f-body ls1 oil pan & A-body(69 chevelle)?
Is it possible to get the ls1 engine in without modifying the oilpan?is there any other problems I will have ,to get the engine in there?
Thanks
Thanks
Originally Posted by 350SS
I got it to fit w/ out having to modify the f-body pan, using BRP style engine mount adapters and relocating the frame mounts. It's real close to the firewall, but there's enough clearance to get to the trans bolts w/o much hassle.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Newbie](https://ls1tech.com/forums/images/smilies2/newbie.gif)
thanks
Originally Posted by Lars1
Thanks for answer
did the alternator fit without modif.?when you mounted the engine?Anyone who know where I can get pics and info about engine mount adapters?Will try to make them myself
thanks
thanks
Originally Posted by SatisTraction
this is a popular subject. there are several types on the market but making your own is easy if you have some basic tools.
street and performance version
BRP mounts
make your own from these templates.
S&P style
BRP style
mount search
BRP mounts
S&P style
BRP style
mount search
if you have access to a welder and some steel, you can make your own mounts and use the stock ls1 pan. on my conversion i am using a Lingenfelter LS1 with a dry sump so i had to cut notch the crossmemeber for the pan to fit, but i made my own mounts. on the a-bodys, since everything is so open i would almost recommend making your own that way you can get the right clearance you want between the frame and the pan as well as between the motor and the firewall.
