Fuel Injection on a 5.3
In my opinion, taking one of these motors and putting 50 year old parts on it is criminal. Why not just use a standard 350 Chevy? You can make the same power with one of those.. (no answer required)
All the LS-x intakes other than the L92 will bolt in place of each other. The block and heads are the same as far as angles and height, similar to the old Pontiacs.
You'll need a fuel pump for EFI applications. You'll also need a wiring harness and computer to run the whole deal.
IMHO for street use the injection is the only way to go. Get with Wait4me or Speartech ect and get your initial setup and you should have 0 hassles from then on. My 1958 Chevrolet Delray can sit for months and starts first crank every time. No more carb adjustments, plug fouling ect.
I bracket raced for years and you can't believe how the correct fuel curve will change in just an hour or 2. With the injection, you are right on the money every time winter, summer, anytime. Good luck with the swap.
And I had a 14:1 compression 462ci drag race motor with EFI...
If you set it up correctly, it'll make minor adjustments by itself. Other than that, all you need is a laptop...
With the right combo you will still be pushing it to get 400 out of the 5.3 all motor... put a little shot on it if you want... if you want to swap intakes, get an LS6, dont mess with the LS1 intake, it will hurt more than help... an LS2 truck intake (TBSS) or the popular LS6 swap will be better for you. Hit up performancetrucks.net if you want to find out exactly how to make that 5.3 scream.
Seeing as you have a 42 chev, you have lots of hood clearance, so you could get a 6.0l truck intake (they flow the same as a LS6 intake) and they have a fuel regulator built into the rail. The 6.0L injectors will do just fine for more than 400HP. Get the wiring harness from the year of truck your motor came out of and build your own harness. I built mine in a couple of days of fooling around. I used a carter 5001 frame mounted electric fuel pump and hooked it all up. If you want get the heads done and stab a bigger cam in, Use some headers and get it all tuned. You should make at least 325HP at the wheels, 375 or so at the motor and that will spin your tires all day. My LS1 and my Dads 5.3 are stock except headers and we can kill tires no sweat. I wouldn't be concerned about trying to get to 400HP, these motors have much better torque curves with injection than our old 350's.
Good luck, and if you have anymore questions, let me know.
That said, in a fat-fendered street rod I'd probably go with a carb-style LSx intake that's been machined for fuel injectors simply because of the shape/size of the engine compartment.
efi-
ls6 intake (or similar but i dont think 6.0 will do it)
throttle body
fuel rails
28 maybe 36lb injectors
he is going to need a harness
all of the sensors involved
some kind of engine management
a cam of some sort
springs
push rods
high pressure fuel line and all fittings involved
efi fuel pump
regulator
probably a different fuel tank
dont forget your tuning software(this will be a big learning curve)
carb-
intake
carb
fuel pump(at least half the cost of an efi pump)
fuel line
regulator
cam
pushrods
springs
ignition box
maybe i am wrong but the efi doesnt look very budget friendly, and just by my rough calculations it looks like you could go ahead add a set of heads to the carb side and still be well under the efi budget. in the end it doesnt matter you build it how you want and spend what you wanna spend on it.
