s10 ls1ers
Old Dec 26, 2005 | 11:15 PM
XtremeDime's Avatar
i thought about what you guys said about tallying up my costs so far. with the route i take i would needa new rear, built tranny which came out to about 7k. so i was thinking this summer just dropping a stock ls1 mated with my stock 4l60e and rear. it should take it just fine. cost coming out to about 4k or so. maybe next summer ill add a cam and all that stuff to make it a beast. i think going from a 16 sec to an 11 sec might be too much anyhow, i think ill be happy with a low 13.
Old Dec 26, 2005 | 11:55 PM
bww3588's Avatar
the 4L60E in the trucks is different from the one in the Fbodys. it has a different bolt pattern for the different engine. and if my memory serves me correct you cant change the bellhousing.
Old Dec 27, 2005 | 09:07 AM
firefighter's Avatar
Originally Posted by bww3588
if your going to do that then why not go with a moser 12 bolt? 33 spline axels and a warranty. 12 bolt strength for $1375. i dont get it. everyone says what a good deal taking a junkyard rear is and dumping money into it to make it strong and its still not as strong as you can buy a brand new one for WITH A WARRANTY. the perfect rear for an s10 is the 12 bolt. because the 9 inch takes too much to turn and the 12 bolt is not going to break under a truck. the tires will break loose before the rear grenades.
If they were that price unless something has changed to get a Moser 12 bolt the way I want it will cost me almost $2500. You know somthing or actually somebody that I don't know
Old Dec 27, 2005 | 11:20 AM
XtremeDime's Avatar
from wat i heard you just need another hole drilled.
Old Dec 27, 2005 | 11:43 AM
bww3588's Avatar
im sorry its 1725 for the basic 12 bolt. not sure of the axels or gears. sorry about the confusion.
EDIT: i know what it was. i was going by my dad's moser 12 bolt he bought. his was for a 68 camaro w/ leaf springs. the one for the s10's is gonna be more cause its narrower.
Old Dec 27, 2005 | 11:47 AM
bww3588's Avatar
https://ls1tech.com/forums/showthrea...05#post3973605
not to ***** but i got my 1998 ZQ8 for sale if yall LS10ers are lookin for a DD or a winter beater.
Old Dec 27, 2005 | 11:52 AM
bww3588's Avatar
im pretty sure it wont work. correct me if im wrong though.
Old Dec 28, 2005 | 10:23 AM
jtmiller92's Avatar
Yeah, My next project wil be a 98 or newer S10 with Ls1. I was close to building one instead of my Camaro but started feeling sorry for the camaro just sitting there.lol
Old Dec 28, 2005 | 10:36 AM
bww3588's Avatar
let me know if your intrested in her.
Old Dec 28, 2005 | 10:54 AM
jtmiller92's Avatar
Man, It would be perfect if I wasdnt in the middle of this project. I am figuring i will cost me another 6k to finish it and want to be done by Spring so cant spare the cash right now. I have a friend who may be interested so i'll pass this on to him.............jt
Old Dec 28, 2005 | 12:27 PM
XtremeDime's Avatar
i talked to my dad and stuff and he thinks it would be a little better to buy an f-body since itll cost just as much to swap in an ls1 in my s10 vs a firebird. plus i wont have to worry about getting a winter vehicle when IM comes around. i dunno. im looking for a wrecked 98+ camaro/firebird
Old Dec 29, 2005 | 03:32 AM
  #32
ZZ4Blazer's Avatar
Good luck finding an 8.5" from a newer S-series. I too was looking to upgrade from the 7.5". While mine did last very long, I started looking for the 8.5" to upgrade. I looked for a few months, with every junk yard around telling me they had one, or could get me one within a few days.
Not one of them found me a rear end that was an 8.5". I even had to have my money refunded on various occations. NO yard I've ever found, knows how to identify an 8.5" in an S-10, from the 7 1/2 or 7 5/8" rears. Maybe its just the hillbillies around me.
I did end up finding one. Was looking for a timing chain cover for one of my work vans, and a yard in the area had a new one for whatever reason. Figured since I was there, Id see if they had one. Looked though many trucks, and was about to give up, when the guy said he had one more newer rear end that he just pulled out the other day. Was just laying in a pile with a bunch of others. Turns out, it was a 2wd 8.5" rear end. They obviously didnt know what they had, cause they let it go for like $300, including the 3rd shock/hop shock bracket and hop shock still attached.
They usually go for $600+. Stock they aren't bulletproof. Id recommend a good posi, and a new pinion yoke. Common for both to break. I've got less than a thousand in mine, w/ new 3.90 gears, eaton posi, bearings, seals, and billet 1350 yoke. Added an aluminum stud cover to finish it off as well.
They started in 95 trucks with the HO 4.3 and 5 speeds. They were standard only in these trucks till 97. In 98 they were optioned in about anything, but your most likely to find them in a 4.3 5 speed truck. They aren't standard in any platform truck that I know of now,(standard cabs, extreme's, extreme blazers, etc) but the extremely wide ZR2 offroad trucks.
You should be able to run the LSx based motor with an older style tranny. I beleive all you need is a spacer for the flexplate or crank. I don't remember exactly where the spacer is used. This would allow the guy with the bravada to keep his current tranny, provided the computer was programmed to run it and the T case with the LS1.
That should allow you to run pretty much any pre-98 GM auto tranny.
I've seen it advised against drilling the LSX block for the missing tranny bellhousing bolt, as I've heard you will hit the piston. I dont see a problem not using just that one tranny bolt. I've seen plenty of guys running 3 speed autos in drag racing applications without problems.
Sorry for the novel, just wanted to clarify some stuff.
Old Dec 29, 2005 | 05:22 AM
  #33
EPP's Avatar
EPP
Great thread, I have a '97 S10 4 cyl automatic. I think an LS engine transplant would get better gas mileage than what I get...
If any of you people are thinking of going with a Moser 12 bolt, give me a call. I'll give you a great price! Bob
Old Dec 29, 2005 | 11:15 AM
  #34
XtremeDime's Avatar
sweet! actually a 6speed ls1 gets around 30 on the highway from what i heard. i was originally gonna get a 6speed but my other blazers manual got fucked and it kinda ruined it for me. you dont happen to carry any swap parts do you?? lol.
Old Dec 29, 2005 | 08:11 PM
  #35
bww3588's Avatar
thanks buddy. ill get you a finders fee if he buys it.
Old Dec 29, 2005 | 08:16 PM
  #36
ZZ4 you got licky as HELL! I had been looking for well over a year had as many as 3 yards looking for me and all of them never could identify the damn things thats why I went the full size truck route it gives me an excuse to buy better axels any ways. I hope it'll put up a good fight when I'm done with this project 'cause I've decided to go 6-speed.
Old Dec 29, 2005 | 11:52 PM
  #37
XtremeDime's Avatar
so wat is the reason for the corvette accessories?? i know its for clearance but wat kinda clearance, radiator, rad. support, frame?? if its just the rad or the frame i can fix that easy.
Old Dec 30, 2005 | 12:09 AM
  #38
bww3588's Avatar
frame clearence. it moves the alt up on top of the engine so it clears the frame. the ac pump will still contact the frame but either clearence the frame or move it with a relocation kit.
Old Dec 30, 2005 | 12:19 AM
  #39
XtremeDime's Avatar
so technically all i need to do is chop the frame some? im not running ac so thats no prob. is it all frame clearance issues even with the power steering stuff? thanks for all the help guys.
Old Dec 30, 2005 | 12:20 AM
  #40
XtremeDime's Avatar
i found that a vette radiator can fit inside the radiator support so i wont have any issues with that.
