LS Pilot Bearing Size
Any help you can give would be greatly appreciated.
Did you reuse the stock bell housing in your installation? I know Keisler makes some hybrid bell housing but I do not know if they have accommodations for the stock style clutch linkage.
I will check out the sticky for the pilot bearing stuff and post my findings here.
I think I read that you just used the standard bellhousing and had to leave one bolt out. How is that working out now that you have had a chance to add a few miles to the car?
Sweet deal. I will look into it and get me one on order since it seems I am going to need one.
I believe I will just use what I have.Now if I can come up with a solution to my clutch linkage. I want to use the stock stuff if I can.
The closest I could come on this was an old school "extended" pilot bushing (it is like 1/4" longer, for a total of about 1") on eBay. It was a real tight fit in the crank. I used a stock LS1 flywheel and LS6 pressure plate with an "eBay special" clutch disk along with a mid 80's GM truck bellhousing since the pattern was the same for the 4 bolts on the tranny and as mentioned above all but one bellhousing to block bolts.
I don't have much time on the combo, still working the bugs out, but the clutch setup has not been an issue other than neededing a larger bore MC over what the Toyota had.
Thanks for the help Mike. Great help like you guys are giving sure does help make a project like this go a whole lot easier.
You should go by your Chevy dealer & see if they have one on hand that you could measure.
I suspect your Keisler tranny is a Tremec series similar to my TKO600, if this is the case, the 12557583 inner diameter is way too big for your input shaft. The 12557583 appears to be used in truck applications that use a larger input shaft diameter than the T56 or old school style trannys. The LS1 T56 pilot bearing is shown to be .600 inch ID, 1.096 OD, .720 inch thick.
