LQ4 into a 3rd Gen/1972 Nova
Old 09-03-2012 | 06:26 AM
  #1001
1970 LSCamaro's Avatar
Following thread...lookin good
Old 09-03-2012 | 10:29 AM
  #1002
Marktainium's Avatar
Did you get a new balancer bolt? You can come get my hoist if you want.
Old 09-03-2012 | 01:36 PM
  #1003
camminls2's Avatar
damn find anything with the oil pressure, hook a gauge where the oil filter goes it may have a bad sended
Old 09-03-2012 | 02:34 PM
  #1004
Rybar's Avatar
Nice work Joe!
Old 09-03-2012 | 07:08 PM
  #1005
tsnow678's Avatar
Looks good FroJoe!
Old 09-04-2012 | 08:39 AM
  #1006
Chicago TDP's Avatar
Was everything already per-balanced ?
Old 09-04-2012 | 09:47 AM
  #1007
frojoe's Avatar
All the con rods & pistons were within a gram or something like that so they only ended up needing to balance the crank.
Old 09-05-2012 | 12:04 PM
  #1008
frojoe's Avatar
7 hours straight in the garage last night, no beer, went from unmounted long block to essentially ready to fire. Hoping to warm it up and drive tonight.
Old 09-05-2012 | 02:14 PM
  #1009
hookemdevils22's Avatar
sweet. can't wait to see the video. x-ing the fingers you get her up and running well.
Old 09-05-2012 | 04:05 PM
  #1010
-TheBandit-'s Avatar
7 hours without beer? With beer, you could have done it in 3, but you may have needed another 12 to fix the mistakes.
Old 09-06-2012 | 01:38 AM
  #1011
frojoe's Avatar
Drove it tonight. 40psi oil pressure cold idle, 30-35 warm idle. Tune is running crazy rich in part throttle especially under load around 1500-200rpm, like in the 11's or less. Engine also still freaks out if I approach 3,000rpm too quickly and accidentally build boost, shuts down into non-responsive safety mode, still have to hunt and find out why. But oh the glorious sounds as the turbo is spooling 2500-2800 and makes hissy sounds. If I held the pedal at a certain spot and the turbo was spooling just shy or just past 0psi, the acceleration was still pretty awesome.. can't imagine what 7-10psi will be like...
Rear has settled a bit over the couple hours I drove it (after this pic), now sits a bit more level, still have to raise the front maybe 1/2"
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-1.jpg   LQ4 into a 3rd Gen/1972 Nova-2.jpg
Old 09-06-2012 | 08:20 AM
  #1012
Awesome stance and glad to hear it is alive!!!!!!!!!
Old 09-06-2012 | 10:32 AM
  #1013
Love the view from the driver's seat. I think the stance looks pretty good, but will be better when you bring the front up some. Are you running a lot of camber?
If it were me, I'd drop it off at a reputable tuner and drop the coin to get it dialed in. I'm sure they've dealt with all the issues you're seeing already and could probably get through it faster. Good luck man - I am really stoked for you!
Old 09-06-2012 | 11:03 AM
  #1014
frojoe's Avatar
There was some screwup in the parameters table on my HPtuners so the driving I did last night didn't record the wideband AFR or the AFR error. I corrected that and have values now so can start tuning the driveability of part throttle.
I'm running about a 1.5* of camber, maybe closer to 2, but I will knock that back a bit once I raise the front another 1/2" or so. Consider the lowness of the front, and that I haven't trimmed the fender lips at all, the rubbing is very minimal being only at just under full lock. The front tire is a 235 which at full lock is about 1/2" clearance to the subframe rails, so when I eventually plan for wider wheels and a 265 up front, I'll definitely have to notch the rails. Also it has a bit of toe out, I think the car has bump steer although I haven't hit bumps while turning quick enough to notice it yet. I will adjust the toe out myself then once the springs settle a bit more and I adjust the ride height I will get it professionally aligned.
And she starts the daily driver routine..
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-0906020840_2-2-.jpg
Old 09-06-2012 | 07:07 PM
  #1015
Verz's Avatar
Nice! Been following but keeping quiet but nice to see you get the issues worked out and get to start enjoying it
Old 09-06-2012 | 08:10 PM
  #1016
Zedzag's Avatar
Looks great Joe. Hopefully I'll see her in person tomorrow night.
I used High Performance engines as well for my LQ4 machine work and they did a great job.
Old 09-06-2012 | 09:31 PM
  #1017
I think I may be more excited than Joe! Look who came over to my house...
I begged him to wash it...
Now my car looks like a 4X4!
Looks like I'll be riding alone to the Langley pre-show tomorrow night, but so will Joe!
Old 09-06-2012 | 11:13 PM
  #1018
wow, four long years (since this thread began) and she's finally on the road! man, there's a ton of people who've been waiting for this day, so congratulations from all of us X-body guys who came after you.
quick question: what's your front suspension setup again?
Old 09-06-2012 | 11:36 PM
  #1019
frojoe's Avatar
It's Speedtech regular control arms & QA1 coil adapters, I believe 450lb springs but they're a bit squishy with the iron block and turbo, maybe 500 would be better, and also it's sagged quite low.
Old 09-07-2012 | 09:20 AM
  #1020
Fb0dy0nly's Avatar
Originally Posted by Chicago TDP
You can order a brand new LS6 cam for $180!!!
Actually it is $265 and thats before shipping, shipping from them is ridiculous and probably $30 for a camshaft so it would be a lot closer to $300 for it and that is what most places charge for one new... so if you found it for under $200, please let me know. http://www.gmpartsdirect.com/catalog/frameset.cfm
sorry for hijack OP, just hate when people post mis-information. Your build is awesome and hope you get a nice new engine and pcm to work this time around.
You can also try ws6store.com. They are a sponsor on here and have great prices, free shipping if you spend $100 and actually stock a lot of parts as they have 3 warehouses.
Quick Reply: LQ4 into a 3rd Gen/1972 Nova
