My 6.0 1971 Olds Cutlass
Old 07-08-2008, 02:05 PM
  #141
lsxyj's Avatar
u just had a four day weekend why is there no updates i know u have parts and stuff u can do lets get it done
Old 07-11-2008, 09:38 PM
  #142
ryanvv355's Avatar
I built the fuse block tonight using a factory Chevy Lumina block and adding some circuits to it. I actually bought 2 and made one out of the parts. The 6 15 amp fuses will be for the pink wires that are run/start hot. The 50 amp maxi fuse is inline with the 15's, not required but just worked out that way. The 3 20 amp circuit breakers are fuel pump, accessory/run/start circuit, and 12v constant. The three relays are run/start circuits, accessory/run/start circuits and fuel pump. I am mounting it on the inner fender right by the battery. I think tomorrow I am going to tie the harness into the fuse block and make it all work.
Old 07-11-2008, 09:46 PM
  #143
ACONLP's Avatar
looking good man i wish mine was that far along
Old 07-13-2008, 08:10 PM
  #144
lfootmatt's Avatar
Look at it this way. If Olds still existed this is what all of us Olds freaks would be doing! Just like the 1st Gen Camaro/Firebird guy are doing. Sweet build. I'm thinking of a similar build for an FJ40 when I get one!
Sweet!
Matt (lfootmatt on ROP)
Old 07-14-2008, 02:18 AM
  #145
ryanvv355's Avatar
Installed the fuse block and ran most of the engine management wiring, just need to find an accessory/run/start circuit in the car to power the relay. Still waiting on Fuddle to get me a good converter
Old 07-14-2008, 12:40 PM
  #146
porksoda's Avatar
Looking good! Your a brave man building your own fuse block, I give major props to you! I tried building a harness one time and it looked like a huge mess, it worked but did not look good at all! It even took me like 4-5 hours to install my nitrous system because I was trying to keep it looking clean. Can't wait to see it around.
Old 07-20-2008, 09:52 AM
  #147
blownerator
BlownChevy's Avatar
Nice work!
If you do not have it already, you are going to need the return style rail adapter from Magna Charger in order to utilize the return style pump you have.
Old 07-20-2008, 09:58 AM
  #148
ryanvv355's Avatar
I'll be running an Aeromotive boost referencing regulator
Old 07-20-2008, 10:24 AM
  #149
blownerator
BlownChevy's Avatar
So you will be running a single line from the regulator to the fuel rail? I would rather see you run the return line all the way to the fuel rail and get the hot unused fuel out of the rail.
Old 07-20-2008, 10:28 AM
  #150
ryanvv355's Avatar
You have my attention, suggestions?
Old 07-20-2008, 10:35 AM
  #151
blownerator
BlownChevy's Avatar
I suggest running the both fuel line and the return line to the rail (new rail adapter for return style) and using the factory style fuel pressure regulator. I have made 650 RWHP with the stock fuel pressure regulator, and return style system.
If you decide to use the Magna Charger rail adapter give me a call. 805-642-8833.
FYI, this should save a few bucks and net the same results.
Brian.
Old 07-29-2008, 11:32 AM
  #152
350SS's Avatar
I got my Spectre Industries EFI fuel tank today from MuscleRodz in Oklahoma City. Looks like it will work great. The only issue is the return port is a hose barb fitting, I will have to cut it off and put a -06 male fitting there. The output port is -08.
Hey, if you didn't install your tank yet, could you get a measurement of the sender hole inside diameter? I'm considering getting one of these tanks but would like to know if I'm going to be able to add an additional intank pump to it. Keep up the good progress
Old 07-29-2008, 04:54 PM
  #153
ryanvv355's Avatar
No I have not installed it yet and will take some measurements for you, however, I am on vacation and will not be able to for a few weeks, but when I get back I can hook you up.
Old 07-29-2008, 08:45 PM
  #154
350SS's Avatar
Doh! jk, I appreciate it and enjoy the vacation. Btw, a post over on team chevelle mentioned that the outlet fitting isn't -8an...not sure which is correct:
Originally Posted by SRGN
What size fitting is on the tank for pressure? I bought one of these and it's not an AN fitting. It's a Spectra GM 34 FI tank.
Originally Posted by Musclerodz
3/8" SAE 45* flare fitting.
http://www.chevelles.com/forums/show...1&postcount=37
Old 07-29-2008, 08:59 PM
  #155
SIC LSX's Avatar
Sweet *** ride! All that and your going to get a Fuddle? I would of got a yank!
Old 08-04-2008, 10:56 AM
  #156
6spdgto's Avatar
I'm waiting to see what you do with the power steering. I have a very similar setup in the works.
Old 08-04-2008, 12:20 PM
  #157
217zenki's Avatar
I had a 350 rocket once.. It was one of the only enignes that Ive owned that wouldnt give up.. I ran the total **** out of it never ever any probs i went through like 4 trannys tho..
Old 09-01-2008, 01:59 AM
  #158
ryanvv355's Avatar
Default Progress
We got alot done Sunday. First off, I set the radiator up with the fans and trans cooler. We set the intercooler in with the stock Magnacharger brackets massaged a bit. The intercooler pump mounted up with a 2.5" muffler clamp and a bit of creativity. We mounted the water tank in front of the radiator out of sight but still accessible. The throttle cable bracket was fabbed up from the oem one. Most of the coolant lines are ran, intake plumbing ran, MAF harness complete, and some more wiring taken care off. Monday we are going to take out all the fuel lines and tank, finish most of the wiring and hopefully put power on her to look for smoke. (hope I knew what i was doing)
Old 09-01-2008, 11:46 AM
  #159
magic's Avatar
Awesome build!!
Old 09-01-2008, 12:56 PM
  #160
rdrage728's Avatar
love the car and the blower good luck with the harness im sure its fine looks like you did a great job on it.
Quick Reply: My 6.0 1971 Olds Cutlass
