LS1 to a LS6?
Depending upon what you're wanting to do, i'd say change the intake over (depends on what LS1 you've got. The 01-02s already have LS6's on 'em, if i remember correctly) then do some long tube headers, ported heads, cam and a few other boltons and so on and so forth, and you're set.
Lil bit of dyno tuning, and computer tweekage, and you're good to go!
For the DIY'ers:
If you don't have a 2001+, get the new intake manifold. ($400)
Larger MAF without screen. ($100)
GM LPE CNC PORTED LS6 heads outright ($1800 pair)
2002 Z06 clutch ($300?)
2002 Z06 cam ($200?)
Voila! All GM parts, ~390rwhp through mufflers after tuning. The GM CNC heads are higher compression and flow better, yet are designed for medium cams like the 2002 LS6 grind. About $3000, THEN you can sell your existing heads for $250, so figure $2800 when all is said and done.
Yes, you can get more HP with aftermarket parts. OR you can get less HP if you aren't lucky. GM stuff is a known quantity and is reliable well-designed gear. Unless you are a serious racer, the LS6 is a pretty slick daily driver. No fuss, no muss.
Most guys change the heads, cam and intake (if they have the older LS1 without the LS6 intake) and that is usually better since most people use a hotter cam than the stock LS6 cam, and ported LS1 heads flow better than stock LS6 heads, not to mention they can be milled to raise the compression.
But ported LS6 heads flow better than ported LS1 heads.
So if you did heads and a cam and intake if neccessary (depends on the year LS1), then you could easily exceed the 405 hp of a LS6 with a LS1. I had 420 hp with just a C2 cam and the typical bolt ons on my LS1. If I would have put on ported heads, that would have easily turned into around 500 hp.
Hope that helps clarify.
Dean
The LS6 cam would also not be a great choice for forced induction. You want an exhaust biased cam for a supercharger. It sounds like you don't want to go to radical, so I'd probably recommend something like a 220-226 duration with lift determined by what the heads flow to.
For your question concerning order of installation, get the procharger first. Get used to the extra 140hp. Swap in the heads and cam...again, get used to the extra 50hp. Finally, build up the bottom end with forged internals, turn up the boost. Get a pair of diapers for when you **** yourself from the 600+rwhp.
Go check out what some of the sponsers have for cams w/ supercharger applications. Sometimes, if you contact companies like Comp, or Thunder they can tell you what kinda cam you're going to want w/ your setup and all that.
And i definatly would wait to build up the bottom end and toss up the boost. The extra 6-8 w/ the "stock" blower will be enough to give you a good punch for awhile.
