5.3 swap cj
I was wondering if some one could tell me what throttle cable they used in there cj swap looking in my summit mag. I 'am looking at lokar cable 48" long universal not sure if this will work with out any after market cable brackets ?
I also still need cold air intake tube any suggestions on what to use or fab my own THANKS IN ADVANCE HUMJ7
Hey, ElkyRacer how far along are you with your project ? I 'am hoping to be driving mine 2-3 weeks. I have had it temporarly wired just to here it run now doing all the finish wiring. HUMJ7
Hah, Im still in the 'aquiring parts' phase. Ive got an 03 5.3/wiring harness, an 02 computer, MAF, will be swapping to an f-body oilpan and cable style throttle body as soon as my buddy pulls his motor out. Got a set of stock f-body manifolds for exhaust side, and a inline fuel pump. Im waiting on my TH700R4 to get built, then I can order the transfer case doubler kit. Ill be running a 231 into a dana 300. Have both transfers, just gotta get the tranny back to mock up and get motor mounts/tranny mounts fabbed up. Then its wiring time, then gotta get a fuel tank built, cooling system needs to be sorted, build exhaust, blah blah. Lots of little crap now really. Im eagerly keeping up with you and the other Jeep builds to see how things are going for you guys!
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Have a look at Lokar Performance Products
Also what trans are u running? Manual or auto?
Also Advance Adapters does have some items for jeep and conversions. There stuff is Lokar.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
info that may help
http://www.hotrodlane.cc/JEEP/jeep1.htm (1981 CJ with 5.3)
http://www.hotrodlane.cc/ (great stuff show car quailty)
info that may help
Thank you Yoda55,
I have some worries about mud and dirt while I am wheeling with my one piece front end. Was thinking about making my own air intake.Having it loop around so it would be closer to the battery tray,and out of the way of the mud and dirt.
I am almost done with my two year project building a humj7 from the frame up. Just trying to get some odds and ends done.
Hey,pick01
Here are a couple of pics of my motor mounts drivers side is in thrid hole on the mount. Hope this helps you. HUMJ7 p.s. orry ther so small not sure how to make them bigger
Holy tiny pictures Batman! What mounts are you using? Ive got my 5.3 sitting on wood blocks in the engine bay and it looks like I could possibly make the truck mounts work ok. My 231/300 doubler should be here first of next week, if I can find a mockup 700R4 Ill slap it all together and start figuring out some mounts for this thing. Its starting to come allong nicely!
Kyle
Kyle
Yes the pictures suck ! but,we do not understand how others put larger ones in here.
If I understand this right your running two transfer cases?
If so why?
We used advanced adapters motor mounts
HUMJ7
If so why?
HUMJ7
Hope this picture turns out a little better.if so i will post more later need to put seats in bleed brakes hook up shifter cable.should be ready for test drive can not wait to drive it! HUMJ7
http://s179.photobucket.com/albums/w301/cjhumj7/
