s10 ls1ers
Old Feb 21, 2006 | 08:44 PM
  #241
Bigdeezs's Avatar
Originally Posted by 97noma
hey bigdeez, what did you use for headers?
modified 98/99 f-body manifolds. I wrapped em in header wrap to keep the heat down under there, so they look pretty badass even though they aren't.
I'm probably gunna buy one of those make your own header kits and do it up nice this summer when I get some time.
Old Feb 22, 2006 | 06:14 PM
  #242
TIM Z's Avatar
11 sec. Truck Mod
when you say modified what do you mean? are those the manifolds that are tubular steel?
Old Feb 22, 2006 | 06:47 PM
  #243
RedSpeck09's Avatar
98-99 manifolds are steel. the newer ones were cast iron. what i did with mine was cut off the flange and weld on a pipe and put the flange further down. it helped with clearance.
Old Feb 22, 2006 | 09:30 PM
  #244
TIM Z's Avatar
11 sec. Truck Mod
thanks, good tip!
Old Feb 22, 2006 | 10:52 PM
  #245
Bigdeezs's Avatar
Ditto
Old Feb 22, 2006 | 11:04 PM
  #246
firefighter's Avatar
doesn't the S10 LS1 conversion manual talk about that?
Old Feb 22, 2006 | 11:08 PM
  #247
RedSpeck09's Avatar
yeah. scott did it with his as well.
Old Feb 25, 2006 | 04:40 PM
  #248
97noma's Avatar
I'm actually able to get my hands on a rear diff. from a 98' z28 rather cheap, what I'm wondering is would that make good swap for my sonoma? I know i'll have to weld perches for the leaf springs, but what about width, backing plate to backing plate on the camaro compared to the stock rear diff. in my sonoma? Would it need to be shortened?
Old Feb 25, 2006 | 05:27 PM
  #249
bww3588's Avatar
yeha you can make it work but its pointless. its no stronger than what you already have. youd be doing all that work for somthing that will break just as soon as what you already have.
Old Feb 25, 2006 | 05:32 PM
  #250
RedSpeck09's Avatar
it would definately have to be shorntened. the thing to do is just take the carrier out and put it in your sonoma. thats what i did with mine. i got a 2001 ws6 rear and took the gears and carrier out and put it in my s10. works great.
Old Feb 25, 2006 | 06:10 PM
  #251
XtremeDime's Avatar
or you could just pay like 500$ for a ford 8.8 out of an explorer. another good thing about it is if uget a 95' or newer they got discs. and a bunch of them have posi. the camaro rear would need to be shortened quite a bit. and ive heard of ppl with stock camaros breaking them. the ford 8.8 just bolts in but you will need to get a chevy bolt pattern and its about the width of a 4x4 rear so like maybe 2" wider on each side, totally manageable.
Old Feb 25, 2006 | 06:40 PM
  #252
bww3588's Avatar
why? that was a waste of time because its the same carrier your sonoma had in it.
Old Feb 25, 2006 | 06:44 PM
  #253
XtremeDime's Avatar
i think the camaro rear is slightly stronger but not worth the effort to do so.
Old Feb 25, 2006 | 06:48 PM
  #254
bww3588's Avatar
no its not. it has the same spline axels and the same diameter carrier. its made with the same materiels and same cover so it has no strength advantages. its the same carrier.
Old Feb 25, 2006 | 06:51 PM
  #255
XtremeDime's Avatar
arent they 8.5" most s10s are 7.625"
Old Feb 25, 2006 | 07:16 PM
  #256
Jake the SSnake's Avatar
No, the only rear end offered from 1982 to 2002 was the 7 1/2 or 7 5/8 ( there was a "9 bolt" I think) whichever it is, pretty lame of gm to put that behind the ls1. I blew my rearend in my ss last year with less than 10000 miles on it also took my 4l60e at the same time
Old Feb 25, 2006 | 07:27 PM
  #257
XtremeDime's Avatar
so one myth is busted. when i was first looking for swap info they said my rear would blow almost instantly. you learn sumtin new everyday!
Old Feb 25, 2006 | 07:29 PM
  #258
RedSpeck09's Avatar
no it wasn't a waste of money. i wouldn't jump to conclusions so quickly. i had an open carrier in my s10 stock. i also had 4:10 gears in and i didn't want something so steep as i do a lot of highway driving and wanted the best gas milage i could get. i went from 4:10 open to 3:42 limited slip for less than $100 after i sold the housing. doesn't sound like a waste of time to me.
Old Feb 25, 2006 | 07:32 PM
  #259
RedSpeck09's Avatar
that is not true. i dont know what year it started in, but late model s10's, especially with 4.3L 5 speeds came with the 8.5" rear. it was an option in the later years. 4wd and zr2 models came with the 8.5" rear as well. the standard 4wd model is like 2 inches wider than stock, while the zr2 model is 4 inches wider. the 8.5" rears are more common in late model blazers as well.
and don't listen to that. i've been driving my ls1/t56 setup for over 3 years now. i haven't had a problem with the rearend yet. now, if you throw on some slicks or a real sticky tire thats going to put stress on the rear, it won't last as long. a lot of horsepower and torque will kill any rearend that isn't built to handle it.
Old Feb 25, 2006 | 07:35 PM
  #260
I was talking about fbody rear ends Yes the 8.5 came on some v6 trucks but not the 300+ hp fbodys
