 turbo II, stock rear end, T-56 trans, 1997 lt1, aluminum heads, headers.
Old Oct 27, 2011 | 11:08 PM
  #1147
lq4gp's Avatar
1987 Pontiac Grand Prix
2004 lq4 Gm performanc parts hot cam, carb intake with a 650 demon, ran through a 4 speed saginaw and 3.73 gears
Attached Thumbnails Conversion folks please list your conversion in here-img_0119.jpg
Old Oct 28, 2011 | 02:28 PM
  #1148
Danny Thomas's Avatar
Default 81 Trans Am
installing an 98 trans am ls1 /4l60e into my 81 TTA. Trying to research all the ins and outs of this swap to keep my stock gauges. Trying to decide to retain stock 15" wheels -snowflakes or up size brakes and do 17" snowflakes..and what fuel system to use--external pump or a in tank setup.
Old Oct 29, 2011 | 08:44 PM
  #1149
jeeptester's Avatar
Default LY2 in 1997 Jeep Wrangler TJ
Installing a LY2 silverado 4.8 in a 2.5 Jeep Wrangler tj 1997
I have it in the frame about to weld mounts.
Build thread
https://ls1tech.com/forums/conversio...8-jeep-tj.html
Old Nov 3, 2011 | 10:25 AM
  #1150
lovnbmws's Avatar
99 BMW e36 323is coupe
Putting in an 02 LS1/T56 using a Vorshlag kit
Build thread: http://forums.bimmerforums.com/forum....php?t=1700197
Old Nov 7, 2011 | 05:50 PM
  #1151
mado1219's Avatar
Default wha do i need for a conversion on 3rd gen carb to fuel injected ls1 of 6.0
I jus wondering wha all I need to do for this conversion and wha tranny is a good one to put in that will fit I was told the turbo 400 help please
Old Nov 20, 2011 | 05:11 PM
  #1152
gotemcoach's Avatar
1980 El camino
98 LS1/A4 3.73 LSD
Old Nov 21, 2011 | 03:09 PM
  #1153
salemetro's Avatar
1996 V6 Firebird...all grown up now with a T76 5.3, 4l80E, 8.8, etc....
2001 Mazda Miata 5.3 L33, T56, 7.5/w TrueTrac....
Old Nov 24, 2011 | 07:56 AM
  #1154
AZSahara's Avatar
1998 Jeep TJ
L92, 6L80, Atlas 3:1 transfercase, Dynatrac HP 60, 4:56 gears, Teraflex LCG Pro triangulated suspension, Genright fuel cell, Ron Davis cooling system and much more.
Attached Thumbnails Conversion folks please list your conversion in here-dsc00156.jpg   Conversion folks please list your conversion in here-dsc00159.jpg   Conversion folks please list your conversion in here-dsc00163.jpg   Conversion folks please list your conversion in here-dsc00164.jpg   Conversion folks please list your conversion in here-319544_10150319237757198_181467227197_8256134_1618679446_n.jpg
Old Nov 27, 2011 | 03:37 PM
  #1155
tmonttt's Avatar
1992 Nissan 240sx
5.3 LM7, T56
Old Nov 27, 2011 | 05:37 PM
  #1156
ecna's Avatar
1955 Buick Century
1999 LS1 / T56
Attached Thumbnails Conversion folks please list your conversion in here-55c.jpg
Old Dec 6, 2011 | 09:02 PM
  #1157
72ssguy's Avatar
1955 studebaker pickup
Lq4 a4
243's
More mods to come...just gettin started.
Old Dec 8, 2011 | 11:27 AM
  #1158
ZexGX's Avatar
Mine was a "typical" F-body 99+ V6 to LS1 swap. Pretty much a bolt-in except for the power wire for INJ 2. I have done a bunch of modifications and cleanup since the swap, this is just to show the swap itself. You can see the current state of this car by clicking on my signature picture. The process was done over the course of 3 days in a friends driveway.
https://ls1tech.com/forums/conversio...ap-w-pics.html
Before:
Immediately after:
Old Dec 10, 2011 | 12:58 AM
  #1159
groveboy's Avatar
84 Caprice
LQ4/4L60E LS6 intake. any more suggestions on what all i will need to make it work?
Old Dec 12, 2011 | 11:24 AM
  #1160
ZexGX's Avatar
Originally Posted by groveboy
84 Caprice
Yeah, get VERY familiar with using the search button. Quotation marks help a bunch, too. Like instead of
fuel pump sending unit
try
"fuel pump" "sending unit"
