LSX oil pans
Personally, no I don't think it is. I think the F-body pan or Holley pan is the best option. CTSV pans makes you put the motor up too high. I fit my LS in mu Caprice with an F-body pan, no pan or frame mods. I can still fit the truck accessory drive too. I think the mount brackets I made will work on a G-body swap, and allow you to set the LS motor back 3/8" more than the SBC used to fit. PM if you want to chat.
Holley Pan 5.89 Inches Deep $ 299
AutoKraft Pan 5.5 Inches Deep $ 399
Moroso Pan 6 Inches Deep $ 299
I didn't spend a lot of time looking for prices yet, So far this is the best Pans I can find for my future swap in my El Camino
In order to use it however, you will have to notch it in most cases; if your engine is pushed right up against the firewall and you have the longer pitman arm and idler arm from an early car, you may acheive clearance with the steering components without having to notch the pan.
The Holley pan will clear the steering components without notching and has the same sump ground clearance as the F-body pan, but requires notching the crossmember to acheive the same ingine/trans inclination angle as is possible with the F-body pan because it is about 1" taller than the F-Body pan at its front edge. If you are building a stroker engine, the Holley pan is well suited for it and worth the effort required to notch out the crossmember.
