LSX oil pans
Old 08-03-2009, 06:28 PM
  #161
LSfan70s's Avatar
Originally Posted by rsz288
The LS7 crank has a longer snout to drive the additional oil pump stage, and the front cover is "deeper" to fit the larger oil pump in.
Not so easy.
Got it
'Guess I'll look for a cheap exteral oil pump.
Old 08-04-2009, 10:59 PM
  #162
Darth-Jesus's Avatar
Default L33 Oil Pan Help
Hello All,
Another new guy here...I've been searching for a shorter oil pan setup for a Jeep build with a planned L33 motor swap and came across this site and started searching! I can't seem to find a definite answer so I thought Id try posting here.
My understanding is that the F-body pan setup works with LM7s, but question is, will this F-body setup work with the L33 motor? Any differences or advice? Thanks in advance,
F-Body
Camaro / Firebird
Capacity: 5.5 qts
Oil pan , List Price $266.39: 12558762
Oil pump pickup: 12558251
Windage tray: 12558253
Dipstick tube: 12551577
Dipstick: 12551581
O-ring for Oil pump pickup: 12557752 (Same as Corvette LS1/LS6)
Old 08-05-2009, 12:50 PM
  #163
46Coupe's Avatar
Originally Posted by Darth-Jesus
Hello All,
F-Body
Camaro / Firebird
Capacity: 5.5 qts
Dipstick: 12551581
Yes. It will work fine. The L33 is the same as an LM7 except is an aluminum block.
Old 08-05-2009, 04:57 PM
  #164
Thats what I thought, thanks!!!
Old 08-06-2009, 08:36 AM
  #165
Dan_W's Avatar
I just picked up the Fbody pan and pickup tube. The pan comes with the gasket and the pickup tube comes with the O-ring. The dip stick tube also came with its O-ring. No need to buy these seperately.
Old 08-15-2009, 02:19 PM
  #166
max1's Avatar
does any-b know what size of bolts.. these pan use??
Old 08-16-2009, 10:50 AM
  #167
beertestr's Avatar
M8 x 1 About 25mm long.
Old 08-23-2009, 07:10 PM
  #168
86 cutty's Avatar
witch one of these oil pans will fit my 86 olds g-body?? 5.3 or 6.0 are the engines I'm gonna be choosing from thanks guys.
Old 09-01-2009, 09:37 PM
  #169
DaveC3R's Avatar
Hey Cutty... We exchanged e-mail on the swap. I actually have two LS pans that I'm not using... one came with my motor, one I bought on a recomendation that was wrong. First is a 'Truck Pan' used but in good shape, second is the GM Perf Parts 'Hot Rod' pan, brand new. I can send you dimensions if you need them and are interested in either. David
Old 09-14-2009, 06:40 PM
  #170
Whickman's Avatar
Default Corvette LS2 Pan vs. Caddy CTSv Pan
Here's some pictures of the Caddy Pan next to the C6 Pan. The corvette pan does not fit well onto an automatic transmission because the vette tranny is in the back. It leaves gaps that should be covered. If you want to see what I mean go here
Vette Pan is on eBay
Attached Thumbnails LSX oil pans-pancomp1.jpg   LSX oil pans-pancomp2.jpg   LSX oil pans-pancomp3.jpg   LSX oil pans-pancomp4.jpg
Old 09-16-2009, 06:59 PM
  #171
tyger's Avatar
The part number for the o-ring that fits the oil pick up on my 2007 Cadillac CTS-V is #12557752.
Old 09-17-2009, 08:54 AM
  #172
LS1Tech Sponsor
Beau@SDPC's Avatar
that is the PN for alot (i believe nearly all of them) of the o rings that fit the car pickup tubes.
Old 09-18-2009, 11:49 AM
  #173
SikkyMFG's Avatar
Default Another front sump pan option for everyone
Version 2 of our front sump pan is now available with new added features
* 7 quart high capacity design using required oil filter relocation kit
* 6061 CNC flanges
* Baffle and trap doors - improvement on OEM design to fight oil starvation
* Increased internal clearance for larger aftermarket connecting rods/bolts
* Magnetic drain plug and all required hardware
* Includes New OEM gasket
* Includes New OEM GTO oil pump pickup tube (oil filter relocation kit not included).
* Low profile pan - great for cars that need added ground clearance
* Redesigned rear pan flange that allows use of factory LS1/T56 bell housing dust covers
These pan combines the best fit with superior oiling to any factory/aftermarket pan or baffle design.
Never worry about oil starvation again!
Recommended for both street and track use.
This pans are in stock and ready to ship. check them out here
http://www.sikky.com/view_item.php?id=37&catid=13
let us know if anyone has any questions or comments
thanks
Sikky
Old 09-18-2009, 11:53 AM
  #174
LS1Tech Sponsor
Beau@SDPC's Avatar
So the question is, on blocks that have the dipstick hole already in them, will this pan cover that hole up so it will not leak or do you have a plug kit for it?
Old 09-18-2009, 12:06 PM
  #175
Petraszewsky's Avatar
That slight gap could easily be covered by fabbing up a piece out of thin metal...
Old 09-18-2009, 12:43 PM
  #176
SikkyMFG's Avatar
Yes, when you buy the pan it comes with a plug for the OEM dipstick hole.
Old 09-20-2009, 10:04 PM
  #177
txcarbuilder's Avatar
Do the LS4 pans interchange with the other LS pans?
Old 09-22-2009, 08:56 AM
  #178
SikkyMFG's Avatar
that's a good question, I have not tested this. Anyone here know compatibility?
Old 09-23-2009, 10:47 PM
  #179
ml4te5ch4's Avatar
Lots of info here, very useful. I read these pages and I have a few questions-anyone have part numbers for that dipstick hole plug mentioned above? also part numbers needed for GTO pick tube O-ring, I believe the GTO pick up is 12572654? Thanks!
Old 09-29-2009, 08:40 AM
  #180
ssdungeon's Avatar
Default lq9 oil pan
will the c5/z06 "batwing" pan fit the lq9 block? Its going in my c5.
Quick Reply: LSX oil pans
