Wiring harness connector question
Old Apr 1, 2007 | 08:22 AM
fast377's Avatar
Default Wiring harness connector question
I'm trying to figure out what a plug goes to and what plugs I'm missing on my '01 harness. Firs there is a 3 pin connector at the back of the engine that comes out of the little bundle that the map sensor connector comes out of...what does that go to? Next there is a group of wires wrapped in silver heat shielding (that runs down the back of the strut tower on the 4th gens) that all the connectors have been cut off of. I think that the right bank o2 plug goes there and the crank sensor goes there...any ideas?
Old Apr 1, 2007 | 10:28 AM
fast377's Avatar
Okay, I figured out what the lone connector was...evidently I forgot to plug in the cam sensor (stupid me).
All I need to know now are the color wires that go to the crank sensor and bank 2 upstream o2 sensor.
Actually if someone can tell me what all the wires in the crank sensor/o2 sensor bundle go to, that would be great.
Old Apr 1, 2007 | 03:53 PM
Skele4door's Avatar
It depends on what year harness you are using. Look in the FAQ in the sticky section for conversions and hybrids and there will be a link to PCM pinouts which will have the wire colors. Good luck.
Old Apr 1, 2007 | 07:47 PM
leonpiper69's Avatar
dont feel stupid about the cam sensor, i did the same thing. drove me nuts for 3 days, cuz you cant really see it under the map sensor.
Old Apr 1, 2007 | 08:18 PM
G-Body's Avatar
sawzall wielding director
The crank pos sens is DK BLU/WHT, YEL/BLK and LT GRN they are on computer connector C1 pin 12, 21, and 2. The bank2 sensor 1 o2 sensor is pink, black, tan and purple.
Old Apr 1, 2007 | 09:17 PM
fast377's Avatar
Awesome, that is exactly what I needed to hear! Thank you! Now that just leaves 3 maybe 5 wires coming out of that bundle that are unaccounted for. I may post what the colors are tomorrow...I know one of them is a thicker gauge purple wire.
Old Apr 2, 2007 | 09:55 AM
fast377's Avatar
Okay here are the three remaining wires that are unaccounted for: larger gauge purple, brown, and black/white. Thanks guys.
Old Apr 2, 2007 | 01:35 PM
Skele4door's Avatar
The large gauge purple wire will be your starter trigger wire. Route it down to the starter and connect it to the only small terminal down there.
Old Apr 2, 2007 | 02:16 PM
fast377's Avatar
That's what I was thinking...now what about the other two?
Old Apr 3, 2007 | 12:14 PM
fast377's Avatar
I just figured out the last two...they go to the oil level sending unit. Thanks for everyone's help.
