Build a bracket to mount the Accurate oil catch can to your C5.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If you've been wondering where you can mount a Accurate Works oil catch can on your C5 this might be of some help, I made this one out 6061 aluminum flat stock. Once I cut the two pieces of 6061 I needed to have it Tig welded ( I'm not set up to weld aluminum ), I then drilled the holes needed and did a slight polish of the bracket.
You'll notice one of the bolts ( there's two ) that holds the bracket to the head isn't tightened down, I mounted this bracket at a Chevy dealer who had a C5 on the lot just to make sure it fit correctly.
Al
BTW, I don't own a C5 but I know some have had concerns where to mount the Accurate oil catch can.
![](http://www.prowleronline.com/ubb/image_uploads/c5b4.jpg)
![](http://www.prowleronline.com/ubb/image_uploads/c5b3.jpg)
Al
Originally Posted by LS123
Where can I get a Accurate Works oil catch can?
