s10 ls1ers
Old Feb 19, 2006 | 09:07 AM
  #221
RedSpeck09's Avatar
mine ran fine for a year with it off and untuned. the only thing i did up front was get a vats bypass module. i didn't have the codes cleared for about a year later.
Old Feb 19, 2006 | 03:52 PM
  #222
XtremeDime's Avatar
im sure it would run like an engine without an EGR. no biggie.
Old Feb 19, 2006 | 04:39 PM
  #223
97noma's Avatar
I'm a little unsure of what vats exactly is? and if i remove the egr, is there a blockoff plate or plug that fills that hole in the intake?
Old Feb 19, 2006 | 05:22 PM
  #224
Jones'n's Avatar
Vehicle Anti-Theft System.
Just make a blockoff for all the holes. No big deal.
Old Feb 19, 2006 | 05:28 PM
  #225
Jake the SSnake's Avatar
A 1 3/8 rubber frost plug works for the intake blockoff ---> egr delete link
Old Feb 19, 2006 | 06:09 PM
  #226
97noma's Avatar
okay cool, thanks for the info.now what about the ses light? can the engine computer be re-programmed without the egr system programmed in it?
Old Feb 19, 2006 | 06:16 PM
  #227
Yes,it can be deleted.
Old Feb 19, 2006 | 06:34 PM
  #228
XtremeDime's Avatar
pcmforless.com they do all that.
Old Feb 20, 2006 | 02:45 PM
  #229
TIM Z's Avatar
11 sec. Truck Mod
well guys i talked to a gentleman at CANTON racing products, and he will custom build an oil pan for my swap for about 500$, i just need some dimensions for my swap( ARE YOU HERE WILDS?, i could really use some measurements!) or if any one else has dimensions for the oil pan to put a 5.3 into a ZR-2 please let me know! THANKS!
Old Feb 20, 2006 | 03:09 PM
  #230
'JustDreamin''s Avatar
You might also check with Eric at Turbotime.....I know they're pretty close to having a ready to go design.... I'm sure they won't part with the info, but should be able to supply a conversion pan fairly soon....Doesn't hurt to ask.....
'JustDreamin'
Old Feb 20, 2006 | 04:05 PM
  #231
XtremeDime's Avatar
jesus christ, is that with or without the KY. 500$ without the benefit of a reach around. robbery i say
Old Feb 20, 2006 | 06:11 PM
  #232
TIM Z's Avatar
11 sec. Truck Mod
yes i agree! but im on the short end of the stick here, i talked sat. to eric at turbo time and he said in about a month he'd be making the oil pan i need and he said it would be about 500$ also! Man, there's got to be a cheaper solution some where, but i am hoping to atleast get some dimensions so at least i can maybe find some one to build one.
Old Feb 20, 2006 | 06:39 PM
  #233
Jones'n's Avatar
Anyone ever seen what goes in to making those pans? $500 is about right. It is pricey, but it is still about right, especially if it is a sheet aluminum pan. If they try to weld up the Cast aluminum pan and just modify it, there is a whole mess of headaches there. That casting sucks, and it is so poreous, it is real tough to make the welds seal.
Old Feb 20, 2006 | 06:46 PM
  #234
97noma's Avatar
What did you guys use for a radiator and e-fan setup with the ls1? Would the stock 4.3l radiator be enough with a set of e-fans?
Old Feb 20, 2006 | 07:32 PM
  #235
TIM Z's Avatar
11 sec. Truck Mod
i was told it would be fine to use, so im just going to try it and see what happens.
Old Feb 20, 2006 | 08:07 PM
  #236
Bigdeezs's Avatar
I'm using my original 1995 stock 4.3 radiator for about 4000 miles with A/C with no cooling issues whatsoever.
Old Feb 20, 2006 | 08:36 PM
  #237
What fans? I see some people use flexalite 220 dual fans which is only around 2500 cfm, according to summits ads that is only good for 250hp w/out ac.So my question would be how many cfms is adequate and how many cfm's do stock ls1 fbody fans flow because they seem to fit the 4.3 radiator really well
Old Feb 21, 2006 | 04:36 PM
  #238
97noma's Avatar
oh so the stock f-body fans will fit with no clearance issues with the face of the motor? because i have the stock camaro fans, they just seem big, wasn't sure if they were going to fit or not.
Old Feb 21, 2006 | 05:33 PM
  #239
Bigdeezs's Avatar
I'm using stock 93 lt1 f-body fans (same motors as most GM electric fans I believe) that I've had on this thing ever since the 4.3. I am NOT using the shroud any more though. I took some 1/8 steel and bent it to make mounting points for the blade/motor assembly. The fans are about a 1/4 inch from the radiator face and they do not contact it in any way. Its tight but doable. The biggest problem is making sure to mount the fans so that the motor body ends up where there are no accesories. (like power steering or idler pulleys)
Derek
Old Feb 21, 2006 | 06:42 PM
  #240
97noma's Avatar
hey bigdeez, what did you use for headers?
