Does anyone make an extension harness for the LS1 PCM?
I've got to lengthen my wires 3 feet or so, so I was wondering if someone made a harness with all the correct wire colors already ready to splice in. It would make it a lot easier than doing one wire at a time.
I bet if you talked to John at Speartech you'd get some info on that... He might even be able to do something for you with one of his harness.... Gonna be $$$$, but will be nice and clean and simple when its done.
The only other thing I can think of is lengthening each and every wire that you need longer one by one.
J.
J.
I can't seem to find it on Painless' site, but is it a harness to splice in between the main harness and the PCM connectors? Or does it just plug into the stock PCM connections and then into the PCM?
Just got an email back from Speartech. This is what he said:
Originally Posted by John at Speartech
Sorry, I can't do a discount on odd items like this. Whether it's 2 or 20, I have to pull a guy off of the more expensive products in order to make them.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
i know this is an old thread but I was wondering if anybody ever found an extension harness that plugs into a standard length harness. Im running into this problem now and dont want to cut and splice the pcm end of the harness if I dont need to. thanks
