Conversion folks please list your conversion in here
Old Apr 18, 2014 | 09:54 AM
  #1461
paytonmack's Avatar
Here is some info on my swap. 1961 Chevy Impala 2 Door sedan
LS1 from 04 GTO
T56 Tranny
Body in primer, frame painted, stock Control arms and rear 4.11, air bags installed, need to mock up engine and tranny with correct engine mounts if anyone can help on what to purchase
Old Apr 18, 2014 | 10:06 AM
  #1462
paytonmack's Avatar
Hey, can you tutor me on how to post some pics of my frame etc.?
Old Apr 18, 2014 | 11:45 AM
  #1463
rquad's Avatar
This is probably not the correct forum to ask that question or answer it, but the answer is quick so I'll give it...
You'll need a place to store your photos online. Photobucket is popular, but there are others. I use photobucket, so here are the instructions for that...
Upload the photos to photobucket
Hover your cursor over the photo - and icon appears in the upper right of the photo
Click the icon and choose Get Links
Copy the *last* link text from photobucket into a posting
That's all, other than maybe learning to navigate around and organize photos in photobucket.
Old May 6, 2014 | 08:52 PM
  #1464
KameTrick's Avatar
I'm in the middle of a swap right now...just finished getting most of the components together and now am focusing on the assembly process.
Car: 1991 Nissan 240SX Fastback
Motor: 2002 Camaro Z28 LS1 & 6Spd
I have a build thread up at: v8 Silvia, might make one here as well to share with LS folks, as I'll need help troubleshooting this and that.
Old May 7, 2014 | 07:12 PM
  #1465
bahdeets's Avatar
Default Project #2
Donor Car; '06 Monte Carlo OEM V6/4T65E FWD
Onto: RWD Morrison Chassis, SC 454 LS9, 4L80E/4L85E & 9" Ford
Old May 11, 2014 | 10:18 PM
  #1466
darin89iroc's Avatar
Default my swap is....
2001 5.3 from a suburban into an 83c10, bone stock 5.3
Old May 14, 2014 | 09:43 AM
  #1467
72bowtieguy's Avatar
72 chevelle with a lq4 and ordering s475 turbo soon
Old May 14, 2014 | 10:07 AM
  #1468
dkiller2135's Avatar
Default Jet Boat
1. 60's fiberglass Jetboat
2. Aluminum 346ci Ls1
Old May 26, 2014 | 04:27 PM
  #1469
raneyck's Avatar
Default 1965 C2 Corvette LS1 & C4 suspension
I am down to a few issues. I don't want to just throw parts at this. I need to know whether a 7" dual diaphragm booster and master cyl (dual disc) will fit here? Also, has anyone tried the C5 radiator in a C2? The dimensions look like they would fit? I plan on using the stock '87 clutch hyd cyl and hook up to the LS7 clutch set up. Also the fuel line, where do I get a long tube to bend with the quick disconnect end on it?
pics here:
https://ls1tech.com/forums/members/r...ion-31188.html
Chuck
Old Jun 8, 2014 | 08:52 AM
  #1470
warrfarr's Avatar
Default Swap info
1)1963 Cadillac Coupe Deville
2)2010 L99 with 6L80e and 9" ford diff.
3)link to pics: https://www.flickr.com/photos/127725...7641678199014/
Thanks!
Old Jun 29, 2014 | 07:35 PM
  #1471
74propu's Avatar
1974 chevy short box truck camaro sub frame square tube back half bed slide up to and welded to cab to make unibody suicide doors and suicide hood rps adjustable upper a arms caddy front spindals with 12 in roters becool 2 tube aluminum radiator 2000 5.3 stock with twin turbo 80 lbs injectors 3 bar map th 400 355 rear gear hummer oil pan self cutdown stand alone wire harness put computer in cab under home made console autometer gauges 15 gal fuel cell between rear wheel tubs 400gph @70 psi electric fule pump with an 10 fuel lines to front of truck astro van tilt column going through the fire wall at 45 deg toward the eng working on ac compressor mounts at this time with a lot of help from the grate gear head up there will start it for the first time by the end of july
Old Jun 30, 2014 | 10:01 AM
  #1472
Mercier's Avatar
Please list:
1) Vehicle receiving the swap
2) Your new combo, LS1; A4 or M6, etc.
