1970 GTO Version 2.0
Run Through the Hills pictures
Andrew
In addition to the great improvement in geometry, the ATS spindles offer numerous bolt on brake systems. Everything from stock C5, Z51, C6 Z06, or any aftermarket C5/C6 system will bolt right on.
I would say that adding the ATS spindles made as much difference in the drivability as adding the LSx engine.
Andrew
have one and would like to copy some pieces of the car.
Andrew
Andrew
60' 2.064
1/4 12.602
MPH 110.97
This is my last trip to the track for this year and I am very pleased.
Andrew
This brings up another point. Why couldn't the GM engineer who worked on the GMPP harness pick up the phone and dial up Autometer, VDO, and Stewart Warner? Between those 3 brands I bet you will cover 95% of the aftermarket gauge market. It would have been a 15 minute discussion to determine what these tachometers need in order to function properly. The information could have been easily outline in the harness instructions. Instead, they put this in the documentation of the harness:
"Note the signal is a low voltage square wave, some older style of tachometers may need a pull-up resistor in order to read the signal -- this detail is left to the user"
WTF?!?!?!
Andrew
Thanks
