Video of my LS1 swaped 240SX (aka 346SX) 0-60-0 Runs
Here's a video I put together quickly tonight of some runs I made at the Year One Experience this last weekend. I hope the link works:
http://video.ls1tech.com/video/bcf0c...3401849c04.htm
Here's the full write up about what went on: (the car is on open C5 manifolds for right now, looking into finishing the exhaust now)
Ted J's 346SX at the Year One Experience '07 0-60-0 Challange.
-First run - That was the first time I went WOT with the car. Only hit 50 MPH cause the speedo was off and I was also spinning in 2nd gear.
-Second run - Got up to 72 MPH. Still spinning in 1st and 2nd, a little in 3rd as well. Runnning skinny cheap tires right now. Braking also wasn't good, suspension and braking all stock for now. Looking into upgrades for both now!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
There wasn't an oil leak, it was a coolant leak. Didn't run the seal tablets from GM with dex-cool and the water pump was leaking. Put the cooling system seal tabs in and once it got up to temp. the seal tabs sealed the leak. (dex cool is known to be bad on water pumps, was in a hurry getting the car ready to go to this event and was working long hours into the night and forget to use the seal tabs.)
Hey awesome! What diff are you running out back? One thing that's a problem is the gear ratios. I think a good option is to look for a 3.6 to run rather than the 4.08. There's a few options I've read about such as using the q45 (97-01 diff and j30 axles) which has 3.6 gearing. Keep the vids posting!
Thanks for the response!
Originally Posted by GTOpowered240sx
Nice! I like the 346SX on the rear. Just installed my MS4, so I have atleast a month before I'll be able to do that.
Was that at RA?
Was that at RA?
MS4, dang man, that should be fun. Looking into cams for later but for now once I get headers onto the car that will do it for power upgrades for I want to get a cage in the car and also get the suspension tuned up as well.
Yup that was at Road Atlanta. Was at the Year One Experience this last weekend.
Originally Posted by fouz65
congrats on getting her going. thing is quiet for open headers. do you do a burnout for runs like that?
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
The only burnout I did was through 1st and 2nd gear getting up to 60! :-) Those were 205's out back and they were the ones I got with the wheels so one actually was down to the wear bars and the other had some thread left on it. That's why the car pulled some when I was getting onto the throttle. The front tires though were 215 Falken 615's, first time ever on those tires but I've been very impressed by them so far.
Originally Posted by memphiss13
cool video. hey ted do you mind posting up more pics of your headers after you finished them?
I've got a few things to work on before even starting the headers so I don't know when I'll be able to fab them up.
Originally Posted by kansaschity
those falken azenis are awesome tires for the street, get some out back too and you will be pleased
Originally Posted by fenix999
sweet, get some wider decent drag radials which im guessing should be cheap in those sizes and that thing will prolly be sicker than it already is. Awesome stuff good work !! makes me more excited about my rx7, someday! ![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by Ted J
The stickers were done up to help make the car not so plain. My brother told them to stetch the font out some so it matched the original on the car better but we had them do it at the last minute so it was better than nothing. It only costed like 3 or 4 bucks so we'll have them make up new ones later.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I wanted to make it up to the Year one exp., but couldn't get free. I bet it was a blast. We'll have to meet up some time if I ever finish mine. It'd be fun to take both of them out one night and terrorize some of the so called bad boys in atlanta.
