Conversion folks please list your conversion in here
Old Apr 14, 2021 | 09:01 PM
  #1861
Jmill2002's Avatar
Originally Posted by G Atsma
I would find out the circumstances under which it quit running. Might narrow down where to look
the wiring harness was completely taken off. When I made a time to go look it was the day after I messaged him and he said “last night after you messaged me I went outside to try to hook up the harness and get it running for you but ran out of daylight” the story ads up cause sunset was about 30 mins after my message and with what he had done the engine was cranking when he turned the key. Just didn’t start.... should I take the wires off and try to do it myself? I have never had to hook up the harness myself before so treat this as if you are talking to someone who’s never seen a car please lol
Old Apr 14, 2021 | 09:09 PM
  #1862
Get a schematic and see if what is done already is done right.
Old Apr 15, 2021 | 02:39 PM
  #1863
will69camaro's Avatar
Sex On Wheels
1969 Camaro - LSX427 TT w/ T56 Magnum (Holley Dominator)
1969 C10 - LS2/4L80e (Holley Terminator Max)
Old May 31, 2021 | 06:37 PM
  #1864
Ghost23's Avatar
1966 Chevelle
Opinions, links to parts and good deals, advice are all welcomed!
Things to do:
Building 6.0 to replace SBC
TH400 or 4L80E to replace TH350
GM 12 bolt to replace 10 bolt
Disc brakes - hydroboost
Front and rear suspension
Mid frame stiffeners
Wheels and tires
Fuel system
Parts still needed for 6.0 build:
Square port heads
Cam - valve train
Injectors
Fuel system
Turbo manifold - like the FSP manifold
Holley EFI
Oil pump and pan
Engine mounts
Throttle body
Intercooler
Parts I have for 6.0 build:
6.0 iron block
Stock LQ4 crank
LS3 intake, injectors, fuel rails
On order forged pistons and rods
VSR 7875 next gen billet turbo
Turbo Smart 50mm wastegate
I almost want to go twin 7875's. Just not sure. Might see how the single does and possibly go bigger if needed. The 7875 should have no lag and be very torquey. I don't really have a HP number I mind. I'm sure the single is plenty.
Undecided about TH400 or 4L80E. I don't make long trips on interstates. Would like the OD and lockup, but some of the 4L80' are pricey compared to a 400.
Holley EFI. Terminator X? HP? Dominator? If I have the extra money, I'm going dominator. Just depends how quickly I want to get this project done.
Fuel system - Fuel cell, flex fuel, water meth injection.
Old Jul 11, 2021 | 10:52 PM
  #1865
ealvarez11's Avatar
Default C3 lsx
1977 C3 Corvette L82
LS1 with Dorman 901 intake and long tube headers, A4 (4L60e)
306 rwhp @ 6, 052 rpm
295 ft-lb @ 4,871 rpm
Old Jul 12, 2021 | 10:49 AM
  #1866
LSswap's Avatar
1977 Corvette. Mostly Cruiser, Occasional Drag Car.
88mm turbo, no wastegates
6.0 LS1 with forged pistons and rods.
1000cc Injectors, Walbro Hellcat 525LPH Fuel Pump with dual feed fuel rail
Surge tank
Speedmaster intake, F body Oil pan
4L80E, forged input shaft and drum, dual feed direct, 2nd and 3rd accumulator delete
Ford 8.8 with 9" internals and axles on 4 link suspension with dual adjustable shocks.
Volvo Electric power steering
Denso hairpin digital alternator
Volvo brushless digital coolant fan
LED headlights
4" aluminum sidepipe exhaust.
AEM Infinty engine management.
A/C in progess.
DIY Arduino touch screen with Cruise, Sport, Burnout and Drag driving modes. PWM controls for: 4L80E, coolant fan, Intercooler fans, trans cooler fan, oil cooler fan, alternator, surge fuel pump, primary fuel pump, no wastegate boost control.
Old Jul 12, 2021 | 11:22 AM
  #1867
pcguy's Avatar
Here is my latest progress on my 70 Chevelle restomod project -- six years and counting:
Runs and moves around the shop; about to take it to daylight and warm up all the fluids to check for leaks.
