LSX oil pans
Old Feb 18, 2011 | 06:07 AM
  #361
chevellenut71's Avatar
sorry gm lists it as there muscle car ls1 pan
Old Feb 18, 2011 | 03:13 PM
  #362
ImprovedRacing's Avatar
LS1Tech Sponsor
Originally Posted by holschen
wonder if holley will feature a oil pressure relief valve?
No it doesn't. But it doesn't do a whole lot anyway.
I believe that muscle car LS1 pan that chevellenut71 mentioned is similar to the Holley pan. Can you confirm? We always recommend GMPartsDirect.com to customers. They have the best prices by far.
__________________
Call Us: 407-705-3054 MON-FRI 10am-6pm EST
Like Us: Facebook - Twitter - Youtube
Old Feb 18, 2011 | 03:32 PM
  #363
52 Rat's Avatar
GMP does offer good prices but they seem to make up for it in shipping and handling fees. I saved almost $50 going directly with my GM dealer. I do have a dealer account and that helps a little.
I'm pleased with my F body pan and parts. The pan came with bolts and gasket. The pick up had the o-ring already installed.
Old Feb 22, 2011 | 07:45 AM
  #364
LS376-65-CHEVELLE's Avatar
Angry Chevelle trouble.
Hi! Newbie here, been reading posts for a few weeks......installing a GM performance LS376 & T56 into a 65 Chevelle.....i tried using the stock oil pan that came with the engine, it shows up as the LS2 corvette pan on this thread. I was able to get it to fit in the car by notching the front crossmember, but now i went to move the steering and the tie rods hit the side of the pan. I have Edelbrock adapter plates with the short energy suspension mounts. Anybody been in this same boat?
Option #1 raise engine 1"
Option #2 get different pan?
Does the GM muscle car pan work with an a body Chevelle?
Thanks in advance
Chris
Old Feb 24, 2011 | 04:52 PM
  #365
1961ba427's Avatar
Originally Posted by magic
Does anyone know what would be a better fit oil pan on an LSx swap into an SN95 Mustang with a tubular K-member? I might be using a 4.6 QA1 or GMS K-member, with the modified 4.6 motor mounts...
Corvette LS2?
Caddy CTS-V?
F-body?
Will the GTO pan work?
Old Feb 27, 2011 | 08:59 AM
  #366
mt5425's Avatar
Chris, the GM Performance pan does work if you use the stock mounting location on 68-72 chevelles and use 1/2" spacers between the mounts and the LS block. I just got done doing it this morning. If your bringing the engine closer to the firewall,it wont be an issue, but there will be near zero clearance back there. Also, if you go under the stock height on the front end......plan on buying another pan if you hit a speed bump! Hangs low on mine, but sits the same as my headers so i'm good with it. Since yours is a 65, may be the same install info???
Old Feb 27, 2011 | 12:06 PM
  #367
mt5425's Avatar
I have several pics of the LS1 INSTALLED in my 70 Chevelle if someone can re-size them for me. Shows position,mounts,and lock to lock on the steering clearance using the H3 pan. She's going in for paint Wednesday!!! Wish I had the wiring to have it running before that...but is what it is.
Old Mar 1, 2011 | 03:37 PM
  #368
parts can in from gm parts direct 225.00 to the door for everything thought that was a good price
Attached Thumbnails LSX oil pans-img00018-20110301-1602.jpg   LSX oil pans-img00019-20110301-1603.jpg   LSX oil pans-img00017-20110301-1555.jpg   LSX oil pans-img00020-20110301-1604.jpg
Old Mar 11, 2011 | 02:19 PM
  #369
Pocket's Avatar
Update:
2005+ C6 Corvette wetsump LS2/3 pan PN 12581810 is no good. New PNs are listed below. Confirmed them at the dealership today 3/11/11
12624617 Pan
12558750 Pickup tube
12558189 Windage tray
Old Mar 15, 2011 | 01:31 PM
  #370
cookseyb's Avatar
I priced the Holley pan this morning thru O'rileys and it is 550 plus tax! FWIW
Old Mar 16, 2011 | 01:30 AM
  #371
holschen's Avatar
Default yyyiikes
550????
thats even more than mast´s
what makes it worth 130 more than mast´s???
Old Mar 16, 2011 | 01:56 PM
  #372
jrs396's Avatar
Summit is showing the Holley pan for $ 429.95 with a ship date of 4/7/11
Old Mar 17, 2011 | 02:44 PM
  #373
dirthead racing's Avatar
Pics from mt5425:
Old Mar 27, 2011 | 09:11 AM
  #374
GTMLS3's Avatar
Originally Posted by ShiftyCapone
Fantastic thread.
Does anyone know the dimensions of the GMPP "Muscle Car Pan"? How does it compare to the F-bod LS1 pan. It sells for much cheaper and I want to see if this is an option.
EDIT. Looks like that kit contains the LH8 pan but I am still unlcear on its dimensions when compared to the F-bod pan.
EDIT #2. Looks like it is 2.5" deeper than the f-bod pan. Lots of info in this thread!
This thread has a lot of good info, but I can not determine if the "muscle car pan, #19212593 will set into a 91 Camaro, maybe missed a post on this one. And what oil filter part number does this pan use?
Old Mar 27, 2011 | 12:02 PM
  #375
GTMLS3's Avatar
Why did my post question, stop a good 374 post? I just could not determine if 19212593 would do a 91 camaro?
Old Mar 27, 2011 | 04:29 PM
  #376
camarof41_383's Avatar
The muscle car pan hangs too low, you need to get a F-Body pan. I looked into the muscle car pan before my swap but determined it wouldn't work..or atleast wouldn't work well.
Old Apr 13, 2011 | 10:32 AM
  #377
t4rs14's Avatar
Another option you all now have depending on your application is our Holley LS Engine Swap Oil Pan designed for retrofitting any of the LS-series family into some of the more venerable chassis' from 1955-1987.
Here are a couple of photos depicting vital dimensions that will be useful for you guys/girls with projects.
Old Apr 20, 2011 | 04:48 PM
  #378
fast's Avatar
my holley pan arrived today ... nice looking piece
Old May 7, 2011 | 11:09 AM
  #379
mserges's Avatar
Default Oil Pan Swap - fitting over oil filter in truck pan?
I am swapping my truck oil pan and wondered if I need the fitting that sits over the oil filter from the truck pan. It it a screw in fitting and looks like a pressure relief valve of some sort. The new pan is not tapped for the fitting. It looks like none of the new pans are tapped for it....does anyone know what it is for and any unintended consequences of leaving it out?
Thanks!!
Old May 7, 2011 | 02:30 PM
  #380
GRFMotorsports's Avatar
Thanks!!
It is a high pressure relief valve used in DOD and VVT applications. If you run a DOD or VVT system you need it, if you dont, then you dont. Most the new GM engines run the valve from what I have seen.
