New PB cam only m6!!!
New PB cam only m6!!! (Edit: Now w/vid)
I took the car to the track today with the new LNC-003 2-step and beat my PB. Without the 2-step the car went 11.99@116.56 with a 1.75 60'. With the 2-step the car initially went 11.700@117.99 with a 1.67 60'. Then I hot lapped the car and backed it up with a 11.71@118.18 with a 1.72 60'. These times were with the 2-step set at 5500rpm. I let the car cool down and bumped the 2-step up to 5800rpm and ran a 11.645@118.08 with a 1.62 60'. I really believe with some cooler weather and a few tweaks the car will go 11.5s or better. A "Big" thanks to Larry and the guys at Speed Inc. It took a while but the car is coming around nicely. I'll post the vid when I get a chance. I almost forgot, this was all done with a Speed Inc SI5 cam and the supporting mods are in my sig.
Thanks Larry, you guys have been a big help. I really believe my current stup has more in it. My track time was cut short though cuz I had to go to my neice's and nephew's 1st b-day. I really believe with some minor tweaks and cooler weather the car will go 11.5s or better. Then I think I'm going to swap to an SI6 over the winter and see how close I can get to the 10s next year.
Nice runs. What is your race weight? My car is similar to yours. Cam only M6 with 9". 4.11s though. I have been thinking about a 2 step myself. I can never seam to be cinsistant with my 60'. What clutch are you running? What are you shifting at? How are you launching? Dump or slip? I can not seam to get my car in the 1.5Xs. Maybe I am not launching hard enough. You are getting pretty high on the 2-step. Soon you will just be able to launch it off the limiter.
UMI K-member & lower control arms
Driver's side airbag and steering wheel (replaced with a Momo)
A/C compressor, condenser, acumulator, and lines
Front and Rear bumper supports
ABS delete
Insulation
Rear and pass. seat removed
Driver's seat replaced with a Corbeau
Traction and Cruise deleted
Spare tire and jack
Billet Specialties Streetlites
I'm running Lingenfelter's LNC-003 2-step and I have a FAST/NW 92/92 setup.
Here's the vid of my 11.64 pass.
http://www.youtube.com/user/phatride.../3/M6A4ECmz4O0
