s10 ls1ers
Old May 26, 2006 | 09:57 AM
  #481
AceHaag's Avatar
The engine is in and running and the truck is at my buddy's house where we're fabing up 1.75 lt headers. hope to finish everything by the begining of july for car craft summer nationals.
Old May 26, 2006 | 10:03 AM
  #482
Jhankinson's Avatar
I am almost finished....got my ZQ8 suspension done....blazer center console mod...overhead console mod....leather blazer seats....dynamat throughout entire cab...frame cleaned and painted...all new steering components...poly bushings throughout....blazer DP brakes up front....8.5 disk blazer in rear with detroit trutrac...motor in and wired....intake ducting done....battery relocated in pass side of bed...got true H-pipe duals with Dynomax Mufflers exiting dual swept side behind pass tire...have tach working properly....still working on cruise controls (added it in...truck didnt orig have it, so its a PITA)...trying to figure out the VSSB/DRAC calibration to get my speedo and cruise and ABS to work properly.....after that all I have left is clean up some interior wiring (originally a base model...now 98+ door panels...power windows, power locks, power heated mirrors, and power heated memory seats) Also have some alarm wiring...have to loom it up and make it pretty as I added a window roll up/down module to it. So hopefully in about 2 weeks I will have my C6 Z06 rims and tires and the wiring will be done....then its on the road i go its been one year and about 7k to get it this far...but oh it is so worth it.
Old May 26, 2006 | 12:37 PM
  #483
Jake the SSnake's Avatar
Sounds alot like my project,blazer interior/consoles,blazer rear...Unfortunately I haven't had time to touch it in a month .Should be back to normal next week and get the motor dropped in and ready to have headers fabbed.
Old May 26, 2006 | 03:01 PM
  #484
philntx's Avatar
Default My 6.0 S10 Blazer project
It's a 2000 S10 Blazer 4-door, with the Trailblazer upgraded leather package and sunroof.
The engine is a crate 6.0 Chevy with:
· ARP fasteners,
· 9.5 CR forged blower pistons,
· mild ported LQ9 Heads,
· Comp Cam 54-424-11 Blower Cam, valve springs, push rods
· Ported Oil Pump
· 90mm LS2 Throttlebody
Aluminum radiator w/twin pullers
· Magnuson Supercharger w/LS2 throttle body mounted to
eliminate cruise control and use "drive-by-wire" throttle cable
· Stainless steel custom LT headers
· Random Technology Converters
· 4 O2 Sensors
· 3" Magnaflow Muffler with Resonator
· Emissions Legal in Texas
Ed Wright Program (and dynotune when finished)
· 4L65E Transmission with shift kit
· 2200 Stall Converter
· 3.73 Gears - Front and Rear
· Powertrax diff in Rear Alxle
· 13" SSB 3-piston front brakes and factory rear disks.
· Hydroboost brake system
· GM 246 Transfercase
· Custom front and rear drive shafts
· A-Pillar mounted Boost and Fuel Pressure gauges
Key switch to lock out the boost on the blower
· KB Boost-a-pump
· 18" Konig Wheels w/255/50x18" Scorpion Tires
· Front Diff lowered 1”
· Custom sheet metal oil pan
· Edlebrock EAS Shocks
The engine is in the truck and uses a custom sheet metal oil pan and stainless LT headers. So far, it looks like it is going to fit under the stock hood.
Phil[/list]
Old May 26, 2006 | 03:42 PM
  #485
XtremeDime's Avatar
they have to be hosted on the internet somewhere else, i use photobucket.com
Old May 29, 2006 | 10:48 AM
  #486
firefighter's Avatar
Phil is that gonna fit under a stock hood? Just curious if a maggie fits. Kinda an outside thought for me I still think I'm gonna go N/A.
Old Jun 2, 2006 | 09:23 AM
  #487
Hey how'd this get to page 2?
Old Jun 5, 2006 | 01:30 PM
  #488
AceHaag's Avatar
anyone know how much wider a 4x4 rear end is than a 2x4?
Old Jun 5, 2006 | 01:35 PM
  #489
I got 4 inches when I measured mine from a 99 blazer 4x4.My 17x9 ss wheels fit perfectly in the back with 275 40 17
Old Jun 6, 2006 | 12:47 PM
  #490
The regular 4X4 is 4" wide overall (2" a side) and the ZR2 is 8" wider overall (4" a side) all this is compared to the 2WD rear.
Are you looking for a 8.5"? I gave up on mine so I just got an 8.5 out of a '95 Silverado and I'm gonna put new tubes on it and rebuild the rest.
Old Jun 6, 2006 | 03:43 PM
  #491
AceHaag's Avatar
I have an 8.5 out of a 2001 silverado i was planning on doing the same thing with. it has the disk brakes on it hoping i can transfer those also.
Old Jun 6, 2006 | 07:56 PM
  #492
Only problem is they went to 6 lug in '99 I think. It's about impossible to find one out of an S-series. What I have figured out is that the stock tube diameter is prolly about 1/2" too big. If you look at the pics of the ultra rare S-10 8.5" the tubes reduce in diameter after it leaves the center section on the Full size it does the exact opposite it enlarges right after the pumpkin. So now I am looking into the idea of somebody local doing the tubes for me I might end up sending it to DTS or Strange or Moser or hell I don't know......
I'll figure it out I allways do. I'll let you guys know when I do.
Old Jun 7, 2006 | 03:57 AM
  #493
AceHaag's Avatar
what about a gen 2 camaro rearend they were all 8.5s wouldn't that be a bit easier to narrow since it already has the right bolt pattern and i would think rather plentiful.
Old Jun 7, 2006 | 10:12 AM
  #494
Yeah I thought about that but it was reccomended to me to get the silverado rear as it had larger bearings (forget which ones) and is supposed to be a stronger rear.
Old Jun 10, 2006 | 12:07 AM
  #495
XtremeDime's Avatar
i wouldnt use a stock camaro rear, they break on stock camaros sometimes. im stickin with the 8.8 all i need is to get the bolt pattern changed and maybe shorten it a little, its 4 inches wider.
Old Jun 11, 2006 | 09:22 AM
  #496
Well you can make the Camaro (second Gen) stronger you would just have to go to 30 spline axles and do the rest of the std upgrades it would be fine it's an 8.5" or you could just get the silverado rear.
Old Jun 11, 2006 | 11:08 AM
  #497
bww3588's Avatar
they werent 8.5's they were all 7.5 inch up till 93 then they went to the 7.625 (7 5/8). the same as the S-10 truck. the 99-2000 blazers with the W code V6 and a 5 spd had the 8.5 3.42 posi rearend. some had disc brakes also.
Old Jun 11, 2006 | 12:26 PM
  #498
No the fbodys had an 8.2 in the first gen then switched to an 8.5 in the 70's (28 spline I believe). The 82-02 were the 7 5/8 rears.
Old Jun 11, 2006 | 07:26 PM
  #499
XtremeDime's Avatar
i dont feel comfortable putting a 70s POS rear on my truck lol
Old Jun 12, 2006 | 02:16 AM
  #500
XtremeDime's Avatar
is ls1 performance parts better yet?? i really want there 1 3/4 long tubes.
