s10 ls1ers
Old Mar 16, 2006 | 08:53 AM
  #321
MrDude_1's Avatar
Originally Posted by firefighter
Well it depends on the vehicle you got I'm gonna assume by your handle you got a '97 sonoma so that means you got the traditional style spindles. So you would need the hubs and brackets from Ed Miller (the guy I used) I'll get the info so you can contact him. My truck just needed a bracket 'cause I have the sealed hubs from the factory Blazer spindles. All I had to do was some clearancing and bolt on the calipers. My front end set up was prolly the cheaper of the two set ups I bought some used Vette calipers and carriers from a local Vette shop for sit down $75 for the pair. The rebuild kits were like $25 for the pair the brackets were $150 the rotor were $150 for the pair new. The total swap front and rear was about $900.
just FYI, 3rdgen fbody brakes are the same thing as the "traditional" S10 ones hes refering to above.
ive met Ed and known him online even longer, good guy and he makes great brake parts. even if you just need the hubs or the brackets, i highly reccomend getting it from him... unless you can make your own..(not too hard with a lathe)
when the site goes back up, look at the brake setups on www.thirdgen.org .. theres ALOT of info there about it.
Old Mar 16, 2006 | 10:15 AM
  #322
firefighter's Avatar
yeah also if you got to the C5 thread at S-seriesforum it has a link to his yahoo photos that has the pics of most of his kits.
Old Mar 17, 2006 | 04:17 PM
  #323
97noma's Avatar
alright cool..i found the link
now i'm kinda curious as to what process you guys went through as far as markup goes for the oil pan.wanna set the engine in this weekend, just trying to get a good idea of how to go about it. looking to mark up for the truck pan, what did you guys find easiest to do, engine in with the pan, or without the pan on?
Old Mar 19, 2006 | 06:11 PM
  #324
1993formulav8's Avatar
Just wondering on a couple of things, has anyone tried to use the 98-99 fbody midlength headers, or the manifolds from the 5.3 silverado? Also what are the issues with the f body acc brackets and a 99 s10?
Old Mar 19, 2006 | 07:56 PM
  #325
Jake the SSnake's Avatar
You mean like these It looks kinda close other than the collectors and by the time you modify the collectors it probably wouldn't be any better than the jtr/headman headers. And as far as manifolds go it doesn't take much to make the 98-99 fbody manifolds work
Old Mar 23, 2006 | 08:20 AM
  #326
Yeah but wouldn't those flow better than manifolds?
Old Mar 23, 2006 | 01:35 PM
  #327
'JustDreamin''s Avatar
If you look at where the F-body Acc puts the alternator you'll see....The alternator mounts way down low, right in the same spot the steering box is. The 2 items really shouldn't occupy the same space....
'JustDreamin'
Old Mar 23, 2006 | 03:36 PM
  #328
Bigdeezs's Avatar
'JustDreamin'
Dreamin says so matter of factly...LMAO
Old Mar 23, 2006 | 07:27 PM
  #329
97noma's Avatar
so this list here is everything you need to change to the c5 drive for to fit the s10? and where it says same as f-body, im assuming that means that stuff is the same if you got an ls1 from an f-body?
Alternator (1)10246634 (production) 10316182 (service)
Alternator to bracket bolts (2) 24503609
Alt bracket to head bolts (3) 11516357
Alt bracket to head bolt (1) 11516356
P/S fluid reservoir bracket (1) 12555222
P/S fluid reservoir (1) 26046502
P/S reservoir hose (1) 26046910
P/S reservoir cap (1) 26022453
P/S pump (1) 26046503
P/S pump pulley (1) 12559890
P/S pump brace (1) 12555693 Same as f-body
P/S pump bolts (2) 14078896 Same as f-body
P/S pump bolts (2) 11515758 Same as f-body
Belt idler pulley (1) 12564401 Same as f-body
Harmonic balancer (1) 12560115
Belt tensioner assembly (1) 12559325
A/C belt tensioner assembly (1) 12560345 Same as f-body
A/C belt idler pulley (1) 12557334
A/C compressor bracket (1) 12556444
A/C compressor (1) 1137031
A/C bracket stud (1) 12556447
A/C bracket bolt (1) 11515768
A/C compressor bolt (1) 11516714
A/C compressor bolt (1) 12552922
A/C compressor bolt (1) 11509202
A/C compressor nut (1) 10255857
Old Mar 23, 2006 | 07:40 PM
  #330
Yup I ordered a bunch of brackets and bolts from gmpartsdirect a month ago and got them yesterday.As far as I remember the part #s are all good just don't forget the alternator/ps pump bracket 12578068
Old Mar 23, 2006 | 07:46 PM
  #331
XtremeDime's Avatar
im glad im not running ac that cuts the list and the price in half!
Old Mar 23, 2006 | 07:50 PM
  #332
XtremeDime's Avatar
do you think the s10 alternator would work??
Old Mar 23, 2006 | 09:31 PM
  #333
97ls1s10's Avatar
Originally Posted by AceHaag
the holes should be there for the 2.8 mount they may need to be tapped. the mounts go with the single hole twards the out side of the truck. just did the same thing in my '01.
i got the 2.8 mounts and i left the stock 4.3 mounts on the frame and i cant get them to quite line up which way do they go?
Old Mar 23, 2006 | 09:52 PM
  #334
reds10's Avatar
I ordered the ls1 swap book from current performance a few weeks ago and still have nothing. I also emailed them to see if they knew when it would be here and no response. Anyone else have any contacts with them??
Old Mar 23, 2006 | 10:02 PM
  #335
XtremeDime's Avatar
umm dude ur suppose to chop the 4.3 mounts off and attach the 2.8 to the frame and then use the stock ls1 mounts to mount them to the 2.8 ones
Old Mar 23, 2006 | 10:03 PM
  #336
XtremeDime's Avatar
the swap book isnt sold directly through current performance its sold by v8s10s.com
Old Mar 24, 2006 | 11:09 AM
  #337
low03noma's Avatar
Not sure but i will be trying it. Anything works with a little fabrication. just make brakets to go from the vette braket to your alt. it would save alot of money if you didnt have to buy the vette one
Old Mar 24, 2006 | 11:45 AM
  #338
Just trying to add a little humor....Even if it is somewhat subtle....
'JustDreamin'
Old Mar 24, 2006 | 03:06 PM
  #339
AceHaag's Avatar
look back in this thread i posted pics.
Old Mar 24, 2006 | 04:52 PM
  #340
Hmbre97's Avatar
Anyone know what the oil capacity is on the modified truck pans?