3) Link to pics if you have any
We can create a list and link it to the top of this forum as a guide.
I wanted to thank everyone who has gotten the word out about this particular forum, I wasn't sure if it would have an audience but it appears that there is one.
Bonus points if you have info or pics of that 59 Cadillac converstion with the turbocharged LS1 from New Jersey!!!!
85 CJ7
LM7, 862s, stock as far as I can tell. SM465
Old Jul 1, 2014 | 02:17 PM
  #1473
94lightningls's Avatar
Default 94 Ford Lightning
5.3 LM7
4L60 swap in progress
Old Aug 2, 2014 | 10:20 PM
  #1474
kwrench61's Avatar
Default G body swap
Hi,did't know this section was here for a while. Good to know cause I seem to be getting what feels like some cold shoulder out there on the other traditional LS sections. I'm gathering parts to do a 6.0 LQ4 swap into a 81' Malibu 2dr. Landau. So far I have the rolling car with no motor/trans,complete LQ4 with all accy's,harness and computer,TH400 short tailshaft,centerline wheels with new front tires and new MT street drag radials,two racing bucket seats,15gal fuel cell,Hurst 1/4 stick shifter,96mm aluminum intake w/101mm TB and fuel rails. Rear is a 7.5 10 bolt with Auburn posi,4.10 GM gears,Moser axles,C-clip eliminators,aluminum girdle rear cover with studs. fiberglass 2" cowl bolt on hood. next will be cam/lifters, flexplate/torque converter parts, fuel pump/reg,and lines. Plan on leaving block and heads stock with exception of good valve job with good springs. Will be using 100hp shot of spray also. Don't have any pic's on home PC yet but will transfer and post. Need help with oil pan fitment suggestions. Not sure if truck pan will fit. eng is a 2001 LQ4 out of Silv 2500HD(steel block). Thanks......
Old Aug 3, 2014 | 09:36 PM
  #1475
74CHEVC10's Avatar
1974 chevy truck lwb
1999 lm7 5.3, 2002 4l60e, Camaro exhaust manifolds, 2.5 dual exhaust into flowmaster 40s, external walbro 255 with stock tank, CAI
Attached Thumbnails Conversion folks please list your conversion in here-1406422578349.jpg   Conversion folks please list your conversion in here-1406432348782.jpg
Old Aug 5, 2014 | 12:37 PM
  #1476
78mc's Avatar
1978 chevrolet Monte Carlo.
2008 4.8 with 4l60e.
Speed engineering LT headers, 224/228 tsp cam, 3500 ptc stall
Still in the process of swapping
Old Aug 16, 2014 | 05:19 PM
  #1477
JRracing's Avatar
I just picked up this rat rod 59 Chevy Apache. I plan on swapping a fresh 347 alm LS1, 700r4. It will be a carb setup on a dual plane int and MSD 6010 box.
Old Aug 19, 2014 | 07:52 AM
  #1478
LSWRANGLER's Avatar
Swapping out a tired 4.0L and 5 speed AX15 with a GenIII 5.3 L33 and 4L60E. Should almost double the horsepower. Incorporating the GM CAN buss and BCM with Cruise Control and Auto Start.
Last edited by LSWRANGLER; Dec 21, 2014 at 09:08 AM. Reason: Premature pushing of the go button
Old Aug 20, 2014 | 02:48 PM
  #1479
98A4SS's Avatar
1993 Pontiac Firebird Trans-Am
LS1 A4 Almost finished
Old Aug 26, 2014 | 11:26 AM
  #1480
3GTOs's Avatar
vehicle is a '65 Pontiac Lemans Convertible
receiving a '13 5.3 engine/6L80E trans liftout from a Silverado with 11,000 miles.
The original truck intake manifold wouldn't clear the hood so a BBK intake and fuel rails were installed. To eliminate pulley clearance issues a Holley accessory drive was installed. The truck manifolds wouldn't clear on the driver side and couldn't find any F body manifolds locally so Hooker cast iron manifolds were used - perfect fit!
not running yet should be about a month.
