s10 ls1ers
Old Jul 28, 2006 | 09:05 PM
  #601
sslowered's Avatar
Hey guys I got a quick question. I am almost done with my swap and I cant get the shifter to shift properly. I got a blazer console and a camaro a4. What are you guys doing about shifters in your swaps?
Thanks
Old Jul 28, 2006 | 09:35 PM
  #602
Bigdeezs's Avatar
On mine I had to go into the tranny and change the shift shaft (the point on the tranny the shifter linkage bolts to) its pretty easy...only took a couple minutes but my tranny was out at the time. Mine has the column mounted shifter and a box (mounted on that shaft) that tells the which lights to light up in my instrument cluster (P-R-N-OD-D-2-1).
Thanks
Old Jul 29, 2006 | 11:25 AM
  #603
firefighter's Avatar
I didn't realize that there would be a difference. But I kinda stopped thinking auto when i decided on a M6.
Old Jul 29, 2006 | 02:56 PM
  #604
sslowered's Avatar
Ok, here is the problem. I am going to try switching the shift shaft, Thanks BigDeez. I am switching the shifter lever by hand underneath the truck and when I am taking it down the road it wont shift out of 1st. The speedometer dosent register either, I dont know if that has anything to do with it or not. What would make the transmission not shift? The fulid level is good, any suggestions would be great.
Thanks
Old Jul 30, 2006 | 05:28 AM
  #605
Bigdeezs's Avatar
Sounds like your unregistering speedo is the main problem. If you are not getting a VSS (the sensor on the tail housing) signal the tranny will do exactly what your describing...not shift...as well as have the speedo inop. I had the VSS go out on my Camaro A4 trans and thats exactly what happened. I think my VSS went out due to all the in and out of my motor and trans when I was fitting them. I would say check to make sure the ECM is getting a VSS signal before anything else.
Thanks
Old Aug 1, 2006 | 03:41 AM
  #606
AceHaag's Avatar
here is a vid of my truck
http://video.ls1tech.com/video/10527...10004cda3c.htm
Old Aug 1, 2006 | 02:02 PM
  #607
Bigdeezs's Avatar
Damn that's sweet...heres a few of mine. Anyone else got any more? I know I'd love to see em.
http://www.youtube.com/watch?v=mT1fo-FkSDA
http://www.youtube.com/watch?v=hrVoRqXIp5M
http://www.youtube.com/watch?v=056ZbYORIsA
Originally Posted by AceHaag
Old Aug 3, 2006 | 03:46 AM
  #608
AceHaag's Avatar
I cracked the oil pan on my truck the other day so I was wondering if any body has found any more info an how the ls2 pan fits?
Old Aug 3, 2006 | 12:29 PM
  #609
jinusow's Avatar
I just posted about notching the ls2 oil in s10forum. Yes it does work and leave plenty of room. I have a 4" lowered s10 and I won't have to worry about a busted pan. The only pain is where the drain plug is located. You can get to the plug but oil will pore onto the crossmember. This is the better pan to use over the 5.3 and you do not have to cut the ls2 oil pan at all for a lowered s10.
Old Aug 3, 2006 | 03:05 PM
  #610
how much room is between the drain plug and the cross member? do you think there is enough room for one of those oil change valves?
Old Aug 3, 2006 | 03:23 PM
  #611
like this thing from fumoto http://www.fumotovalve.com/ I don't know much about it but they have one with a nipple maybe put a 90* elbow on it or somthing. I don't know. Just thinking but it all depends on how much room is available.
Old Aug 4, 2006 | 10:49 AM
  #612
1FASTS10's Avatar
I was totally there in the stand rooting you on man..good to see the s10s showing up the other cars haha..
Old Aug 13, 2006 | 10:27 AM
  #613
acrorigo's Avatar
anyone else have pics of how much they cut out of the cross member for the ls2 pan???
Old Aug 13, 2006 | 02:06 PM
  #614
bww3588's Avatar
PM LS2Sonoma
he has a few.
Old Aug 13, 2006 | 09:31 PM
  #615
Xtremes10's Avatar
Default motor mount blues
ok, so the motor mounts (on the block) that i ordered from JTR(jags that run) dont even come close to allowing the motor to even mount, even with about 3" of movement front to back on each side, its as if he welded them backwards, as well as the headers that i ordered from them wont fit at all, it ends up right in the steering shaft, anyone else have these problems?
Old Aug 13, 2006 | 09:42 PM
  #616
Jake the SSnake's Avatar
Maybe you installed the mounts wrong? They will bolt to the motor on the wrong side.At any rate take some pics of the problem area's and post them.Also,are you using the older style 2.8 mounts?
Old Aug 13, 2006 | 10:12 PM
  #617
Xtremes10's Avatar
got the whole thing, it actually makes the motor sit ****-eyed, and causes the pan to go into the cross member (yes it is notched 2X10) and we cant really notch the k-member any more, the a-arm bolts are right against the edge, i know the mounts were on as labeled(each one said either pass or drivers side) but if they were flipped and the tabs welded on the other side it would fit perfect, a screw up maybe? ill get pics tomorrow
Old Aug 14, 2006 | 12:17 AM
  #618
BluLS1's Avatar
Originally Posted by sr_ryan1
for the auto transmisson 4l60e you will have to drill another hold in the trans braket to mount it, and may have to cut your drive shaft back about 2-3 inches. .
what do you mean by having to drill anothing hole in the bracket? and does the transmission have to be moved back some or something, i'm kinda confused on this part.
Old Aug 14, 2006 | 07:41 AM
  #619
acrorigo's Avatar
anyone know where i can get the ls2 oil pan relativley fast and inexpensive???
Old Aug 14, 2006 | 08:20 PM
  #620
Xtremes10's Avatar
ok, sorry about not getting the pics, but we were looking, the brackets are incorrect, we measured, he welded them backwards, as well as, we noticed (he was getting ready to go on vacation in 2 days) that he only welded 1, yes ONE, side of the mounting tabs, and burned them none the less, so were gunna have our guy fix em up some
