Sub Frame Conectors
From what I can find I will also have to figure out what size bolts I will have to get to replace the stock ones.
(if you have the 3-points made, of course, that would be the best option!)
umi performance (reputable sponsor of ls1tech) bolt-in
umi's weld-in subframe connectors
bmr fabrication (another reputable sponsor of ls1tech) weld-in subframe connectors
you gotta consider how much these cars flex. to get a better idea, go ride around in a fixed or t-top car (with subframe connectors if you can find one). the more points that these bars are connected to, the better they will work. if you search around the suspension section, you'll read about stories where the sfcs move around when they're bolted on and don't quite do their job well and even where the manufacturer steps in and acknowledges this, then recommends that the bolt-in units are welded later for better support.
i went with bmr's weld-in in hammertone black. these photos show them while they were being welded on. you'll see the front driver's side was not yet completed. after these photos were taken, i took some paint to the underside and it looks/performs great.
but if you can get the "kenny diamond" style subframe connectors that connect in the middle.. that would be awesome.
if you can get someone to make these, you'd have some customers on this board for sure (myself included)
I bought the optional bolt kit so I could try before
I took the plunge and welded them in. I could
not get the bolts tight enough to keep from
rattleing. Instantly drove me nuts (not very
hard thing to do). Within 20 miles out came the torch.
They made a heck of a difference. Stopped
most of the flexing. Best single upgrade you
could make on a vert.
My $.02, go with the weld ins.
Jon
Found these and I am going to order, if I have any problems they can be welded in.
I went with weld in Bmrs. I didnt notice hardly any difference with the bmr weld ins.
I may still cut them off at some point and put on a more triangulated type of subframe connector.
Now why can't bmr, umi or whoever figure this out?
God knows they'd make a killing. You had one guy in here who said he'd
cut his bmr's out for a set.
If you build'em we'll buy'em!!!!!!!
