s10 ls1ers
One thing you guys might wanna look into is the C5 vette brake upgrade. If you turn your stock rotors down, you can use them as a hub. A few people make a bracket that bolts to the stock S10 spindle than allows you to use the C5 caliper as well.
Go to www.thirdgen.org and look for the C5 swap in the brake upgrade section. An S10 spindle and 3rd gen F-body spindle are exactly the same except the S10 spindle takes a balljoint up top and the 3rd gen has a strut mount. Everything else carries over.
. Though you are correct, there are alot more swap products for that motor as I beleive most SBC stuff will work. Though it seems there is enough LS1 stuff out there now I think to get you by though the company that has the good stuff...like long tubes and oil pan is hit and miss (ls1performanceparts.com).But also remember that usually the motor has to be newer or the same year as the vehicle it is being put into to be emissions legal.
also note I am assuming we are talking about built motors not a stock drop in if you are talking stock you are absolutely correct.