Most everything is working; lights, alarm, rear camera/sensors, nav. Having a little trouble with the front window motors; BCM doesn't like them.
Nick
Old Aug 14, 2021 | 09:21 AM
  #1868
PantegoD's Avatar
Default 72’ c10
72’ C10
2003 5.3/4L60 stock
Dual fans
Vintage Air
Dakota Instruments
Will be a daily driver when completed
Old Oct 12, 2021 | 08:46 PM
  #1869
Woody80z28's Avatar
96 Chevy Beretta - FWD to RWD swap with 4.8, 5spd and Ford 8.8
Old Dec 14, 2021 | 10:35 AM
  #1870
Stiloc6's Avatar
1998 BMW M3
LS3 (CPP 376/480)
Thanks,
98 E36 M3 w/LS3 swap
Old Dec 25, 2021 | 03:12 PM
  #1871
Racer-X-'s Avatar
Default Elvis the 1947 DeSoto Custom Sedan
Not sure if I've posted an intro here yet. We have a 1947 DeSoto Custom Sedan with a LS1 and a 4L60E transmission. I'll post some pix up later.
The car's name is Elvis. Elvis lived in Cuba most of his life, and he had the LS1/4L60E installed by a shop in Miami that was really, really good at interior, upholstery and paint.
Old Jan 4, 2022 | 02:35 PM
  #1872
james_drives's Avatar
My build in progress https://ls1tech.com/forums/conversio...-lq4-more.html
1989 Jeep Wrangler
LQ4/4L80e/NP241
2016 Jeep Wrangler chassis
stock-look 4-seasons daily driver build
Old Feb 27, 2022 | 04:48 PM
  #1873
84/89's Avatar
89 RS camaro vert
LS3 (e-rod), 4L65e
Old Mar 2, 2022 | 03:28 PM
  #1874
70DusterDev's Avatar
1970 Plymouth Duster
6.1 Turbo LS, T56 Magnum
Old Mar 22, 2022 | 06:00 PM
  #1875
KenMathisHD's Avatar
1992 GMC K1500
Bored and stroked an L59 out from 5.3l to 6.3l, looking at doing a built 4L80 or 4L65 for it. Going back and forth between changing up the interior or restoring it - we'll see what happens
Old Mar 23, 2022 | 09:31 AM
  #1876
Toes's Avatar
2005 GMC Sierra
6.0 LS3 top end 460/450 crate motor
RPM stage 5 4l60
Old Apr 24, 2022 | 01:31 PM
  #1877
Honestbroker's Avatar
Default 90 Isuzu Pickup
1) 90 Isuzu Pickup
2) 5.3L LS1 (Vortec); 4L60E
3) A few photos, although not as nice as some of these projects.
4) Progress is slow. Pretty much a one man show. Getting closer though.
Last edited by Honestbroker; Apr 27, 2023 at 08:53 AM. Reason: Recording correct year of truck
Old Jun 9, 2022 | 11:15 PM
  #1878
Mikey72D's Avatar
Default 1941 Studebaker champion
1941 Studebaker that I bought in early 1964. Drove it stock for a number of years. Stored for a number of years. Mid 2000 had a fatman mustang II front end installed along with sb chevy engine and st-10 transmission and a Ford rear end. Sat for a while. Then last year I picked up a LM7 with harness and ECU. So that motivated me again. Had to get new parts to adapt the trans to the new engine. So the engine and transmission are now mounted. New parts for the McLeod hydraulic throw out bearing. New bottom for original fuel tank. Finished routing new fuel lines from in tank fuel pump to corvette style fuel filter/regulator and new fuel line forward to near the engine.
Currently the body is off. I need to pull the third member to check the gear ratio. I’m getting ready to make up brake lines to the adapted Cadillac rotors and calipers on the housing. Then I can put the body back on, install the front group to get a feel for the odds and ends.
proud 2nd owner
Old Jun 10, 2022 | 11:37 PM
  #1879
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Dang I started this thread 20 years ago, when I was 14.
Old Jun 11, 2022 | 12:54 AM
  #1880
one4torque's Avatar
Default 1999 bmw m3 ls1 t56
C5 air bridge
C6 muffs
Dumps w resonators
T56. Hurst
Surgery
