s10 ls1ers
Josh
Other transmissions you could consider include the TKO 500 & 600, Richmond 5 & 6 speeds, and most of the factory v8 4 speeds (like Muncies & T10's) but you give up overdrive.....
Most of the other transmission choices are either too weak (like the T5) or really not suitable (like the NV4500 truck transmission, which might fit and probably not break, but takes about 15 minutes to shift gears).
'JustDreamin'
The LS1 engine itself above '99 only needs a fuel feed, however, the Corvette filter assembly will utilize the return. No return goes to the engine.
If you are keeping emissions, just hook the EVAP tube to the EVAP purge solenoid on the '98 engine.
so, it's just a matter of running a feed and a return. cool, i like that. Well i'm going to the garage tonight, gotta finish my suspension and body mounts, thanks for the help. Josh
